Formosa 120 gr build
19 Aug 2017, 7:08pm
I have spent just over a day improving the hinges on the car ....Poor old Jeff has been trying to get the gaps really nice on a door that kept changing its height due to over engineered door frames and under engineered hinges !!
I tried to upload a picture but it is huge ...so I will try again tomorrow ...
The hinges are now angle iron style instead of flat plate , they have been welded to the frame in extra places where they touch , have been braced and tied together with a studded 8mm bar inside a crush tube and the oil lite bearings and 8mm pins have been replaced with roller bearings in machined housings with 6mm centres and some hole reducer inserts added to the frame so I can use 6mm bolts and nylocs as the hinge pins ...it is so much better , supports itself and opens smoothly and repeatedly without trying to re-adjust itself !
20 Aug 2017, 12:33pm
Nice one
21 Aug 2017, 9:51am
Gary - looking really good.
How much for 2 humps.......and don't be vulgar. They look like they would save me a lot of time.
21 Aug 2017, 7:32pm
Excuse my ignorance ...Price for 2 humps separately ? or a Formosa body with 2 humps ?
22 Aug 2017, 5:36am
Gary - My guess would be for two humps separately to be grafted onto this.
Oxford - Come on, I've been waiting all Summer for an update on your build tread. :rolleyes:
:icon_wink:
22 Aug 2017, 1:13pm
Yup, Paul, you are correct. And, there are a changes coming-up for Oxford1360. Once they are sorted I should have a good-sized garage close to the house from ~October. Progress should be much swifter from then on......
Gary, apologies for my lack of clarity. If you could let me have a price for two of the humps that you have supplied for the passenger above.
Thank you.
22 Aug 2017, 8:31pm
micky1mo wrote:
Them hinges look the dogs do-da's but what sort of door handles and locks are you going to fit?
Thank you ...it has Landrover type slam latches and a modified Landrover dovetail catch ...I have reduced the latch area to minimize rattle .
22 Aug 2017, 8:38pm
oxford1360 wrote:
Apologies for my lack of clarity. If you could let me have a price for two of the humps that you have supplied for the passenger above.
Thank you.
Oxford , if you wanted 2 humps supplied separately with the same excess around them as the loose one in the picture , giving you plenty of material to 'graft' ...a 6 oz. layup and finished in grey gelcoat ......then we would be looking at £140 the pair including well wrapped postage via parcelforce.
22 Aug 2017, 8:44pm
Glad to hear it ..your build is one of my favourites and I am looking forward to seeing the end result ....
23 Aug 2017, 5:14pm
Interesting idea any photos?
I tried a similar arrangement on the G-46 with-out success. The doors never felt "firm" and would open with the body flexing. I ended up using a pair of small bear-catches from CAR BUILDER SOLUTIONS.
They were cheap and worked well. :icon_idea:
23 Aug 2017, 8:07pm
I can take some pics when young Mr. Jeff has finished painting it as latches are off at present .....they are pretty firm ...the doors don't flex much , the new uber hinges have tightened it up ......
Bear claws are really good , and you can get those door drop latch things too , to locate a door and hold it ...the ones convertible cars and lorries tend to use on the rear bodies where doors flex... this sort of thing ....
They are about £5 or 6 each from memory ...
27 Aug 2017, 7:16pm
V5c Document back from DVLA a few days ago ...all present and correct . Triumph Formosa Sports in red ..no inspection required , so Happy Days !
27 Aug 2017, 7:40pm
[img]https://www.imageupload.co.uk/images/2017/08/27/frm.jpg[/img
27 Aug 2017, 7:46pm
Jeff sent me some pictures today ...I know Graham has seen the full set , so thought I would put a couple on here ...
The car has been sprayed in Polyester reface ...this will be sanded back and then the car will be treated to some 2 pack high build primer and sanded again ...
Jeff also masked the whole of the underneath of the car , engine bay , floors etc...so no overspray should make its way onto the restored chassis ...
28 Aug 2017, 5:48pm
Car looks good. :cool:
Although one of the photos may have accidentally broken the forums nudity rules! :eek:
I'm sure all the prep work Jeff does will result in a great finish.
8 Sep 2017, 9:29pm
I think Gary is away this weekend at Goodwood.
The car has had a fair few hours put in to it this week and is now in colour.
Graham decided against the Rosso blood red colour in the end and went for a more classic looking colour, the same one used on my car, Rosso Barchetta, I think it suits the car very well.
Some pics for those interested.
I do have pics of the painted car but they are on my phone, I will get some better ones tomorrow and bung them up here.
8 Sep 2017, 9:38pm
Ok these may work.
8 Sep 2017, 9:41pm
The car will be left for a few days to harden off,
Then it will have a day spent on it flatting and polishing, the only paint work left to do is the rear bulkhead in Silver, and the head lamp bowls also in Silver.
8 Sep 2017, 11:05pm
Fantastic! Looks super.
9 Sep 2017, 6:43am
Wow
9 Sep 2017, 8:10am
Very pretty, nice colour choice . :eusa_clap::eusa_clap:
