Another question (I am full of 'em tonight), does anyone else have a problem with the boot trough filling with rainwater? And if so, is there a solution?
for memory the front end is riding high as it's sitting on the headlight frame work ,I took a hammer to mine and flatten them down you can not see them when the fronts on an finished. The door window reveals I bonded a frame in to make a step meaning you then dont need a massive rubber to fill the gap. have a look on my build thread or ask NED for a pic of his to give you a idea. the boot must be the rubber it should not get water in it mine never did . good luck
Thanks Andy. Will have a look at your thread now. I think the boot rubber is ok, the water is gathering between the rubber and the outer edge of the trough. It could be because my drive is on a slope I suppose? I will try and get a pic, it looks like rain again!
I had the same problem with the front end and "trimmed" the fiber glass off the kit until it sat properly. I had to take quite a lot off.
The German guys also built theirs on MK2's and cut away the light mounts. I was advised against this but it's an option.
On the rain build up, have you put any drains in?
If you trimmed out the corners, how did you secure the front end? I presume just the plate down the front of the radiator into the back of the slam panel?
No, not done any drain holes, I must admit I was looking at that as a possibility, but by my reckoning the holes would drain into the boot area?
Just been through both of your threads Andy, I can't see anything about your window seals?
This is how much I ended up cutting away to make the front fit.
To make sure the front end didn't move I fitted these which fixed the bottom of the front to the chassis.
Thanks mate - a picture paints......etc etc. You basically took all of the big corner bit out!!! I can see the benefit of leaving the headlight brackets in, gives you something to mount bonnet rubbers etc to.
I had always planned on some kind of strengthening from the bottom of the front end to the chassis, but DO like those adjustable rods, where you get them?
Hi Craig regards door seals check out Jones thread page 9 he did the same as me cutting back the lip and re glassing the lip back in,my rubber seal was from Pheonix trim supplies check out their website as they have profiles to scale on it. I think i used 10 ml . I will try to find some pics of the pipe etc i used for the drains in the boot trough
Thanks Ned. Really appreciate it. Happy with what you did at the B pillar and around the top of the window........you wouldn't have a picture of how the top of the A pillar looks would you??? Sorry to be a pain in A***E but i have been pondering this for days.
hi Craig hope this helps,the drains are plastic plumbing pipe with the metal inserts that go inside. I set the inserts into the channel and glued the pipe to it from underneath with the pipe going through the boot floor,also here are some pics of the rubber window seal
Thanks Ned. You are a star. Only just finished working on the car and looking at the pics on my phone. Will have a look on the laptop at work tomorrow. Cheers again mate.
I am building my MX250 at the moment as well and come across the same problem of the front end sitting to high. I have based mine on a MK2 body and ended up cutting the corner supports off and reglasssing the corners back in at a smaller dimension so that it sat lower and also had to cut out the corner of the light support to miss the headlight buckets.
I then made a bracket to pick up the front brace in front of the radiator to bolt the front end to.
Have attached some photo's of what I have done and how low I got the front end although the last photo is upside down as I took it with my phone and can't seem to rotate it round.
