My Photo's
2 Sep 2007, 10:57pm
Looking good Peter :D I put the headlights behind, like the look better especially with the spots on there :)
20 Oct 2007, 9:01pm
Spurred on by Patrick's SVA pass, I worked on my car today. Its getting a little chilly, so time to refresh the anti-freeze. The first lot had got pretty murky so I had put some radflush in a few weeks back to get rid of all the rust and gunge from the engine which sat empty for nearly three years.
Whilst I had the coolant drained, I fitted a new bottom rad hose as the one previously fitted was from the donor. (Anyone wanting to copy this design should note that this hose is in fact a Thermostat top hose with about 10mm trimmed off. It fits the 35mm plumbing pipe and radiator bottom outlet perfectly)
I also fitted the temperature sender for my temperature gauge.
Next job was to fit the extra spacer between the brake servo and master brake cylinder. Thanks to Stuart for the idea and Robin for the design plus Patrick for posting the drawing. (Pictures on my Flickr site)
I had a little drive up and down to test the brakes and it worked a treat.
Whilst running the engine to re-circulate the ant-freeze, I solved my misfire problem.
This has been bugging me for the last few weeks. By listening to the injectors by the old technique of a long screwdriver resting on each injector and the handle pressed against one ear, I discovered that injector number 6 was not firing. I first suspected the connector on the side of the engine beneath the inlet manifold but that didn't seem to be the problem.
Then I tried a sharp tap on the side of the injector while the engine was running. That instantly fixed the problem, the injector started up and the misfire was gone.
Engine and exhaust note now sound much smoother.
I had had the injectors utrasonically cleaned before I re-assmbled the engine, so I assume that this one was just a but gummed up from not running. I'll keep an eye on this one incase it is faulty.
I also, fitted the hose clips in the steering rack to limit the range and stop the front axle uprights hitting the front shock absorbers.
I few test drives up and down the garage block confirmed everything worked fine but there is more work required to get it to self centre from full lock.
Some pictures here.............
http://www.flickr.com/photos/peters-bmwmarlin/
20 Oct 2007, 9:45pm
looks good Peter :)
Try a bit of toe out should help it self centre, toe in stopped it self centring. Not tried parallel yet but that's what Marin recommended. Try the camber at -0.75 ish. Not measured the caster but its got 2 washers at the front and 3 at the back (now the wishbones up the right way it works just fine!)
23 Oct 2007, 9:23pm
Servo...
Peter,
can't find anything about the servo earlier - what was your original problem? My brakes need a hard push and I have to be honest to say I don't think I can get the wheels to lock up even with full pressure on the pedal. Think it's the same problem you had.
I'm thinking it could also be sealant - I can't see any round the servo and marlin mounting plate - guessing that if there isn't any I'll have a potential vacuum leak.
So I'm thinking of unbolting it and just adding a little standard kitchen bathroom sealer because I have some to hand...
Andy
PS - I do like the spots - on next years show shopping list!!
23 Oct 2007, 9:34pm
Original problem on our cars was that the pedal did nothing until 1/2 down. The spacer means that you instantly get movement on the master cylinder.
I've got silicon all round the join between the master cylinder and servo. Had a big vacuum leak there. Also used that white tape you get from the plumbing supply section of DIY stores on the vacuum pipe join to the servo which has sorted all the leaks.
If you do have a leak fixing it will improve how your engine runs too :)
23 Oct 2007, 9:37pm
hadn't noticed any engine issues but I'm all for more!!
it may be sealed and there isn't any leaked out but I'll check...
Andy
23 Oct 2007, 9:44pm
AndyDane wrote:
Peter,
Andy
Thanks, the spots are actually bargins off eBay,(£37 if i recall) but may rust through as they are not brass like the headlamps.
Brake problem was that there was a lot of slack between the servo pushrod and the master cylinder. You can read more in one of Patricks FAQ on his website.
I can lock my brakes from only about 5mph but I still have the crappy tyres off the donor fitted, so not much grip. You can test the servo effect as follows. With the engine switched off, press hard and hold the pressure on the pedal. Then start the engine and the effect of the servo will be the pedal will sink towards the floor a little bit. If it doesn't, you have no servo effect and yes, it might be the seal around the master cylinder.
I think bathroom sealant contains acetic acid, so probably best to get something from Halfords. Look for something like RTV silicon sealant.
We need to see more pictures of your car out on the open road! :D
4 Nov 2007, 10:20pm
Fitted the side bonnets this weekend......
they look great!
Latest tip, is fit the side bonnets before installing the headlights as they get in the way when you drill the fixing holes.
On to the bonnet hinge next, if the weather holds next weekend.
5 Nov 2007, 8:02am
very nice!
5 Nov 2007, 1:04pm
Looking great. It's amazing how it quickly becomes to look like a car once you fit the bodywork.
Best
5 Nov 2007, 6:39pm
Very nice, I remember getting to that stage, as Robin said it really starts looking like a car :)
11 Nov 2007, 8:14pm
Looking good Peter. I see your hinge is stainless - mine is brass. Did the hinge come from Marlin? (Stainless seems a much better idea than brass)
11 Nov 2007, 11:22pm
Yes, Marlin supplied, it was an option that I had to pay £15 extra. Had to buy a brand new titanium drill bit to drill all the holes!
12 Nov 2007, 2:53pm
That's looking really good (I think I'm getting bonnet fitment envy! Nice shutlines :D)
12 Nov 2007, 9:56pm
Thanks, but you might have noticed that there are no close up photos yet!
:icon_wink:
18 Dec 2007, 11:08pm
Not exactly car build progress but i've been having a huge clear out so that finally on Sunday I was able to bring the car home.
So after 4 years from starting to strip the donor the car is now in my home garage and I can say goodbye to working in the unlit, unheated lock-up garage. (I will miss the old lock-up :D)
The garage floor was treated to a fresh coat of International garage floor paint (great stuff!)
The plan was to push it the half mile in the cold winters sunshine but we got half way and ran out of puff (so we had to resort to a little petrol to help :D:D:D)
[IMG] http://farm3.static.flickr.com/2095/2121554082_45f0268286_o.jpg[/IMG]
19 Dec 2007, 9:44am
Ah, International Floor paint. Great stuff - and an unmistakable aroma for the Missus to moan about for several days as it permiates the house... :)
19 Dec 2007, 9:47am
That is a nice floor, if there wasn't so much stuff in the way I'd be tempted to do that as well!
29 Dec 2007, 8:31pm
Some Christmas holiday progress....
I've been focussing on some more off the wiring over the last two days.
I now have Brake Lights that work, Indicators that flash normally and in Hazard mode and a reversing light that comes on when in reverse. Plus brake warning lamp switches and wires. The wiring up takes much time for little visible progress. Lots of time routing cables and fitting those fiddly Lucus spade terminal connectors.
best regards
30 Dec 2007, 7:37pm
Been doing the same. I must have rewired the front lights half a dozen times to try and get a neat and discreet run for the cable. Cracked it in the end...
Still haven't got around to fitting the top bonnet although I am now the proud owner of a stainless hinge courtesy of Ebay.
8 Jan 2008, 12:40pm
well done from marlin cars
I would like to congratulate you and all the other Sportster builders (inc Patrick and Richard) for keeping your web sites up to date with such detailed pictures and advise. It is a great help to others either building or thinking about building to know there are so many of you out there willing to advise and to also see what a great job you are doing. Of course it helps that you are building such a well engineered product ;-)
Well done
Terry
8 Jan 2008, 4:30pm
Thanks, Terry.
It's been 4 years now since I started to dissmantle the BMW donor, but to be fair i've had a few whole 6 month blocks of no progress due to other DIY and family commitments.
I've learnt a huge amount about the Sportster and the BMW 3 series and this forum has been a great place to watch other builds and to share problems and solutions.
But we need to see some newer builders over here. Do encourage any new builders in the last 12 months to join us!
The Flickr site I use to post my pictures is dead easy to use, as I am no web expert and only costs about £12 a year.
8 Jan 2008, 6:15pm
re more new builder pics please
ok will do my best ;-)
