Dannys Build Thread 2 - Kobra
31 Oct 2014, 6:05pm
they are 8.5 front and 10 rear, they are fitted woth the spacers that where already on, i think 15mm/20mm ish. the rear spacers need to come off but i never had any shorter bolts. and the rear also needs to be jacked up about 10mm on the coilovers
10 Dec 2014, 9:58pm
I havn't gave an update for a while as ive been away and its been left in the hands of my pal. Just a little pic to show the smooth doors, no wing mirrors, no door handles. And most importantly, the shaping of the doors.
10 Dec 2014, 9:59pm
'Spot the Z3 now!'......
15 Dec 2014, 10:08pm
So simple, but what a difference.
15 Dec 2014, 10:46pm
Nice work on the door Danny, it does make a big difference. Looking forward to the other mods to front and rear.
16 Dec 2014, 8:53am
What does the inside of the door look Like?
16 Dec 2014, 9:35am
Have you fitted 'poppers' to pull the door handles?
I tried a couple of different models but neither had enough power to reliably release to door latch.
If you do have remote release I would like to see how you positioned it all if possible.
16 Dec 2014, 2:35pm
Ive used door poppers in the past before and they have all been sh!!t so i bought a remote garage door opening kit off ebay (a 1 that allows for 2 garage doors)...
http://www.ebay.co.uk/itm/181085271614?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
These are very good quality and the remote phobs feel solid and well put together.
This phob has 2 buttons (A for drivers side door & B for pass door)
I then bought 2 ford transit van central locking solenoids (very heavy duty! - infact they pull 3 amp unlike the cheap 1s from china that pull about 0.5amp)
I added a relay into the circuite that was man enough and bobs your uncle.
Ive sent them to colourtech to fit but if your thinking of doing the same il email you a wiring diagram i made.
I never added any fuses into the equation incase they pop and i cant get into the car!
However I will be adding a charge point some where incase my battery dies!
16 Dec 2014, 2:37pm
***i added relay because the contactors in the garage door opening kit where only rated at 1amp
(the contactors give continuity not voltage so you have to add a 12v supply for each door)
16 Dec 2014, 6:15pm
Pic of the drivers side.....
ive left the lock barrel in just incase the remote central locking fails!
The petrol cap will be covered and re located on the top of the rear drivers side wing.
16 Dec 2014, 6:49pm
The rear...
Not much to see here, the number plate light place that was built up has been cut out and filled back in flush.
The chrome hinges will be removed once internal 1s have been made.
16 Dec 2014, 6:52pm
Front...
Front lower plitter widened and built out, ready for trimming and sanding.
Bumper bar holes filled and sanded. Got to cut some new holes and add some fins through. Not sure yet if im going to change the bonnet scoop as per the concept im trying to replicate, i think i prefer it as it is!
16 Dec 2014, 6:56pm
At least you are ahead of the game Danny, with thoughts about how to get in if you get the dreaded flat battery!
A really good tin-opener may be a last resort!!
Good luck with it.
16 Dec 2014, 7:39pm
Thank God it wasn't just my normal incompetence that meant the poppers I bought failed. I did wonder when the seller just sent me their uprated kit without asking for the original one back. They then refunded the cost when that didn't work without asking for either kit back.
Garage door puller is genius.
I saw somewhere on the internet a popper kit with a hard wired cable pull behind the front wheel rain flap. Dead Battery? Reach behind the rain flap and pull the cable. Great idea but the bloke put it on the internet with a picture of his car and the location of the emergency lock puller.
I wouldn't worry too much about being locked out though. It is really easy to get a straightened coat hanger with a hook on the end above the window and reach through to pull the roof releases. When my first attempt at door poppers failed it took the RAC man about 12 seconds to get in.
16 Dec 2014, 7:51pm
A lad i work with works long trips away from home so he added a charge point to his car for a trickle charger like this....
Going to add somthing like this just in case the battery fails.
However someone told me that if you hold the unlock button down on a bmw that the windows open? Ive yet to see if it workes on a z3 though!
5 Jan 2015, 12:04pm
Thinking of keeping the original bonnet scoop and adding stripes something like this...
5 Jan 2015, 12:16pm
I really like that Danny - going to look awesome!
11 Jan 2015, 11:26am
Check out the latest TD3 prototype Cobra GT style from Backdraft Racing.
11 Jan 2015, 12:21pm
That's interesting. I like the front and rear wheel arches but not sure about the frontal view
11 Jan 2015, 6:56pm
I think that TDĀ£ looks awful. The proportions are all wrong. It is like a big car that has been shrunk using cheap cartoon software. It reminds me of the 'rad' VW Beetle charicatures
11 Jan 2015, 8:31pm
TVR used to fit a key operated lock hidden behind the rear number plate in case the car ever had a flat battery and you need to open the door. Very neat idea that worked well. You did need to unscrew the number plate first so neede a screwdriver as well.
12 Jan 2015, 2:24pm
WCA You describe the TD3 so eloquently!
There are some things we agree on!
12 Jan 2015, 5:07pm
Im not a fan off this at all. It does look a bit 'cartoonified' as WCA says.
Im flying to the uk for a short visit (2 days!) on thursday untill my company flies me back to Germany for work onthe Sat. Il be calling into colourtech to take some pics and fit the door solenoids.
Hopfully the car will be somwhere near paint so i can give the 'go-ahead' to paint it or ask for a few final 'tweaks' before paint as I won't see the car untill a friend of mine drives it to spain for me at some point in March.
4 Mar 2015, 3:17pm
Progress is still going on the kobra and im back in the UK in about 6 weeks so hopfully it will be finished.
I was always going to go with matt black or matt dark grey for the colour but i came across this photo and I may have changed my mind!..
What does everyone think?
