Eventually the rain stopped, although the dark clouds remained, so I decided to take a chance and not start packing up for the day.
So I slotted the arches together and used the fixing bolts to locate the corresponding holes in both layers.
You can also see that I clamped the front end down to make it easier to carry.
Initially I left these two spacers on the rear of the chassis, but in the end I will only be using the rubber layer.
( This helps level the arches as the hand brake panel is "lifted" over the frame + floor. )
As it was, it took my wife and my two daughters to help carry this thing onto the chassis.
Then I put a couple of bolts on each side to hold the frame to the bulkhead.
( I did spray some stone guard on both sides of these brackets. )
Then I did up the four chassis bolts.
With the bolts tightened the hand brake panel does sit flush with the floor.
The seat belt bolts also go in, although one hole feels like it needs the thread re-tapping.
I am currently in two minds about what to do with this section as the bolts will clearly hold the hand brake panel in place.
So should I run a few lines of welding down the edges and cover it in fibreglass filler for a final "seal"?
Or should I run a length of bonding paste along the edges and smooth that down when it has set?
( As I do have a big tin of it and haven't used it before, so this would be an excuse to practise. )
At the back of the frame, the arches sit centrally over the lowering block studs.
Which just leave the "feet" for the rear frame to sort out.
By chance, the driver's side is at the right height and the foot just needs to be welded on.
The frame "leg" had been left a little longer on the passenger side.
But nothing a quick trim couldn't fix.
Then I cut & tidied up the feet.
So now both feet will now fit nicely in position like so.
I will do the welding another day.
The only other thing I want to do is an two extra brackets (one on each side).
I need to make some templates, but I should be able to join the frame to the arches by re-using an original seat belt mounting point.
One thing I noticed is that one of the fixing bolts is at an angle rather than perpendicular.
So I will have to sort that out at some point.
But taking that photo did remind me to take my angle grinder to all four bolts and trim them a bit.
Which will at least speed up the bolting / unbolting process.
Finally with the body shell back on...
I noticed another area of work that I need to think about / fix.
The car isn't going to be very water tight unless I insert a floor of some sort between the bulkhead and the body shell.
At least with all the big parts in one place (for now) the drive is looking tidy.
Note:
I forgot to put the heavy duty tarpaulin under the car cover to help keep the water out of the floors.
Despite the set backs, I know I am getting closer to fixing this stuff onto the chassis for good.
I also know that there will be a lot of small, time consuming, jobs to finish off before that happens.
So I will try to remain positive and keep chipping away and I'm glad I stuck with it today rather than simply give up.
Although Father's Day will be a relaxing one, so it will be Monday at the earliest before I can carry on.
Until next time, take care, Paul
, there are people all over the world who have thrown the towel in and not finished their kit car builds and some of them had massive garages with endless cash for parts and tools and were building giant maccano kits with everything done for them. looking forward to the next instalment buddy.
