Whilst I haven't had the chance to work on the car recently, I have been able to put a bit more thought into a few areas...
Boot Lid / Access Panel:
I have been following the work Swifty has been doing on his Navigator boot lid.
I also liked the way Andreas used DZUS fasteners on his boot lid "next door".
Due to the fact that I have the longer "MkI" humps, my boot lid needs to cut through them.
In my head there are two ways of doing this:
- Attempt to make a straight vertical cut across the humps
- Make the cut at an angle "going forwards"
I've tried to draw these two options below...
I think the angle works best, as depending on how the car sits, the vertical line might be a bit out.
Whereas, a deliberate angle would always look like it was meant to be that way.
While looking for more images of how this sort of thing had been done on other cars I found this.
So if that approach is good enough for the Jaguar Project 7, it is good enough for me.
Prepping For Paint:
Lots of good advice on Scottie's build "next door" about painting and I had a real "deja-vu" moment.
Because I had just re-read Mister Towed's build thread to see how he had prepared his car for paint.
Then shortly afterwards, Mr T posted a summary of what I had just read on Scottie's thread, spooky.
Clearly there is no such thing as a short cut if you want to get a decent finish.
Allow me to summarise one of his posts here...
My word, prep for paint is a laborious process.
It's like painting the ruddy Forth Road Bridge
every time I go round sanding down the primer I find more dints and scrapes to fill that I hadn't noticed before.
It's now taken almost a whole tube of knifing putty and it's still not completely smooth.
After spending eighteen hours sanding over the last two days I'm absolutely knackered.
So clearly I need to take my time and do the best job that I can.
After all, the body shell has so many symmetry issues that a "professional" paint job would be a waste of money.
[color="red"]Question - "Knifing Putty" :[/color]
What do people use / recommend as knifing putty / stop filler?
There seems to be various options, dolphin glaze, liquid gold, etc.
Or are they all pretty much the same?
Anyway, that's all for now, take care, Paul.
