WCA G46 - The slow build (MX5 donor, customer chassis)
26 Nov 2011, 8:00pm
I bet that goes well?
Can i see it online, anywhere? Once you,ve got it... don't want any gazumping! Have you told the Mrs's that she may not get an ove n for Christmas after all...:tape:
28 Nov 2011, 6:30pm
It is being delivered on Wednesday.
Now when do I tell the wife...
28 Nov 2011, 6:51pm
I tend to find it's best when it's sat on the drive. It's harder for her to give you "options" then as the car is already here.
Not that i've ever done this you understand........ :)
28 Nov 2011, 8:24pm
WCA... I thought you had a budget!
Or rather you did have? I don't know about you sobering up, I'm hoping your wife hasn't... What's her Christmas present gonna be? Actually forget that!:nono:
28 Nov 2011, 8:52pm
Budget blown, Christmas blown, last time I will get blown.
Wife sort of okay with the idea, well she is willing to be in the same room. Lets hope it is okay when the bloke delivers it on Wednesday.
28 Nov 2011, 9:03pm
Anyway, its a lovely car
I remember when they were out, when i was a lad... great sound, no need to suup it up! I would say it must be one of the best options to build on, ever.:flame: :flame: :flame: One i will look forward to seeing!
http://garyssammiospyderbuild.blogspot.com/
28 Nov 2011, 9:18pm
Congratulations! Now the fun begins.
30 Nov 2011, 1:30pm
So according to the e-bay ad, it's got 12 months MOT.
So what i think that most of us want to know is.....
Has it broken down yet? :)
Only kidding, how does it drive? :)
30 Nov 2011, 1:48pm
Scary fun in the wet. Power slide away from the petrol pump in Sainsbury!
Smells quite rich but that could be fumes coming out of this tube.
30 Nov 2011, 2:12pm
Does it sound good!
All looks very nice, almost a shame to cut it up... almost.:biggrin:
30 Nov 2011, 2:14pm
I will be leaving it alone for a while. I wasn't planning on starting until the new year anyway and this has already stretched the budget.
I might need some new rear tyres soon. I just got wheelspin parking it in the garage
30 Nov 2011, 10:04pm
that open pipe is a breather so you may get some fumes
30 Nov 2011, 10:38pm
Roadster is right. It probably was designed to have a positive ventilation valve (PCV) plumbed into it and then hooked up to a vacuum port on the intake. Might want to check to make sure that there isn't a port open which would cause a massive vacuum leak. If this were hooked up in this manner you would not be smelling "fumes".
In any case you won't want to operate the engine with the tubing open. It will allow contaminants to get into the engine. At the very least there should be some type of filter attached.
Just my 2 cents. Nice looking car.
1 Dec 2011, 10:29am
Wow, that's a pretty adventurous donor and a far better choice than the MX5 imho. :eusa_clap:
Given the power to weight ratio I think you're probably going to get wheel-spin while it's parked in the garage!
I can't wait to see your build progress. Yee-haa! :party:
1 Dec 2011, 10:33am
I am glad to get your approval Mr Towed. I agree about it being 'braver' than the MX5.
I keep flip flopping between a state of extreme happiness and sheer panic.
I think I have traced a possible cause of the rich running. Under the big silver pancake is a choke that appears to be zip ties fully open!
1 Dec 2011, 10:38am
hands off...
You're not meant to be playing with it til' the new year. You'll get caught. Axe and Tookers spring to mind!:faint2:
1 Dec 2011, 8:27pm
WCA if you get wheel spin now - just wait until its a G46
The guys in their moderate powered Spyders all have lively sportscars thanks to their low weight-just ask Pat.
It will be a beast and it might bite.
I look forward to watching yourself and Garry create a unique Sammio
1 Dec 2011, 9:31pm
Me too....
Nice one WCA ....looks perfect for cutting up !
I quite fancy a G46 on this setup at some point - time and finances permitting !
I fancy a Rover powered Sammio Spyder as well .....
I think a TVR donor will be a bit special and still SVA EXEMPT !! You gotta love it..
1 Dec 2011, 9:45pm
WCA, very ermm! "got a new motor john" just yep thats the jobbie all TVR's where fun now it'll look good as well, PAT
1 Dec 2011, 9:47pm
Loving it already. I couldn't find the choke pull in the cabin so I took the air filter off to try and trace it. I found the choke was zip tied open.
There will be progress reports while I play with the TVR on Piston Heads (http://www.pistonheads.com/gassing/forum.asp?h=0&f=12&mid=208259)
I will start clogging up this forum when I start converting it to a Sammio. Probably in Jan/Feb depending on money.
If I can replace the high pressure EFI pump with one designed to run carbs I might even try a trip to see you Gary. At the moment the engine runs great and there is loads of power but the petrol fumes are a bit rich to drive anywhere for more than five minutes.
7 Dec 2011, 12:19pm
Fuel pump replaced.
Fuel Filter replaced.
Extra Fuel filter fitted.
Fuel cut off valve fitted (leaked and then repaired).
Cam vent fumes redirected.
Taxed and Insured.
Time for a reliability run. Southampton to Poole might be nice on a sunny day like today.
I will put my phone on charge and my faith in 25 year old Blackpool engineering
7 Dec 2011, 12:44pm
WorldClassAccident wrote:
Fuel pump replaced.
Taxed and Insured.
Sounds like a Tower ing achievement. Let's hope the ride isn't rock hard or you might only be able to drive a golden mile without tram lining etc, etc... :tape:
