Sammio workshop project.
10 Feb 2020, 6:09pm
Now the manifold is fitted it doesn't look to odd.
I'll just have to wait and see if it works. :madgrin:
11 Feb 2020, 12:37pm
I plumed in the fuel line, flipped the key and BANG, IT FIRED UP, RAN AND REVED AS IF IT WAS MADE FOR IT !!!:rockon::rockon::rockon:
I'll take a video clip later !!! :director:
11 Feb 2020, 1:41pm
micky1mo wrote:
I was going to finish with a pair of chrome dome nuts on the outside.
Good idea, thanks. Might steal that :D
11 Feb 2020, 9:16pm
Great news, I am glad your persistence paid off.
15 Feb 2020, 8:51pm
This is the carb, air filter and throttle cable all in place and ready to roll.:badgrin:
23 Feb 2020, 11:03am
Mike – Is that one carb HUGE?
As I’ve got two of those pancake filters on my little 1500 engine.
Either way, glad to hear it is running. :cool:
23 Feb 2020, 9:11pm
No, it's a standard weber twin choke carb off a Ford Essex 3lt V6. :smokin:
4 Mar 2020, 6:43pm
Finally I made the effort and fitted the doors.
Drivers side
Passengers side.
Not a bad fit as it was not an easy task because they open at about 45%.:icon_frown:
The blue wire hanging out of the open door works the latch opener until I figure some thing else out. :icon_redface:
11 Mar 2020, 5:59pm
The brake have now been sorted.
New calipers.
If you look closely you'll see the caliper have 3 bleed nipples one on each side and one on the top.
They also have 2 feed flexi lines.
I thought I'd be clever and just use one feed line and block the other off with a bleed nipple making a duel line braking system.
This was OK until I tried to bleed the calipers !!:mmph:
I could bleed brake fluid from the bottom 2 nipples but not the top one!!
No fluid came out!!
After much head scratching I realized the caliper is split into two independent chambers each chamber feed from one of the two separate feed flexi lines hence the 3 bleed nipples!!:icon_mad:
I had to change the braking system into a duel circuit system.
The servo master cylinder rear take offs now feed both the rear brakes and the bottom chambers of the front calipers and the servo master cylinder front take off feeds the top chambers of the front calipers.
So in theory if I cut a brake line I should still have a reasonably decent (but limited) brake, we hope. :fear:
The end result is .
1, Single line braking system.
Cut a brake line and loose all the brakes!!!
2, Duel line braking system.
Cut a brake line and loose either the front brakes or the rear brake depending on which line is cut!!!
3, Duel circuit braking system.
Cut a brake line and have either 1/2 the front braking power with no rear brakes or 1/2 the front braking power plus the rear brakes.
I believe it was VOLVO who came up with the last one!!!
20 Apr 2020, 5:11pm
Things are very quite around the workshop but I have sorted out the engine in my daily driver.
The problem turned out to be the balance shaft gears were stripped.
So it was quicker and easier to replace the engine.
The truck now has a new MOT and is still earning it's keep.
So, if you see me about please give-us-a-wave. :horn:
Due to things being quite next door has taken on the "D" type for paint.
After day one.
The final colour will be, JAGUAR - British Racing Green. :thumb:
20 Apr 2020, 8:07pm
Can't wait to see it in paint.
21 Apr 2020, 6:20am
Exciting stuff - I love the point where a project gets its first coat of primer and looks all one colour for the first time.
21 Apr 2020, 5:47pm
it brings the whole project together :whoo::whoo:
22 Apr 2020, 4:08pm
Called in the paint shop today!:icon_surprised:
coming along nicely. !!::pop2:
22 Apr 2020, 5:25pm
fantastic!
22 Apr 2020, 6:22pm
Looking good. Will be nice to get it ready for the road, hopefully lock down will be over before this glorious weather!
22 Apr 2020, 9:10pm
You could be looking at an original one !
25 Apr 2020, 7:06am
Mike – The BRG looks great. :cool:
Do you still have a buyer lined up for this ‘Jag in a Jag’?
25 Apr 2020, 10:42am
Paul, Jag-in-a-Jag !! I like that :thumb:
Every man and his dog what's to buy it but no money has changed hands so it's still for sale !!!":fish:
I am looking forward to the "road development" stage. :becky:
6 Jun 2020, 4:53pm
I'v done a small upgrade on the truck and replaced the original intercooler with a larger one from a L322 Range Rover..
It sits nicely across the front of the radiator, it needed not serious cutting to fit and I was able to use the original pipework to plum it in.:rockon:
There's not much noticeable diferance in general driving with the larger intercooler but the truck certainly develops more torque up hills. :icon_biggrin:
28 Aug 2020, 3:58pm
We finally got some spare time to work on the "D" type so we sorted out the wheels.
Not quite the original Dunlop Magnesium specials but a set of TR6 wheels and a few quid's worth of bits-and-bobs and we get these.:becky:
We also fitted the wind screen.
I have made steel supports for each end of the windscreen to add some strength and to to give the door windows something to close against
As usual, despite our best efforts we still managed to crack the screen on the last screw !! :shock:
7 Sep 2020, 10:19pm
Mike – Shame about the screen cracking. :icon_sad:
Good luck with the rest of it. Paul. :)
10 Jul 2021, 3:33pm
Another workshop project completed.
https://www.youtube.com/watch?v=HlFE0GRRt6s
It's a PEMBLETON SS1 Grass hopper
Took this video just before a test drive but, if you look closely you'll see the puddle of oil under the engine !
Turns out the oil cooled pipe split so no test run today!!:mad2:
11 Jul 2021, 2:47pm
Looks like the JAGUAR project is now completed.
https://youtu.be/qCOeMb7yVMI
Now Registered correctly with DVLA as "SAMMIO D TYPE REPLICA"
Just needs to under-go a little "road development" then it's for sale!!!
Sometime I hate my job (LOL)! :eusa_clap:
11 Jul 2021, 5:03pm
Pembleton is just bonkers so I love it, and the D Type is a credit to you, well done on both :)
