mikmiglia wrote:
Well paul, well done for finding them pics. You will see what im up too from next week with pics, keep and eye out.
Looking forward to the update Mike...
Now, the best thing about Sammio building imho is the complete lack of rules. You may find this surprising given what I do for a living, but, in my working life I've always been one to view rules as a flexible concept that're there to be stretched to the limit if not actually broken.
So, when a challenge manifests itself, rather than consult the comprehensive build manual for the 'right' way of tackling it as you would if you'd bought a Caterham or Westfield, you invariably have to start a lateral thinking process instead. And nobody can tell you you've got it wrong, with the possible exception of M*cha, who no-one listens to anyway.
And the latest challenge is the fly-screen. I don't know if anyone's noticed, but my perspex fly-screen hasn't been attached properly since I bonded in the Porsche 550 Spyder dashboard I bought from Gary J about a hundred years ago. Well, last summer.
The problem is that my fancy dashboard has completely blocked access to the underside of the body at each end of the 'screen frame. I can get at all the other fasteners across the middle, but the very ends are totally inaccessable. This isn't the best illustration of the problem, but trust me, you can't get at the underside at all.
As I don't particularly want to cut access panels into the sides of the dashboard, some type of blind fastener was needed.
Whilst sitting on the toilet, netbook on knees, pondering the not inconsiderable expense and pitfalls of having to buy a decent 'rivnut' tool - looking at a few forums it seems they quickly get loose if attached to fibreglass - it suddenly struck me that I might actually be closer to a solution than I could've possibly imagined.
You see, a year or so ago I replaced the broken toilet seat in our downstairs 'cloakroom' (posh talk for spare shi**er) with a fancy, soft closing one that came with ingenious, shake-proof fasteners called 'well nuts'. If you're not familiar with these, they consist of thick rubber tube with a brass nut set in one end and a matching bolt. You push the tube into a hole that's near enough an interference fit (hole too small for object going in), put the bolt in, and when you tighten it up it pulls the rubber tube up into a doughnut shape under the panel and jams it in place.
And a quick ebay search revealed that for the princely sum of less than six pounds I could buy the same toilet seat technology on a smaller scale, M6 in my case, and solve the problem without having to cut access panels in my car.
So here it is, straight from bog to car, a very effective way of fitting the screen without requiring access to both the inside and outside of the body shell.
Next time we'll be looking at bonnet vents hopefully...
