volvo p1800 into ferrari 275gtb nart spyder: v12, 5spd, tube chassis
I am fortunate to be able to be as creative as I want, thankfully. Where I am in the US there's absolutely no kind of inspection since it is already titled. I just have to pay my money and get on the road (if that ever happens)! I have been slaving away doing dirty work but I have some updates coming soon.
I made some progress a while back but neglected to post. This was tedious work but it had to be done. I decided to add some gussets from the rear frame crossmember that would tie in to the strut tower area/frame rails.
Next I prepped the whole floor, top and bottom to remove any paint, surface rust, and factory undercoating.
Priming, seam sealing, undercoating
Painting the chassis, firewall and interior floor
seam sealed the interior floor for now
installing the front end and engine
Next up I AM starting on the body buck. But this project is taking a back seat for a few more months while I finish an engine swap/refresh in another car I have.
It has been quite some time since I updated. I have been working on translating a 3d model into a real physical structure and all is going well so far.
I ended up shortening the sides approximately 2" for the wheelbase to match the body as well as massaging the rear quarters to look closer to photos.* Visually it looks correct after a quick photoshop job too.* I have to just assume the 3d model I have been working with*was a tad out of scale.* Unfortunately*the 3d printed parts are quite fragile and I need to reinforce the insides before I crack any more pieces off...* After that I can begin hard mounting everything on the chassis.* The plan is to have it all be bolt on*for ease of removal as needed for working on specific sections.*
Hi Garth,
Sorry for the lack of updates on this site! I have worked on it in bursts. I have the door jambs and door frames constructed out of steel and will be skinning the doors in aluminum shortly.
door handle construction based on 3d scanned/ printed part
