Your procedure is pretty much what I did but it would have been considerably easier if I could have seen what someone else did first.
But - you could be in luck.... I haven't put the scuttle top back on yet. I can send you a birds eye picture of the ww instalation complete with rule if that would be useful.
I'm assuming that I need to shorten the arms, fit the blades and then work out the right hand most box's position (as looking from the front of the car)by placing it on the windscreen and noting where the arm sits on the scuttle, and then work across the screen with the other arms ensuring they don't interfere with one another.
Or is that all ass backwards?
I think I started from the drivers side. I first found the position that gives the full sweep from vertical to horizontal. Then with that blade in place you can find the position of the other two arms and blades. I found taking the spring off one of the arms helps. But i'm sure you can go the other way and end up in the same place.
The usual rule of 'measure twice, cut once' becomes 'measure 6 times and cut once'!!
Its the business end of a Toad alarm/imobiliser. Carpet is same as the stuff used in classic Jags - but is a real pain to use. Wouldn't use it again...
I started work fitting the washer system yesterday. I couldn't use the washer bottle kit I got from CBS at Stoneliegh, as the only place it'd fit was directly above the exhaust... I didn't fancy having to clean melted plastic from the pipes.
I've followed Robin's lead, and used a Alu water bottle from Millets (£3!) - but I have mounted mine horizontally in a cradle on top of the scuttle above the pedal box.
I've bonded a spigot into the cap and drilled a small hole on the shoulder of the bottle to allow air in as the water is pumped out. There's a dip tube inside on the other end of the spigot, which I've weighted down with some stainless washers to ensure it staus on the bottom.
To fill it, I take it out of the cradle, spin the bottle to get the lid off and then pour the fluid in. Spin the lid back on, and lay it back in the cradle with the vent hole facing up. Simples.
Just waiting on some nyon webbing and some adjustable plastic clips (like on rucksacks) to arrive to secure the bottle in the cradle.
I also need a decent one way valve... the one I got from halfrauds was a non-way valve. I could barely get it to open by blowing through it... :/
I thought I had posted these last night, but obviously the gremlins did for them after I hit the submit button...
Anyway - pics of the bottle:
I need to get some sort of label (that will withstand the rigours of the engine compartment) to stick on it that has the washer symbol on it. Anyone know where I could get one?
Questions before I start fitting the wipers tommorow:
1) How did everyone bend the arms of the wipers? Vice plus brute strength? If so I guess I'd need to cover the vice jaws so I don't mar the chrome...
2) Approx. how much needs cutting off an arm? From Peter's pics, it looks like an inch or so.
3) Wiring - I've got the lucas wiring details for motor, so that shouldn't be an issue - but when it comes to the washer jets - how did you wire that up? Just the jets when you pull back on the stalk, or jet + wiper? Did anyone get intermittant working, and if so, how?
at work and realised that I need K10... Which I think I've thrown away.
That being the case, and once I've got another, everything should go together as per the diagram I have. Bar the wiper motor that is.
I've worked out that:
Motor PIN 1 (Earth) -> Earth
Motor PIN 2 (Park) -> K10 'F1' (Slow input)
Motor PIN 3 (Fast) -> K10 '53b'
Motor PIN 5 (Slow) -> K10 '53'
But where does PIN 4 (Live) go to? K10 terminal '15' needs to be fed when the ign. is in ACY, Run or Start, so that will come off terminal 20 (dedicated wiper power) on my CBS wiring panel. Should Pin 4 of the motor be tied to that as well?
Wiring diags would be nice
Hi Jason,
1) yes, I bent mine by hand in the vice. I think my wiper arms are stainless so no visible damage.
2) That's about right. My arms are the adjustable type so the amount I cut off was not critical and also depends on exactly where your spindle holes are positioned.
3) Sorry can't help, as mine are very simple. I 'click' on the wiper switch for wipers and 'click' on the washer push buttun if I want both
1. Ours were the same as Peters, just bend in the vice. Wrap the metal in a cloth to avoid damaging the surface.
2. Our wipers are not adjustable so the length had to be right. That took a bit of time to measure. We just held the wipers up to the screen once the arms were bent. To make it a little easier you can take the spring out of the wiper arm.
3. I don't remember exactly how I wired it up. But I do remembering using a relay on the park signal to change it from -ve to +ve (I think it was that way round). Also the intermittent mode doesn't work as it would need a separate timer. The BMW wiper motor has that built in. We decided it wasn't that important and all functions work except intermittent:
- single wipe
- park
- slow
- fast
- wash + wipe
Aside from the London to Briton last year they've only had a little use.
I managed to use the BMW wiring almost unmodified and I have all the functions (including intermittent) which the K10 relay seems to sort out.
As I remember I just had to supply a separate live as the BMW wiring switches the earth.
Here is a picture of the internal connections of a Lucas motor - it may help.
As I remember, The BMW wiring effectively connects the park circuit to the slow speed when you turn the wipers off.
Excellent - I managed to get a K10 from an e30 dismantler on Friday, so I'll start hooking it up this coming week.
In connecting the slow speed to park, does that mean that I need to connect terminal 2 of the motor to F1, and then pin 4 to earth? or does pin 4 got to live and then it earths itself through F1 on the K10?
Assuming that you are wiring it using the BMW wiper switch...
Pin 4 of the motor to earth and pin 2 to F1 of the relay. The park switch just behaves as the "slow" switch - until it parks.
It's always wise to put a lowish value fuse in the circuit to start - just in case....
The K10 should provide all the functions, slow, fast, intermittant and wash wipe - just as on the original BMW.
You may have to adjust the park postion - I need to on mine but I haven't investigated how to do it yet. As a result my wipers park about 5deg into wipe rather that at the bottom.
A hint that I was given in the final stages of putting my wipers together was prior to fitting the arms and blades was:
Using blu-tack put some straws/cocktail sticks on the spindles so you can observe the sweep without the risk of damaging anything.
When I was ordering the bundy tube this morning, The SVC man also sugested that I don't use a saw on the drive cable when I come to cut it down, as the cable will fray. He sugested a file instead.
I was going to use the same method as Peter - cold chisel and an f'ing big hammer.
Sharp cold chisel is the best way. Just make sure there is nothing fragile with the target area as the bit you cut off tends to move with alarming speed...
