Up-dating my McCoy
30 Dec 2015, 10:30pm
Thanks Mr Jones, its always a worry that it won't break out of the plug, first sheet of glass on now and hopefully the edges stay put...
1 Jan 2016, 5:04pm
Bonnet continued
Right the mould has all been glassed and support rails fitted….
Once cured the plug and mould was lowered to meet the car……
The profile looks good and then…….
Aaaaarrrggghhhhh…. I need a break
3 Jan 2016, 8:30pm
Bonnet continued
Right worse nightmare ever but needs to be tackled, the plug didn’t release from the mould, well after a rant and a day off I took in the job of trying to recover the mould with limited damage, I ripped off the supports and then scored the surface of the plug, then put some water in and hoped it would soak in and give me a chance..
After an hour and a lot of scraping out the MDF I thought this is not working too well…
After another 2 hours I decided to try something else, scrape it out dry…
2 hours later that got most of it out…
Now for the steamer…..
Another hour or so…..
And another…
Most of it out and now to think about the paint, into work tomorrow to ask my welder for the details of the paint stripping spray he has recently has had good results from…… No more messing with nitromors…
3 Jan 2016, 9:09pm
Oh Noooooo! Sorry to hear of the pain you are going through - it looked so good too. Fingers crossed it can be salvaged.
3 Jan 2016, 10:27pm
Thanks, I will salvage it, it has taken an age to get this far with the bonnet and I will not let this get me down, if I can clean the paint off it should be not too much work to flatten back the gel coat and sort the minor repairs, I think the spray on mould release may have reacted to the paint and caused it not to do its job, maybe the paint was too fresh but hey ho, life not simple and I am no expert when it comes to fibreglass, you live and learn ....
4 Jan 2016, 9:30am
pompeyal - Sorry to read what a nightmare your bonnet mould has turned out to be. :icon_sad:
Unfortunately, I don't have any experience of making "proper" moulds.
( So my use of parcel tape as a release agent is not relevant here. )
However, Viatron posted on his build that he applied 4 coats of this release wax on his moulds.
( Apparently he has used it for years and it always works well. )
Obviously, not much help in this case, but make help if you have other stuff to make.
4 Jan 2016, 10:56am
Thanks Paul, I still have to make the bonnet from the mould so thats the way I will be going for that, couldn't waste another whole day digging out again....
4 Jan 2016, 6:43pm
Six coats of mold release wax and for belt & suspenders, spray it with a couple of coats of PVA. Best for a plug for the first release.
4 Jan 2016, 7:14pm
Why the PVA surely thats an adhesive?
4 Jan 2016, 7:17pm
I believe you use the PVA first to seal the surface of the mould and when dry leaves a nice shiny surface
4 Jan 2016, 7:19pm
Prior to adding the wax?
4 Jan 2016, 7:39pm
PVA = Polyvinyl Alcohol is a release agent.
Use it after waxing the mold and letting the wax gas-off for about an hour. The PVA is water soluble so easy to clean up.
Check with any fiberglass supply place and they'll have it.
Cheap insurance to ensure a part or mold does not "stick"
Hate it when that happens. I just now finished spraying PVA on a new roof duct mold for an RCR Superlite Coupe. (USA). I have the only mold for that part and the manufacturer gave permission to make them for customers should they desire it. Been playing with fiberglass since the early 1960's. Simply a retired old broke guy having fun!
5 Jan 2016, 10:46am
Everyday is a school day - that makes a lot more sense than using PVA glue then. :biggrin1:
5 Jan 2016, 9:40pm
Bonnet continued
Right tried out a few things tonight just to see how it went, VHT Strip Fast certainly lifts the paint into a gooey mess and I didn’t leave it on long then scraped it of quickly, this seems to not have attacked the glass underneath, mind you it wasn’t on long. Cleaned back with spray gun cleaner, “Neogene”, can’t leave that on to long either, that will attack the glass, next put down some Nitromors and a spray of VHT Strip Fast over the top, left for a minute or two then with a soft brush rubbed it around then scraped of the mess, that seemed to work as well so I think about ten hours of stripping and sanding back I may have a workable mould, I will just have to see….
9 Jan 2016, 3:50pm
Bonnet continued
Tried out this stuff, worked a treat on this fresh paint but not sure how it would cope with old car paint finishes, will be trying that out later..
I went round covering 300mm squares and leaving for an hour
I continued this until I had removed the majority of the paint, I didn’t try to do too much at a time because it does create quite a mess
I started sanding back the imperfections but forgot to take a picture, shall do that later, I am sure with a bit I work I can recover the mould so I though I would reinforce the edges by bonding on a flange… First I covered around the bonnet opening with cling film and placed the mould over...
Then I cut some fibreglass roving woven tape into lengths and positioned them around the mould…
Then mixed up some resin and applied it to the tape
I will now leave that until it starts to set off then cut some strips of fibreglass mat and do the same.
10 Jan 2016, 12:39pm
Bonnet continued
Well the strips of glass have been added and then set with resin, once set I will trim around the flange and get on with polishing back the inside of the mould
Removed the mould from the car and now you can see that I have some polishing to do along with some minor repairs,,
11 Jan 2016, 10:07pm
After all your hard work, I really hope the new bonnet turns out the way you want it. :pray:
11 Jan 2016, 10:09pm
From where that mould was a week ago you must be pleased and relieved. Going to be worth it by the looks of it.
12 Jan 2016, 11:17am
Thanks guys, hopefully I sould have it sorted at the weekend fingers crossed...
14 Jan 2016, 5:36pm
Bonnet continued
Done a few bits during the week for the bonnet, made a pair of bonnet hinges with brackets and a latch pin and bracket, just need to get the bonnet sorted out……
4 Feb 2016, 2:31pm
I love those hinges. How's the bonnet coming along?
6 Feb 2016, 10:31pm
Thanks Mr Jones, to be honest I haven't touched the car for a month, the son in law collared me to build his workshop with him and its been more like for him, hope to have it finished tomorrow then I will get on and repair the mould...
22 Feb 2016, 8:18pm
Bonnet continued
Well it’s been a while and a slight stall on the project but I am now back on line, I started assessing the damage to the mould and got ready for the repairs, the main areas for concern were the damaged edges but started filling the imperfections with filler putty
Before going too far I had to pay a visit to my resin supplier and had a chat about what I had done so far and he warned me against using filler because there would be a good chance the gel coat would stick to it and recommended that I should use gel coat for the repairs, rub that back and then flat and wax at least five coats, then apply PVA,…. Hmm more work then so back home and start again..
First things then, a fresh coat of gel coat
Then built a dam around the edges with plasticine where they had been damaged and in filled with gel coat
After that removed the dams and cleaned, now to rub it all back flat…
Then 6 coats of wax, one for luck…
Then the PVA application..
And now I have committed to the bonnet, first coat of gel…everything has now been suitably crossed and in hope all goes well
22 Feb 2016, 10:14pm
Nice to see you back, thought son in law got you building a house as well as a workshop!! Lol. Fingers crossed here too, good luck.
23 Feb 2016, 8:50am
You know when you get asked to help and then end up doing it with a little help from the person who asked, that was the workshop build, anyway I am back underway and thanks....:icon_wink:
