Peepsy's MX250
19 Jan 2013, 4:50pm
Thanks for Pic's. Its the blue for me. I think the green for seanick as he is a Nautical leaning. :fish2:
21 Jan 2013, 9:23pm
Ready for the spring Rog? :high5:
3 Feb 2013, 9:17am
:rain: Any Idea when the spring starts :rain:
3 Feb 2013, 10:20am
No idea when it starts, it may never the way the planet is going. But you do have a lovely garage and a car with a roof......:smash:
20 Feb 2013, 8:03am
Bonnet
have just moved steering fluid resevoir to allow my bonnet hinges to fit. Have use 10mm copper to fabricate a new cooling pipe, rubber pipes just trimmed back.[IMG][/IMG]
20 Feb 2013, 8:08am
Rear Arches
Because I have 17 inch wheels, and the rear arches have been enlarged. My rear vents are quite close to inner wheel arch. Mesh didnt cover enough so have made some covers up. [IMG][/IMG][IMG][IMG][/IMG][/IMG]
20 Feb 2013, 7:47pm
Cooling or connecting pipe? Nice vent trim, sort of bling bling trim! You seem to have lots of room on your arches now. Are you going to fit lower springs?
20 Feb 2013, 9:06pm
The fillers on the rear vents arn't to shiney ! hopefully will look ok.The power steering pump has a return pipe that runs behind the radiator and back to the resevoir to cool the fluid. It was badly corroded anyway . The picture is a bit misleading as car is up on stands at moment. If i make it any lower i wont be able to get out the bloody thing. I have to make good the lower edge of the sills where it has been damaged ! a few bendy bits .Then some Acid 8 a couple of coats of primer filler and off we go with the sand and filler shuffle.
25 May 2013, 9:30am
Peepsy wrote:
Hey Chris
The back is ok. This idea about working for a living is highly over rated. Takes up to much time.:amen:
Don't do what I did and stop doing your exercises after a 6ish months, my back was fine for a year or so, so stopped doing them... now 3 years on it aches most days and "goes" every so often so it's hard to get a full days work done on the car or house.
But I did have 2 discs done and still have one thats squished that they couldn't operate on
Chris
27 May 2013, 6:25pm
Second that, keep up the exercises. Touch wood while I get some discomfort it all clicks back.
8 Jun 2013, 8:34am
Tribute aches and pains group
Perhaps we need a thread to share our aches and pains. My back, touch wood is pretty good at the moment but i am very careful when doing any work. It is something you have to live with. So when some one says look after your back !
Take notice , because its a life changer.
Thanks for the kind words guys, I havent figured how to carry the zimmer in the 250 yet maybe boot rack !!
:eusa_boohoo:
30 Dec 2013, 9:18pm
Peepsy,
I have for the first time seen your thread, you have a lovely car there!
I REALLY like your exhaust idea, first rate, also the wiper bits are impressive too.
I am building a jag type thing at the moment, and I may well copy your wiper bits!
20 Jan 2014, 9:08am
Hi Scottie
strangely i have just been looking through your build.sorry didn't reply to your post.Haven't been on for a while other distractions. Your build and blogs are excellent, they really get across the frustrations and joys of these projects ( note frustrations first) Top job. Will keep an eye on you now . I have 5 litres of silver paint in my garage and if i can build up enough nerve i will be spraying mine soon.
20 Jan 2014, 10:44am
Brilliant, I'll look forward to seeing it.
I was thinking the other day, all the bits I will be putting in my interior, like that divider thing, transmission tunnel seats etc. there won't be much room left for getting in and out, what with the daft little doors!
30 Jan 2014, 7:53am
Nearly ready to paint
Have finally put the beast back together. If you remove the doors leave the hinges on the car they are a pig to adjust. I did mark original positions, but sprayed over them. Another tip don't use cheap masking tape. It leaves behind lots of glue which is difficult to remove, proper auto tape is better and not much more.Have given another rub with 1200 grit so now need to wash and panel wipe before the paint goes on next week.
3 Feb 2014, 7:15am
I sprayed my first car
Washed/ panel wiped. and tac ragged befor I finally put some paint on the car. The silver cellulose went on a treat. I gave her 5 coats of 50:50 and then a 60:40 down to a 70:30 thinners to paint about 15 mins between coats. With the last coats you need to get a wet look and carry that over the car. It gives a nice shine when dry.
Having never sprayed before, and engrossed in my painting, my water trap filled up. As i was just giving the bonnet another coat my gun stuttered and coughed water and paint all over. I will need to flatten and redo. so check your water trap before and during your spraying.
Having to get down on hands and knees to paint under car, I managed to pick up some grit from the floor on the hose, which as i moved my hand down while painting the roof kindly dropped on to my boot lid. Flatten and redo. so keep your hose clean. good advice for any boy.
Also when you fill your gun up especially with very thin paint it doesn't leek form the breather on top of the cup. if the gun is full try to start low down the car and use up some paint before leaning over the roof/ bonnet etc as it could drip.
I was really pleased with the finish, without the few mistakes it would have been a really good job.
3 Feb 2014, 8:31am
Looks crackin'.:high5:
Get some more paint in and I will bring mine down.
Clear coat over the top?
3 Feb 2014, 8:38am
Looking very nice. I also used silver cellulose for my first attempt at spraying and I'd say it's an inspired choice - it's very forgiving and still looks good even if you don't get it on perfectly.
Keep up the good work. :)
3 Feb 2014, 10:10am
Looks great, sorry to hear about the minor problems, hopefully we can learn from your mistakes!
How much paint did you start with, to be able to do 5 coats Peeps?
3 Feb 2014, 9:31pm
Paint
I bought 5 litre's of unthinned metallic silver and 5 litre's of anti bloom thinners, which mixed together makes 10 litre's of paint. If you go for cellulose be careful as a lot is sold as RFU, ready for use so is already thinned.To give my car 5 coats would take about 3 litres of paint 3 litre's of thinners plus you want a bit spare. I am glad I bought 5 litre's ! I will give the bad bits a flatten down and respray. should match ?:icon_redface:
3 Feb 2014, 9:39pm
Well done Roger, looks brilliant in silver, a brave move for your first paint job :eusa_clap:
Are you coming up our way when it's back together?
3 Feb 2014, 9:49pm
I would be pleased to just get it out the garage ! never say never but i better sort a towing eye out first ! oh and a bonnet catch.
