This is the new rotor and the stock unit. Stock rotors are 18mm thick new, and corrado is 22mm. So i machined of 2mm at each side. Take care when doing this and dial it in carefully before start cutting, otherwise the brakes will pulsate as hell. I also drilled gas holes in the new discs, and a friend of mine phosphated them so they wont rust. The phosphate will come of the friction area.
Mounted and ready. Almost. I have ordered EBC Yellowstuff pads for front and rears too, very good track pads. Works fine with glowing brakes! New wheels with sticky toyo r888´s too. I will transform the rear brakes too. Awaiting new rotors, 276mm (ordered from germany) so will do rears in the coming week!
Nice work, it always helps if you can stop when you're driving a home built car!
Can't believe the huge difference between the saucer sized 230mm discs and dinner plate 280's You can clearly see how much extra surface area, and subsequent ability to shed heat, that the bigger ones have. Keep up the good work.
Looks just great Chris! Bet that if they allready picked it up, it should come shortly. Bet they don´t want to store it that long...
Been working on car this weekend. Job was to replace ecu with aftermarket, and choice was megasquirt that i bought second hand from a very nice guy (same as i bought the coilovers from). So had to fiddle a bit with it as it has been used on a NB miata with 1.8 litre engine with turbo. Wiring is totaly different, so there was some soldering done, but now it running just great! Also changed injectors to 450cc, as the engine might see some boost in the future!
Megasquirt up and running! Uses the stock harness, no need to cut stock wiring as it used OEM style connectors!
When doing this the very restrictive air flow meter can be deleted, as the MS uses MAP-sensor.
When i had it out i realized i needed to do something with the roofline, so i have marked it out with tape where to cut... It has been cut today and bonded together helpfully, just so i can take rear piece off and bond on inside. Unfortunally i couldnt take any picture as it got dark outside, will try tomorrow
Difference now and before straitening the roofline. Doesn´t look much on the picture, but makes a big difference in reality... I am very happy with it. Also shortened front clip about 15mm to get the arches more symmetric...
Thats just great! Don´t forget the epoxi and perspex! I will need them really soon now! Thanks again! Your a great seller!
Todays work was to mould a new grille opening, took some influenses from aston martin. Used foam plastic (is it called that??) and cut it and sanded it out to make something to mould around. Protected it with packing tape.
Also moulded in light buckets for som extra highbeam lights. Will use 5" type from older golf or BMW. Used plastic flower pots
Today i slipped a bit with the grinder! As my car doesn´t have a slam panel, i thought i could lower the top of the frontsection a bit to have a smoother transition. -Yes i know it it perfectly fine as is, but it´s just me, i guess i was made this way
I made a "skelleton" of board pieces and foam plastic. Used hot glue gun to bond together
Packing tape so it will come of easy
Fibreglass layed. I am laying this "backwards", so i will have to sand it down, put some filler on and smooth it out. I will also have to sand it on the underside an add some more layers there.
You have done a brilliant job there! The roof-line looks well balanced.
I can identify a bit with your thoughts, it is not so much the difference that is seen by others, as the satisfaction in your own mind that you have what you want!
It is definitely worth the effort, and your car car will look fabulous because of it, keep it up.
