I answered Geoff's request for help regarding the door to bonnet gap,
I recommended Leigh at Automirage in Black pool due to him being nearer than me, plus he has a lot of experience with fiberglass cars.
Due to the distance between us I didn't think I would be quoting for the work, however I did mention to Geoff that I was going to be at Donnington that week end and maybe we could meet up for a chat.
So on a very wet and windy Saturday morning a couple of weeks ago I met Geoff outside the Motor museum at Donnington, had a look at his car and he had a nosey around mine.
I gave him a rough idea of costings, it must of sounded ok to Geoff as he then said "ok I will bring it down to you next Saturday" so following Saturday he arrived, a quick run thru of what was needed and I took him back to the station where he took the long journey back oop North.
Apart from the gaps being a bit iffy the car wasn't too bad considering it lives outside in all weathers under a cover, one small problem mentioned was that the doors did not open very far plus their were a couple of star cracks here and there.
Anyway I had a week to do the job as Geoff was booked on the train to come down the following Saturday.
Here are some pics of the work carried out.
This is how far the doors opened.
On the drivers side the door was sticking out quite a bit, the skins have been bonded on which is good as it stops them moving around, so i had to split the skin and push it back in down the leading edge.
The other thing Geoff wanted was some narrower top door mouldings as the ones fitted were rather wide, the skin on the drivers door was not a good fit to the window at the rear of the door so I folded up a sheet of alloy and glassed it in on the top edge.
The passenger door bonnet gap was not too bad, it was just the bonnet sticking out a bit too far, as we didn't want to take the bonnet off to do the cut and pull method I slit open the inner and outer skin, removed the material required and re bonded it back together.
There were a couple of sink marks and cracks were the bonnet straps had been fitted, these were ground out, glassed up and filled.
Then it was on to the painting side of things, 1st off some Polyester primer, I put this on with a roller just for speed really.
The other concern Geoff had was where the pillar meets the roof, it had been cut and filled but had a rather large gap, this was reduced and also straightened up a bit both sides
Then it was on to getting it in to 2k high build primer, we were originally not going to get involved doing the roof, rear wings, boot lid etc, one to keep cost down and two due to the time available, however best laid plans and all that, so I blocked the roof and got that in primer along with the doors and front clip.
