Mr Bonds Build (Car noob)
24 Mar 2014, 1:12pm
Are you planning to add doors? If not, those sketched side windows might mean some walkways up the rear deck in order to get in.
Sorry, I should also have said, looking good!
24 Mar 2014, 9:30pm
Like the idea of doors but will make lift out or hinge side screen
24 Mar 2014, 10:21pm
CarNoob - Your car is coming together nicely. :cool:
Good luck with the rest of it, Paul. :)
Does the boot "lip" have / need a drain, or does it simply seal water tight?
27 Mar 2014, 11:51am
Hopefully watertight but I may add a drain.
27 Mar 2014, 11:57am
Hole for the speaker
7 Apr 2014, 4:48pm
bit the bullit for the rear lights by cutting holes so the sit flush
Filled in with ply a the rear and glassed in
8 Apr 2014, 6:45am
Another nice touch. :cool:
9 Apr 2014, 10:30am
I Keep chipping away!
As I have big feet I decided to alter the gearbox tunnel
9 Apr 2014, 10:35am
And a compartment for the bond switches
9 Apr 2014, 10:39am
Radio purchased and downloaded all the bond tunes for USB stick
24 Apr 2014, 8:34am
finally found the fastners i wanted only took 8 months
ebay buy under £10 wish I bought them earlier
small push fastener
24 Apr 2014, 11:47am
Those fasteners look ideal! Could you post a link to the suppliers please?
24 Apr 2014, 1:21pm
Tel: 01803 868677 Fax: 01803 868678
Email: [email]sales@specialty-fasteners.co.uk[/email]
push fastener
24 Apr 2014, 2:58pm
Many, many thanks. THat site has all the stuff I've been looking for :biggrin:
24 Apr 2014, 6:13pm
CarNoob - I also picked up a similar stepped drill bit set from ebay and have almost worn them out. :rolleyes:
Those push fasteners look good. :cool:
Are they self tapping, or do you need to bond them to the body work / boot lid?
25 Apr 2014, 6:35am
Hi Paul the top one has a retaining clip the bottom one a nut but I may bond it in. It only took 8 months to finally find a small fastener but I was sure they were out there if I kept looking:::whoo::whoo::whoo:
1 May 2014, 9:28am
top of wings seem a little weak
added three layers of chopped matting
Also had the SU carb needle sleeve stuck removed and cleaned
23 May 2014, 9:03am
After fitting lights position was not symmetrical 1.5 cm lower and 1.5 to the right. I could have glassed the back and recut the hole but it kicked in to the left, so out came the cutting disc and moved position. another problem solved.
Also recessed front indicators idecided to go for clear for the front I think they look better this picture is befor I moved the left headlight position
23 May 2014, 9:09am
Looks tidy.
23 May 2014, 2:50pm
CarNoob - The view from the front looks very good. :cool:
Is it my eyesight, or has your car gained an extra hump recently?
3 Jun 2014, 8:03am
rear boot carpet
yes I made a new hump about 12 months ago. It will be removable.
Tried out sowing skills and borrow over locking machine for boot carpet
view from inside boot with access panel
5 Jun 2014, 8:57am
Centre console is now ready for primer I am going to cover in leather with stainless steel dividers so it's easy to remove
5 Jun 2014, 11:46am
I've just been catching up on your build and it's looking very tidy!
Out of interest, what is the chrome handbrake lever that you're using? Is it one of the Lokar ones?
11 Jun 2014, 8:59am
Europa spares ltd
HBL001 hand brake 11" chrome
