Fatbloke builds a Spyder
17 Sep 2013, 9:00am
I left the original panel as is. Looks fine to me haven't noticed any thing wrong with it .
17 Sep 2013, 7:48pm
fatbloke wrote:
Quick question guys, for those who have made the convertible. Have you put filler across between the Frankenstein bolts to raise the body work up to the same height as the kit or left the original panel there and worked around it?
I feathered the filler out behind the Frankensteins on the demo car. Post up a pick for me to look at.
30 Sep 2013, 10:14am
A little help please, the filling is coming along quite well but getting the area between the edge of the cut wings of the kit and the filler I'm using to blend is very tough. It feels smooth but with some paint on there is an obvious lip where the two materials meet.
Any advice on how to make the blend invisible? I'm toying with putting a small vee between the two and then filling again but I wonder if this will just move the join.
Chris - will post pics of the back shortly.
30 Sep 2013, 5:38pm
I skimmed the whole section with diluted filler. Obviously then requires sanding back and probably more filling.............
1 Oct 2013, 8:17am
Thanks, I'll give it a try.
3 Oct 2013, 8:13pm
Hi Patrick.
Sorry for the delay, been away for a short break. I will give you a call on Friday with some pointers.
13 Oct 2013, 5:47pm
Not posted for a while but thought it time for an update. Sorted some electrical problems, turned out to be a dodgy relay, so now the side lights work.
Fitted the boot lock with some extension tubes (note to self, check the mechanism isn't stuck before shutting the boot).
After some advice from Chris more filling and sanding on the wing joints and they're pretty smooth now.
Bonnet pins fitted.
and wheels freshly powder coated.
More filling and sanding over the next few weeks until I can get the cash for the hub adapters and exhaust and then, hopefully, on the road in the New Year.
13 Oct 2013, 8:31pm
Love the rear lights, wheels look great too. Coming along very well...
13 Oct 2013, 8:47pm
I agree, all looking lovely. Can't wait to see those wheels in place Patrick.
25 Oct 2013, 8:36pm
Amazing how a bit of primer can help you see how you're doing. Also makes you realise how much you still have left to do.
25 Oct 2013, 9:22pm
Nice going F.B. starting to look GOOD!!
27 Oct 2013, 4:13pm
Little things really do make a difference. Fitted some mesh into the old Mondeo grill and bolted it in place. Starting to look like a car now.
14 Dec 2013, 9:01pm
Took the cam cover off to paint it and now the bloody thing won't start. AAARRRGGGHHH!
30 Dec 2013, 2:37pm
Anyone considered putting wider wheel arches on the front of their MX? Just wondered if it might help the proportions a bit.
30 Dec 2013, 2:48pm
Where did you get the wheels powder coated, any issues and what did it cost?
I have 4 spare wires in the garage waiting to be powder coated in the new year.
30 Dec 2013, 3:04pm
Got them done at a local company in Hull. What I didn't know was that the previous owner had let the chrome get a bit crappy so when the guy blasted them the surface wasn't so good. They're okay from a distance but not so good close up. Should have been £160 but because he wasn't happy with the finish let me have them for £120.
Can't remember the name of the company but probably a bit too far North for you.
30 Dec 2013, 5:00pm
fatbloke - Your car seems to be coming together nicely. :cool:
Is there any chance you could take a photo of how these bonnet pins are fitted/mounted?
Also what did you have to do to seal this bonnet panel?
I'm just looking for ideas for a possible boot area on my Cordite kit.
31 Dec 2013, 1:51pm
My solution for the bonnet pins wasn't very subtle. I bolted some steel bar across the engine bay and drilled through. They are out of the way of all bits of the engine I need to get at and will unbolt if they're in the way.
Not sure how to seal it yet, was thinking or trying the sort of self adhesive draft excluder you use on windows as it's not too thick so will compress under the bonnet but should give a good seal.
Chris - can you drop me a PM on the cost for the arch extensions. Thanks, Patrick
31 Dec 2013, 2:24pm
Thanks for the photo & explanation. :cool:
16 Jan 2014, 10:26am
Wish me luck boys and girls as my cars goes off to the garage tomorrow to get the motor running (think I've jumped the timing belt) have some welding work done (an MX5 with rust? Never!) and then an MOT.
All things being equal this means the beastie could/should/will be on the road shortly, albeit with narrow wheels.
16 Jan 2014, 9:52pm
Good luck. It cam't be anything too bad on the engine front. It will only be a sensor fault I'm sure. Did you get your arches and covers OK?
16 Jan 2014, 11:40pm
Arches and covers arrived safely thanks. Shall look to fit them once the garage has finished with the car.
19 Jan 2014, 10:28am
My car has been away since Friday and I'm completely lost. I didn't realise how much time I was spending in the garage and now I don't know what to do with myself :becky:
19 Jan 2014, 7:05pm
It's like a drug isn't it! :doh:
