Forum Home
Mad Chat
General chatter
K1 Attack
K1 Attack
High Voltage Systems (kinda) Working
https://youtu.be/Zhh1q7wurts
Problems, problems, and more Problems
We find brake lines leaking. We find the steering rack leaking. The controller will not boot up. And we might need a new radiator. Sigh...
https://youtu.be/V4HHwKF0SJc
You're making good progress. Are those connectors in the steering rack just plastic plugs ? If they are then replace them with metal ones or fit an oil cooler, that's probably what the ports are for.
I can't help you with electrics, I can only think in terms of simple DC circuits !
Yes, I think they are just plastic plugs. I will see if I can take out the steering rack and get things fitted up properly.
Fixing some of those pesky problems
https://youtu.be/7xYo8Ymqv2g
Is my car broken?
https://youtu.be/_uV-PehRB1U
Controller will not talk to the inverter
Controller will still not talk to the inverter.
Moving on to the center console
https://youtu.be/7W6LrKNYnko
Trying my first fiberglass panel
https://youtu.be/dBkJFETWvYE
Trying another fiberglass panel
https://youtu.be/mmix6kYmSQw
Still waiting on the inverter fix. Starting on the car stereo.
https://youtu.be/7kTLJM0e_AI
Tackling some DIY electrical
https://youtu.be/LOKl0URmPOk
Working on the door mechanical locks
https://youtu.be/vqi89gxxOdc
My first try at car interior vinyl
https://youtu.be/_OCPffCo468
Finishing up some car interior vinyl
https://youtu.be/vB3MXVwUVdw
Love this project! Keep the updates coming!!!
Thanks Friend! Will Do!
Finishing up the door locks
https://youtu.be/bK1qvC2AVK4
Installing the inverter board
https://youtu.be/Mv3h_RiuEdo
Got things to a point where I could drive again.
Still figuring out pack 2
https://youtu.be/TZ4eUEkqG18
Did a full systems check including 0-60
https://youtu.be/dbg0e4WooAo
Finished up a lot of the electrical
https://youtu.be/yBmBVqncZeQ
Still having controller issues, but switching gears to some body work.
https://youtu.be/NNWuZk-8BbE
On to installing the lambo doors
https://youtu.be/8iFzRmVjtfc
