Berlinetta Restoration 2015
28 Feb 2015, 9:00am
The Answer:
Apparently it's a Honda 500.
No V5 but may not have been certified as destroyed.
It's very similar to this except it is a salon with an MGB - GT style roof with the third door. Me thinks it could be pretty rare. I may well take a closer look on Monday morning. In some ways it's in quite good condition, despite the body rust. The seats and interior are serviceable.
1 Mar 2015, 12:04am
Started the engine today. No real issues, it was a bit reluctant to run well but with no exhaust or air cleaners, it was expecting a lot. I fitted some air filters after we recorded the video and it ran a lot better. With an exhaust it should be perfect. :icon_cool:
https://www.youtube.com/watch?v=bnX9gi7DKmU&spfreload=10
We went out after dinner to clip up some brake pipes and tidy up some loose ends but somehow one thing led to another, it was after 10:30 pm before we called it a day. We started to make the engine side covers, we will roll the bonnet through the English Wheel tomorrow, another milestone. I am not going to form the engine side louvers at this stage, I want to get the panels completed first before I start to make the tooling for the louvers.
1 Mar 2015, 1:56pm
Progress
The end of another month, only one more month to go until Easter.
This is the first car I built, an Austin Seven special when I was about 14, although I had worked on my fathers Alvis's before that.
Made mainly from wood I used an Alvis instrument panel which I made a new dashboard for decorated with brass nails.
Here is the current bar chart as of last night...
For comparison, The progress chart at the end of January...
And at the end of December...
As you can see significant progress in two months. I am confident it will be ready for MOT soon after Easter, baring accidents or unforeseen. Starting the engine yesterday was a big milestone, today I am struck down with a tummy bug, been sick twice but feeling a little better now. I had hoped to be getting on with the engine sides and bonnet today, but not. Michael is tidying up the garage so I can spend next week looking for 'stuff'! LOL
2 Mar 2015, 8:31pm
Congratulations on the engine start. :cool:
It must be great to see how close you are to the finish.
2 Mar 2015, 10:21pm
Thanks Paul, I don't need more days like today!
I welded two silences to the down pipes, one is skew-wiff, I have had to take the manifolds back off, like Michael told me I would because the studs securing the down pipes have almost no threads left. In the process I broke two drills and one tap, in the hole... I smashed it to pieces to get it out.
I drilled one stud out last week and re-tapped the hole but it had been repaired with a hellicoil, and it started to unravel so I had to take it out and re thread for a new insert, fortunately I have an M8 Re-Coil set and some inserts! So I ended up drilling out the remaining 5 studs and tapping them out. Three with new hellicoils, three I managed to salvage the original threads. I have fitted the exhausts back to the manifolds with stainless Cap Screws, I'm not sure it's a wonderful idea but if I loosen them and re-tighten every six months or so they should be OK, even fit new bolts from time to time perhaps? I have used plenty of Copper Slip, so they should stay free, I hope.
I will have to apply some heat to the exhaust in the morning to try to get the silencer pointing more in the right direction. I started the engine after I fitted the first silencers, it's still loud, but not so loud as it was with open exhausts. I may tack some tail pipes onto the silencers to see if that quietens it down any, if not I have a couple more silencers waiting... I got a good deal at the breakers this morning. Five silencers for the price of four, they normally charge a fiver for a silencer, I got five for twenty quid, not sure what I will do with the fifth silencer but I am sure it will come in for something.
The engine sounds fabulous, so responsive, I am sure I am going to enjoy driving it! In fact I did drive it a few inches this afternoon, the clutch is dragging a bit but I am hoping it will improve with use. I have to pump the clutch pedal to engage a gear. My master cylinder is a bit suspect, but it may sort itself gradually.
Will try to get some pix tomorrow, am feeling a lot better after my sickness bug.
3 Mar 2015, 12:47am
while you're in B&Q looking for parrafin:
just made my fourth grille and I must be nearly halfway through the roll :icon_smile:
3 Mar 2015, 7:44am
Thank you, that's a good idea. I rarely go into B&Q since they introduced the self service tills... I will take my son Michael, he seems to like them for some strange reason???
5 Mar 2015, 11:12pm
Un-planned extra task
I never liked the hinges on the Berlinetta. They were ugly and ill-conceived.
Because of the way my new engine side panels worked, I needed to take the side panels back to the front of the doors. That meant cutting out for the hinges. I just couldn't bring myself to do it. I wanted to make concealed hinges. Far neater and more functional. OK the doors won't open to 90º but who needs 90º door opening anyway.
So, rather reluctantly I bit the bullet. I was reluctant because my experience of this type of hinge is limited to say the least. However, I am very pleased about how they have worked out. It has taken me three days to do it, but I think it has been worth the effort. The doors still open to about 60º, which I think is enough, especially given how wide they are.
I used some off-cuts of 2" box section and several cutting disks! The doors are now more adjustable than they were and close more nicely. The channel is drilled and tapped and bolted to the inner panel of the door. I need to fit door check straps to prevent damage to the side panels.
This is what the original hinges look like at the n/s door:
This the 'after' pic with the new side panel in position with the door hung on my new hinges:
This is with the door open to about maximum:
The actual hinge, dismantled:
This is with the hinge in the fully open position with the side panel removed to show the cut out in the hinge:
Perhaps I can get back to the tasks of finishing the fuel supply pipes and making the bonnet now... :rolleyes:
Yesterday evening I had a session on my friends lathe. I made a 'Y' piece union for the fuel pipe, I modded my angle grinder nut so it would grip the 1mm cutting disks properly and I made a threaded insert for my Marlin gear lever knob.
7 Mar 2015, 11:36pm
A brilliant day today, I closed off a few minor tasks and started the bonnet!
I soldered and fitted the fuel union I made on Wednesday. It takes the output from the two fuel pumps and connects them to the main feed to the engine.
The fuel pumps are connected to separate suction tubes, one reaching almost to the bottom of the tank, which will be used as standby and reserve, the other pump's suction tube is shorter by about 30mm and will be regarded as the 'main' pump so it will run out leaving a reserve of about 30mm which should be a useful standby.
Here are a couple of pix of the bonnet, only the off side today, tomorrow I intend to do the near side. I formed the curve and toe gentle radios at the back of the panel on the English wheel with a rubber band on the top wheel. It worked really well although I do have some tracking marks, I think they will blend out as I continue to finish the body. They only show on close examination.
I was concerned about the transition from the flat section at the front of the panel to a 1200mm radius at the back where it sits in the rebate at the front of the scuttle. It seems to have come out perfectly. :icon_biggrin:
8 Mar 2015, 6:42am
Bonnet looks really nice.
The fuel connector thingy has a solid mount and the pipes are not clamped,are you not worried they will crack?
The copper fual lines i made in my hotrod are supported every 5 inch in rubber D-clamps to prevent this..........works well.
Better save as sorry.
René
8 Mar 2015, 9:25am
Thank you most kindly! I am hugely relieved the bonnet is working out. I came across some photographs of a Royale yesterday, this has thrown me into something of a dilemma. The Royale bonnet has a fold down of the panel at the hinge, avoiding having a row of rivets each side of the hinge. However, if I am to benefit from Scotties example, the detail is everything. It makes up for other shortcomings in the build which are impossible to achieve.
I am trying to make the car more like the original1930 Alfa Romeo cars, upon which they were originally (loosely) based, they have nice round head solid rivets along the hinges. They can be seen in many photographs I have of the original cars.
You make a very good point about the fuel pipes. They are unsupported at present, I have been considering how best to support them neatly because the whole fuel pump area is becoming a mess. I had originally tried to keep it simple and neat but with the pumps, pipes, filters and 'stuff' it's lost it's tidy appearance. I may devise a bracket from the side of the tub, or perhaps a longer piece of metal under the pipe. I am now wondering if the solid mounting under the union was such a good idea... I may replace it with a rubber bobbin to de-stress the pipe, or even leave it un-mounted. I had liked the idea of a solid mounting but now realise that will cause the copper pipes to flex, work hardening the metal and possibly leading to a fracture, with potentially catastrophic consequences.
I still have to make the fuel filler connection, another 'unknown' I have yet to decide how I am to achieve that. I didn't like the way it was mounted originally, far too close to the boot lid aperture.
I am considering boxing the fuel pump area off with an easily removable panel, both for neatness and safety, preventing them from being damaged by any loose objects in the boot.
8 Mar 2015, 9:55am
If you make a 45 degree angle in the fuelpipe above the pump and you a small piece of rubber hose to connect it to the pump,than run the copper pipe against the floor area,drill a hole in the piece of box section it's now clamped on,run the pipe trough the box and clamp it down with D-clamp(with a rubber sleeve)it would't look much better.
Don't clamp the connector thinghy,just clamp the fuel lines about 1 inch before and after the thinghy.
Personally i am not fond on soldering fuel lines,i rather use pieces of rubber hose to connect them.
I use a Y shaped plastic connector to put 1 into 2 lines with hose clamps,with a roadside repair you can always find it easy to repair with a piece of rubber hose.Soldering at the roadside is a bit difficult sometimes.
René
8 Mar 2015, 10:25am
Thank you Rene for your input, it is much appreciated. This is a really critical aspect of the restoration. I don't want to build in a poorly designed feature of such an important aspect of the car.
I will go back to the drawing board on this.
I can't easily go on the boot floor because the suspension bracket for the damper is in the way, which is why I went over the top of it. I am not sure what thread the fuel pump outlet union uses because I was reluctant to remove it and break the seal. I will do that now and establish if I can obtain or make a 90º elbow connector for the pump.
What it really needs is a 90º elbow outlet connector the same as the main pump with the red dot sticker has. That would improve the pipework a lot. I may go with a plastic 'Y' piece connecter but had avoided them because plastic can become brittle especially perhaps with the high ethanol content petrol we now 'enjoy'.
More thought needed!
Must go, have another bonnet side to roll! :icon_biggrin:
8 Mar 2015, 11:07am
ethanol also eats copper - I'm using nylon lines. I presume the "main" pump is switched off when the level stops it drawing fuel (as they're cooled and lubricated by fuel). Perhaps something like this Tee piece would simplify things?
8 Mar 2015, 1:54pm
:icon_frown: Ethanol seems to have a varied appetite. I thought copper was OK.
Yes, I was/am proposing to have a change over switch a bit like an indicator switch (on-off-on) in a concealed position, which gives some theft protection.
I had looked at a 90º 'T' connector but not keen on the 90º for flow. That's why I made a 'Y' connector, although I have since seen a plastic 'Y' connector like Rene suggested since I made mine, it probably doesn't matter that much but it just seemed better to have a 'Y' connector.
8 Mar 2015, 1:56pm
Second bonnet half almost made, a little fine adjustments and the hinge line to cut...
Will post some pix later if I don't make a complete hash of it.
8 Mar 2015, 3:04pm
Ethanol is nothing else as alcohol............moonshine is brewed in a copper pot:laugh:
So what's the problem?:doh:
8 Mar 2015, 7:57pm
A copper pot is probably 10 times thicker than your pipes. coupled with the risk of cracking through work-hardening, copper is just a risk you don't need to take IMO. non SAE R30 J6 rubber hoses can be eaten through within 12 months, copper can take 12 years but I prefer my cars to last bit longer :)
http://www.dieselnet.com/news/2014/07nist.php - bear in mind that report says 15 years for 1.2mm copper and the stuff we use in brakes is normlly 0.7mm.
8 Mar 2015, 10:23pm
I understand the copper fuel pipe has a 0.6mm thick wall. Not sure what will dissolve first, the filler neck, the tank, the fuel pumps (c1985), my 'new' pipework or the carburettors which were new c1977.
This is going to be a can of worms for older cars.
For now I am simply going to make a better support for the copper pipes. In some ways this is a development car. Once it is on the road I will need something to tinker with. It will be monitored and revisited once the car is back on the road. It is partly for this reason I passed the copper pipe through a conduit to facilitate replacement should the need arise.
I haven't achieved as much as I hoped this weekend, we had a dog staying which hampered things a bit. I still managed a major milestone, that of making the new bonnet. It's all trimmed and ready to rivet the hinge in. I need to order some solid rivets.
This is how I left the car this afternoon. Ready to bolt in the central hinge and mount the catches. The orange patches are strong adhesive gaffer tape, holding the bonnet in position.
8 Mar 2015, 11:26pm
Factory look!!!!!!!!!!!!!!!!
9 Mar 2015, 1:02am
Car Builder Solutions do right angle fittings for fuel pumps.
http://www.carbuildersolutions.com/uk/90-degree-brass-8mm-hosetail-18-npt
This one is for 8mm hose but 6mm and 10mm also available.
9 Mar 2015, 1:46am
Rene, it's a long way from perfect, but with a little work...
Scott, I hadn't really considered that, thank you for the link, in fact I think the rear pump with the straight connectors has 1/8" NPT threaded connectors, I just looked the spec's up on Wiki and it seems that way. I will measure in the morning. That would be a good fix for that aspect of the snag.
I just got home a few minutes ago, according to the car thermometer it's -2ºC outside so I thought it prudent to drain the Marlin. I haven't added antifreeze yet... It's very cold with a clear sky so the temp could drop quite a bit further by dawn. No point in risking my newly built engine and repaired radiator.
Looking forward to fixing the bonnet hinge in the morning. :smile:
9 Mar 2015, 7:54am
8 Valve Ed - Great work on the bonnet and doors. :cool:
As ReneAnglia says, it looks very professional.
9 Mar 2015, 12:01pm
Just catching up with this thread :-)
Copper is generally frowned on for fuel lines (and brake lines) as it work hardens with vibration and then cracks. I believe thats the reason it is not accepted by the IVA testers. I used Kunifer for both brake and fuel lines. Its an alloy of copper and something and doesn't suffer so much from the work hardening issue.
Great pictures! For those interested in making bodywork from ali its also worth a look at the Pembleton forum. http://thepembleton.org.uk. These little three and four wheelers have a body made entirely of ali.
Cheers, Robin
10 Mar 2015, 8:01pm
Sorry my contributions here are a bit gappy, I have been working on the car since first thing, dragged myself away for a dish of Kedgeree which I threw together, I am off back out now to finish off a couple of tasks which have been put off to often...
Paul, thanks for the complements, close up it's not as good as I would like but I am sure it will do what I need.
Robin, My preferred material would have been Kunifer, 10% nickel and copper, it's much tougher than copper. I had several rolls but due to lack of space I gave a lot of that gear away to friends. I used to have a really well equipped workshop and store with everything I needed but due to things beyond my control I had to give much of it up, my greatest loss is not having my own lathe any more. Eventually I may replace the fuel and brake lines with better material. I have to discover if this car is really suitable for what I need before I start refining it. My priority is to get it on the road.
Thanks for the compliment on the pictures, I try to take some which may help others understand there are many roads to Rome. I am overcome with the bonnet, it was so easy to roll, I am sure with more experience and a bit more patience I could have made a better job but I think it will hold together!
I have finished fitting the bonnet, I still have to set the rivets but I am waiting until the w/e when I have some more hands to help. I think I will need a lot of help to set the rivets, 23 each side for the central hinge, plus a similar number in the engine side panels. I am toying with the idea of peening them with my air hammer. I dug it out last night and it appears to be rusted up, the trigger is seized so I think some thin oil and a bit of encouragement may be needed.
While I enjoy contributing here, my priority is to get the car on the road ASAP, it's hung too long. So off out to get some more done. If I still have any energy I will post a pic or two when I get back in. :icon_cool:
