Spent today tackling another of those annoying little jobs that eat up the time, in this case fitting bits 'n' bobs to the dash.
These included the hazard lights switch, the 12v socket, the heater fan switch and the heater control knob.
With the heater control the original plan was to re-use the Vitesse ratchet stop heater cable, but that proved to be a bit too stiff for my liking, even after lathering it in grease.
So, the broken choke cable that came with my donor was dug out, shortened and adapted to do the job instead. It doesn't have the right logo on the knob, but you can't see it anyway as it's angled downwards quite a bit.
The reason for that is that I've tucked all these extraneous switches under the curve of the dash so they're almost out of view from outside the car.
The idea is to keep the interior as minimalistic as possible and avoid the 'kit car that crashed through Halfords Chav department' look (no offence meant to anyone who actually
likes loads and loads of gauges and switches, but I just think less is more).
Like everything else Sammio it wasn't exactly a straightforward job to fit. It looked like it should be - cut holes in dash and bulkhead, push cable through, connect to the London taxi heater valve and the job's done in ten minutes - which was fine until I pulled the knob and the dashboard flexed enough for it to crack.
Solution was to make a stabilising bracket out of one of the Vitesse bonnet stays and bolt it to the inner frame. It took three hours just to drill and tap a suitable hole in the frame due to having to do everything through the hole for the tachometer, sort of Sammio keyhole surgery.
Here's the pitiful result of nigh on a full day's work (the two push fit items aren't fully in yet as they have plastic 'barbs' that're likely to break off if I keep pulling the in and out) -
Should be able to get a bit more done tomorrow, weather permitting...
