Sammio rat rod pick-up
16 Aug 2019, 7:42pm
Also, I love it.
20 Oct 2019, 3:34pm
The rear tub has now been lined with T&G .
The T&G planks are pressure treated but I'm not sure weather to leave the wood as it is, stain it or varnish it. :eusa_think:
I also freed off the clutch plate, freed off the front brakes and fitted new rear brakes.
20 Oct 2019, 3:59pm
I'd coat them in epoxy or simply varnish them.
Looking really good! Well done.
20 Oct 2019, 5:02pm
Rustins plasticote after staining them. 2pack and as hard as nails, easy to put on as well. Satin or gloss finish.
20 Oct 2019, 5:13pm
Never learned of that. Sounds good to me. Much easier than epoxy.
5 Nov 2019, 5:27pm
Fitted hinges to the bonnet.
Also fitted the bonnet side panels.
Both side panels need some sort of lip to cover the bottom edge but for now good enough for the MOT tester.
:biggrin::biggrin:
17 Nov 2019, 7:29am
Mike – Do you have a final colour in mind for this pick up?
17 Nov 2019, 7:59pm
I have 2 colours in mind. :noidea:
Grey with black trim.
Rust with black trim.
I'll decide when it's complete
16 Dec 2019, 7:13pm
I'v been looking for a pair of Morris Minor door tops to convert to fit the doors giving me an opening window.
But having been unsuccessful I purchased some thin steel channel and made a pair.
I also added an in-fill to the door top surrounds
I re-enforced the door bottom which not only helped stop the fiberglass door flexing but also gave me some where to fit the window winder and door latch.
On the mechanical side we have now got it running better and freed off the clutch so the truck will now move under it's own power!
No more pushing about :dance:
28 Dec 2019, 6:31pm
Spent so time on the interior of the pick-up ready for the final fitting of the seats and belts.
25 Jan 2020, 6:30pm
The front of the truck was always to high.
So we replaced the front coil-over shocks with some smaller ones we had left over from the front of the "D" type.
This shows the difference, left has the new smaller coil-over shock fitted.
Again.:icon_cool:
I think it's down about 50mm, just hope the front will clear the local speed humps!!!!:bounce:
10 Feb 2020, 6:14pm
I'v been trying to sort out a safe way to fit the visor.
I finally settled on some exhaust bobbins which allow the air flow to pass under the visor .
I'll tidy the fitting up later. :icon_wink:
10 Feb 2020, 7:47pm
I like that!
15 Feb 2020, 8:48pm
We wanted to get the truck all one colour to see what it looks like so we used primer.
Still loads of work to do on the rest of the bodywork but the single colour shows the potential. :rockon:
23 Feb 2020, 11:04am
Mike – Getting the truck in one colour does make a big difference. :cool:
Also, good to see you are already making use of the pickup bed. :icon_wink:
28 Mar 2021, 6:36pm
Finally got it through it's MOT! :dance:
Still needs a little sorting but it seems to drives OK.
28 Mar 2021, 8:40pm
Congrats!
29 Mar 2021, 9:24pm
Respect!
2 Jun 2021, 1:51pm
Can't stop playing with it!!
Fitted a heater :biggrin:
The blower to the cab is brilliant but the de-mist sucks! . :rant:
You-Tube test drive !!
https://www.youtube.com/watch?v=iOUFmqEQT74
Now correctly registered with DVLA as Reliant - Pick-up - 2 seats - Grey !
2 Jun 2021, 2:04pm
Fantastic!
