Good afternoon new exhaust fitted today , makes a wonderful sound and really pleased with the look , all work done by Cybox Exhausts of Brombrough (on the Wirral) 0151 343 0330 , ask for Mark or Gerry .
Morning all , first photo is of my newly made (courtesy of a length of steel rod from B&Q) boot prop , certainly not the most exciting item ever fitted to a SWB but does work a treat .
Final photo is the boot floor! for what ever reason and it it a long time ago i binned all the original Z3 boot trim , so after boarding out the base then covering with carpet this is what it looks like , i guess the battery will know fail!!!!! Geoff .
Good evening many moons ago one of my first tasks after my car was built was to install a headlining , before doing so i decided to glue sound deadening to the roof then glue the headlining to that (my theory was the sound deadening would help to dull the noise of sitting in a fibre-glass box) . The glue was the correct sort for headlining , well it is not an easy task as the glue sticks (like s*** ) on contact , all was well and it looked good untill the past couple of weeks where we have had strong sunlight and high temperatures , my car sits outside and with it being a dark colour the interior does get hot . What has happened is the glue between the roof and the sound deadening goes soft and the weight of the sound deadening overcomes the stiction , not good so today it has been pulled off and all things being equal tomorrow a new section of headlining will be stuck back but with no sound deadening , Geoff .
I've stuck various parts with the spray glue used for carpets, but this one stated high temp glue, don't know if you've seen it, (available on e bay)
Pops
Morning thank you for the replies , the glue i used was the "high temp stuff" but i can only assume the weight of the sound deadening was to much for it . Have been to Martrim in Sandbach this morning and bought more glue "not the spray on type" so will try that , have decided not to use any more sound deadening as the exhaust is now changed!
If anybody is looking for a supplier of the alloy strip that runs along the top of the door have a look at the following http://www.blackburnsmetals.com/products-aluminium-mouldings-cope.html , many thanks to Bob(Hurnleft) for the info , Geoff .
IMHO there are 2 issues with spray on glue 1. It doesn't give as thick a coating, so doesn't glue as well. 2. It atomises when sprayed, so more of a hazzard?
Maybe, but any of these contact glues are dangerous inside a car! Whilst glueing the headlining to my Quantum (no glazing fitted at the time) I was still almost overcome by the fumes and just got out of the garage in time, a confined space and contact adhesive is dodgy.
[Quote] Maybe, but any of these contact glues are dangerous inside a car! Whilst glueing the headlining to my Quantum (no glazing fitted at the time) I was still almost overcome by the fumes and just got out of the garage in time, a confined space and contact adhesive is dodgy. [Quote] .
No garage for me so should be safe enough , although anybody walking past on the pavement may have to look out! Geoff .
Good afternoon i decided to alter the door cards i had made by adding a pocket and by changing the door handles for something differant (as fitted to a Alfa 105)!
Not there was anything wrong with the old door handles!
Original door card .
New Door card .
The size/length of the pocket was dictated by the amount of leather i had left from the original work , the cost of another half skin to make two longer pockets was not realistic .
The two plastic covers around the door pulls are standard Z3 sprayed up the body colour they are stuck on but i can not decide whether to keep them ,Geoff .
Morning Andy , you really are a flash bugger Geoff .
Good morning Geoff, many thanks!!!!! Hope you are getting the most out of the car with the weather now starting to improve a little? all the small ( and bigger) touches you are doing really make the difference.
Good evening , i decided it was time for a change ref my wheels and tyres , so i bought a set of 15" BMW steel wheels from an old boy! in Norfolk , would guess most people on here will recognize them , what i will say is that if anybody want a load of small holes accurately drilled in steel "Mr Towed" is your man . Bought set of 4 195 65 15 Avon tyres from Blackcircles approx £170 fitted at ATS , slightly larger in circumference and quieter than the P6000`s that were on the Minilites
