Mister Towed on the road...
15 Oct 2013, 8:47pm
davecymru wrote:
So you have a car on the road that you're enjoying _and_ you're going to the Gym....
Just like the rest of us....... :flypig:
He only parked outside..didn't actually say anything about going inside:D :D
16 Oct 2013, 7:35am
:eusa_whistle:
16 Oct 2013, 8:02am
Mister Towed wrote:
... I sure am glad I fitted a heater though. :smow:
I was going to ask whether you got the heater sorted out.
Where do you have the heating vents pointing?
16 Oct 2013, 9:26am
Heater works fine Paul, it just needed the inlet manifold 'pipe' clearing out and a bleed valve adding to the outlet hose at its highest point to get the air out of the system.
The vents are behind the wireless and can be rotated to point at your feet or into your lap.
The engine provides a fair bit of heat into the cabin too, I've driven it in some pretty cold conditions over the last few days and it's nice and snug in the cockpit. I'm aiming to keep using it through the winter on dry days, in fact, I'm off out in it now :twitch:
16 Oct 2013, 1:18pm
That's it Mr T ... if you've got it, flaunt it :attention:
ATVB
Slarti
16 Oct 2013, 6:40pm
What's the clothes peg behind the gear stick for Towed?
16 Oct 2013, 7:55pm
Well spotted Baz. My cheap ebay choke cable wouldn't hold itself so it was to keep the choke open. So far I haven't needed to use the choke so it's been a bit redundant. I may reuse the choke cable to pull a little weight to tap the solenoid when it sticks and leaves me embarrassingly stranded at petrol stations (twice now :( )
17 Oct 2013, 9:27am
I've got a pair of mole grips tucked down next to my drivers seat for exactly the same reason :)
17 Oct 2013, 9:43am
Mr T - Can I be a real pain and ask another question about your heater?
What does it need in terms of operating switches, is it simply on/off?
I guess the obvious shopping list is:
- Heater
- Vents
- Ducting from heater to vents
- Hoses from engine to heater
- Fittings to hold all of the above in place.
Is there any thing else I have missed?
17 Oct 2013, 10:44am
a warm suit and something for you eyes and ears?
17 Oct 2013, 2:11pm
- Heater
- Vents
That's pretty much it Paul apart from a control valve. I used one from a London Taxi, which is opened and closed with the donor's choke cable -
http://www.ebay.co.uk/itm/Heater-Control-Valve-Kit-Car-Classic-Car-Taxi-TX1-/200924321876?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2ec805d854
I reused the donor's heater switch to turn the fan on and bought some (expensive) bulkhead connectors to pass the hoses through the bulkhead without them fraying, but that's it, warm, toasty feet for me :mad2:
17 Oct 2013, 2:22pm
Finally got round to fitting the 150lb Spitfire front springs today, quite a simple job which took about two hours.
For those that didn't follow my build thread I cut my 200lb Vitesse springs down by 95mm. This gave me a cool look but no ground clearance and a ride harsh enough to blur your vision at 50mph.
After doing some calculations on the back of a fag packet I decided to cut the new springs down by just 35mm. Here's the old and new springs -
The result of changing these over is to give about 2" more ground clearance and a much more forgiving ride.
You can really feel the difference on the road, front end grip is stronger because the tyres are staying in contact with the surface rather than hopping about and braking feels stronger too for the same reason.
It now sits slightly nose up so I'll probably raise the back an inch or so tomorrow to compensate, then I'll probably change to 175/80/14 tyres from the current 175/70/14's to fill the arches a bit better and give the classic, tall tyre look that suits these cars best (imho).
Overall I'm very pleased with the softer set up front and rear and I don't think it'll spoil the looks once it's level either -
More tomorrow :)
17 Oct 2013, 2:44pm
Very nice Mr T.
With the 175/80 14s will you have to adjust/cut off some of the bulkhead or will they fit?
From memory, when we met at Revival you explained that you moved the bulkhead backwards about 20mm.
Keep up the good work.
Slarti
17 Oct 2013, 3:47pm
Hello Towed,
It looks very good the way it is. Are you sure you want to change the back? It doesn't show on the photo that the cars hangs a bit to the rear. It's pretty.
Bigger tyres could make the picture complete.
Michiel
17 Oct 2013, 4:33pm
Thanks guys, it never fails to draw a crowd when it's parked up.
I did move my bulkhead back 20mm Slarti or even the 175/70's would've fouled. I should get away with the taller profile tyres without any further mods though, the bulkhead slopes forward as it rises from the chassis rail and as I've raised the front suspension a couple of inches it moves the centre of the tyres that bit further down the slope so clearance increases. That's what I'm hoping anyway :)
20 Oct 2013, 2:41pm
inspirrational stuff towed. your car is a real ambassador for the Sammio/ribble range. I love 550's so your colour and dash choice is obviously swaying me a bit! keep it coming .
20 Oct 2013, 5:01pm
Glad you like my car TS. I went with silver because I initially wanted a 718 RSK replica (very expensive to build and I didn't fit in the cockpit when I tried one for size) which looks stunning in silver. Despite everyone telling me silver would be hard to spray I actually found it quite straightforward and the result looks period correct - it reflects the light nicely but isn't a mirror finish which would just look too new.
I still take my hat off to Gary J for evolving the shape from an old Nikri body he bought on ebay and reinventing the rebody concept, and I have no complaints about the quality of my mid production body shell (number 50 or thereabouts) for the price I paid. Bearing in mind that I got the complete body, internal frame, egg crate grille, lowered battery tray and 550 dashboard for under £1,300, while the body alone for a 356, 550 or 718 would've been around £3,500 + VAT, the Sammio is an absolute steal, even if it was rather thin and wobbly until it was bonded onto the frame and the cockpit boxed in with ply.
The best thing I can say about the product is that it genuinely seems difficult to build a crap looking one. They suit all colours and most chop and change mods, like bonnet scoops and bulges, and even look good in the bare fibreglass - just take a look at the gallery photo of 'skippy' an unpainted budget build completed by the chap in the goggles.
On the whole I can thoroughly recommend this kit to anyone. :)
20 Oct 2013, 8:00pm
hi T just thinking about my exust can you tell me if you used just a cherry bomb on the end . thank you dave r
21 Oct 2013, 5:39am
Yep, mild steel cherry bomb which was about £30 on ebay. Sounds nice :)
22 Oct 2013, 12:58pm
I've now had time to remove the 40mm lowering block from the back and replace it with three short sections cut from the original top leaves, each 5mm thick. This has raised the back end another inch without ruining the look of the car (imho) -
I've now gone from 95mm lowered 200lb springs on the front and 75mm lowered spring with three leaves removed on the back to 35mm lowered 150lb springs on the front and 15mm lowered spring with six leaves removed on the back. These changes have transformed the ride of the car which now feels far more compliant while still firm enough to be sporty. It's also given a tad more ground clearance so I shouldn't have to stop before speed bumps any more :)
Final step, when funds allow, will be to switch to a higher profile tyre, either 165/80/14, 175/80/14 or even 155/80/15's if some 4.5x15 wheels come up at the right price. Having taken a look at the clearance on the front I'll probably need to give the bulkhead another bashing to get any of the above to fit without fouling.
22 Oct 2013, 1:17pm
T, is it an optical illusion or is that rear wheel cambering in at the top?
22 Oct 2013, 1:22pm
There is still a bit of positive camber on the back wheels, but not as much as there was yesterday.
22 Oct 2013, 1:46pm
must be my eyes it looks like negative camber to my eye, ie the top of the wheel further inboard than the bottom. That said if it handles nicely than who cares!
22 Oct 2013, 10:35pm
Sorry, I meant negative camber of course. There's a bit of toe in too, but the handling is most satisfactory as it is without bothering to have it properly set up. As it's a road car and I like the way it drives I'm not going to mess with it. If I wanted to go racing it might be a different matter though.
24 Oct 2013, 3:15am
thats an awesome dashboard Mr T - did you do that yourself or is it from another car or is it part of the sammio?
