Mike, Keith and Davecymr thanks for the support. Nothing much to update as I have been away for the new year in Ireland with limited internet and not back to Yorkshire till Monday.
But I have come up with a plan for the front grill whilst been away so will try and fit that on Monday.
Keith I could use the contact you have for wire wheels painting when you get chance please.
Davecymr the garden lockup I think I am safe till March I wasn’t brave enough to use the summer house lol, thank you for the garage comments still work in progress after 3 years but my first garage build and design.
Mike once the lights are in and working I think it will be time for a trip out in the alpha.
Cas Coatings, ecleshill, must be near you!
Well after a long trip at work and a holiday I am back on the Alpha. After a catch-up on the forum that took a while it’s nearly 2 months since I last looked.
Keith thanks and yes cas coatings is the one I used.
Micky1mo time is getting short for the summer but I am determined to have the Alpha on the road this summer.
So I pushed the Alpha out to have a look in daylight.
I am still not happy with the front wheel arches for the clearance of the arch around the wheel. I know the car was originally made for 14” wheels and I had
fitted the bonnet slightly higher at the front. I decided I have to get this right. So back out with the foam tape rule marker and grinder.
The next few photos show me modify the front arches again.
The arches went much faster this time and not many plastic clothes pegs were harmed this time lol.
This just left me time to start adding filler to fibreglass.
So with a bit of luck or good time management I should get to fill both arches tomorrow and smooth off.
So at four projects I decided with good help from my wife I needed to complete some of these projects. So my triumph spitfire was complete and as a project as a far as I was going to go with it. So that was sold which made room in the second garage for the Sammie spider to go in which it sat with my other spitfire that
So I have always wanted a 13” wheel set up for the Alpha however after trying various designs including some wires I borrowed, I decided to go for 14” wire wheels
Thanks for the welcome back Micky the Alpha looks great is there any views of the rear and how the bonnet locks down they look like the original triumph spitfire ones.
Mister toad they will be more updates on the wire wheels front if I get some free time at work tonight.
how the bonnet locks down they look like the original triumph spitfire ones. .
Your right the bonnet locks are the original ones as used on the Spitfire.
A slot to suit is cut in the bonnet and the locks just bolted in place and the original internal hook is repositioned on the inside.
I found it easiest why to fit them is after fitting the lock mechanism to the bonnet, remove the front wheel and then you can look in and see to line up the internal catch.
Quick turn around home this time so due to some time waiting for ship I can update the progress of the Alpha. With the plan of going down the route of 14” wheels I needed to find them in othe other garage. I then took six wheels to the garage to fit new tires. The garage owner is my friend and insisted I removed the old tires prepared the rims fit the inner tubes and tires along with balancing them. This along with tiding the other garage took most of the day.
So with finding the wheels I needed new tires. My friend looked into sizes and came up with some cooper tires 14” 175/65. I was under the impression he would fit them but he showed me one and supervised me on the rest including the spares so my first time seeing inner tubes and taping up the end of the spokes on the inside of the rim. So it was a quick trip home to fit the wheels with the rear wheels were easy with the new hubs the fronts took a little longer as I hadn’t fitted the brake callipers. I only managed one before my wife returned home so that was end of play for the day.
Also I will up date when back in uk as internet is too slow to update photos and text at the moment.
