20 May 2015, 6:32am
Well done! That's quite an achievement if you got it through first time.
20 May 2015, 6:37am
Cheers all, it was actually second time Mr T as first time it failed on brake balance as the adjustable brake bias wasn't set correctly.
Tried to tax it last night but the mot hadn't updated on the system yet will ne trying again later this morning
TTFN
Mac
21 May 2015, 5:59am
great work mac....a top motor
21 May 2015, 12:29pm
How well does it drive and stop of course ??
21 May 2015, 1:36pm
Phil thanks a lot
21 May 2015, 1:41pm
Micky
The brakes are now excellent and it pull up well and will lock up if provoked the engine is still running rough as its on a base only map and the jets are a ways off. Got it up to 60 on the way back from the MOT and the ride was surpringly good. I have the front Spax set just soft of midway and that seems tone the sweet spot as it rides nicely but doesn't wallow. The tears are set just firm of midway and again that seems to be working.
Next job is to get it on the rolling road for a tune up and I should then be able to stretch its legs properly.
TTFN
Mac
21 May 2015, 2:31pm
If a car "feels" right it normally is right.
Your racing history should set you in good stead to see just how well you can stretch it's legs. :icon_razz:
24 May 2015, 8:07am
Mac - Belated congratulations on the MOT. :cool:
You have joined a very exclusive "club", as there are very few Cordite/Navigator kits actually on the road.
Good luck with the last few details, Paul. :)
25 May 2015, 7:40am
Paul,
thanks but have hit a small snag as i tried for about 3 days to tax it on line before noticing that the MOT tester had got one digit wrong on the reg! Spoke to them on Friday and they tried to contact VOSa to get it changed but couldn't get through so will try again tomorrow.
TTFN
Mac
25 May 2015, 1:15pm
To anyone spraying at home I hope this helps.
Please bear in mind the following
1. I used a high solid 2 pack paint commonly referred to as truck coat, it goes on thick and does take a while to cure fully but if your spraying conditions aren't ideal (like mine) it allows you the luxury of having enough paint on that you can correct most runs, orange peel etc. The specific product i used was Lechlar 29155 also referred to as LS155.
2. I put about 5 coats on and could probably have reduced the peel by thinning a little more but that would have encouraged more runs.
3. This is just my experience some may disagree and if you follow my lead don't blame me if it goes all Pete Tong!
4. Truck Coat by the very nature is not conducive to producing a mirror finish shine, if that's what you want then this isn't for you. Me personally? I wanted a period finish with some shine and lustre but wasn't that bothered from the start about a mirror finish.
Goin back a bit this was the finish out of the gun:
Very orange peeley to say the least.
After about a week I started to flat back starting with 800 on a small solid block fro runs first then moving up to 1200 to start removing as much of the peel as possible. I used water in a spray bottle with literally 2 drops of washing up liquid to help reduce clogging. After the 1200 i moved up to 1500 then 2000. In hindsight i could probably have gone straight from 1200 to 2000.
Part way through this process you will definitely think you have totally cocked it all up:
Keep persevering though just take it slow and easy and changed your sanding pads regularly. Eventually you'll end up with this:
A smooth flat surface but with minimal defects
Next step was a good wash with nothing more than clean warm water twice to ensure that any left over contaminants are removed.
After letting it air dry I then started (This morning) to cut back using Ferecla G3, be warned that the product you can buy in Halfords in the black bottle is not the same as the pukka stuff in a yellow bottle available from your local paint supply place.
I found that ToolStation did some very cheap foam pads and polishing mops and having used them I think they were fine and dirt cheap.
First i soaked the new sponge in clean water then squeezed the majority out by hand followed by spinning the wet sponge on the polisher to remove most of the remainder, you want it damp not wet.
A few dobs of G3 on the panel and then swirl it around with the sponge before you start. Start at low RPM, I'm using a cheapo Clarke polisher and started on setting 1. Keep the sponge flat to the surface and move slowly, don't linger or you will burn the paint, sounds scary but just take it slow and steady. after the majority of the G3 has started to dissapear I then up the rpm setting to 2.5. If things start to get sticky then stop and spray a fine mist of water on the panel , this helps keep the temperature low and acts as a lubricant. Keep going until your left with just a light haze on the panel. Now remove any remaining haze with a clean cloth and inspect. If necessary then start the G3 steps again! Its not a quick job but the results are worth it.
Just this morning the rear of my car has gone from a totally flat fin ish to this:
And a close up of the same are to show its not just 2 foot good :-)
Very close up you can still see some very faint swirls and I will decide after finishing with the G3 wether or not to go up to maybe a G10 for a final finish.
Hope that helped someone
TTFN
Mac
25 May 2015, 1:24pm
Some links that may be useful:
Lechlar Spec Sheet for the paint:
http://www.express-paints.co.uk/content/291551.pdf
Polishing stuff from ToolStation:
http://www.toolstation.com/shop/Power+Tool+Accessories/d80/Buffing+%26+Polishing/sd2694/Drawstring+Lambswool+Bonnet/p80677
http://www.toolstation.com/shop/Power+Tool+Accessories/d80/Buffing+%26+Polishing/sd2694/Polishing+Sponge/p33265
Feracla G3
http://www.amazon.co.uk/FARECLA-BODYSHOP-ADVANCED-CUTTING-COMPOUND/dp/B003JI745O
TTFN
Mac
25 May 2015, 4:44pm
Well that's it, I have decided that G3 is enough! mainly because my body just wont stand up to going over the whole thing again with G10...
I have also just given it a coat of Mer and cleaned the interior. List of jobs left is now:
1. Clean Wire Wheels and tyres
2. Finish Fuse Box Cover
3. Finish Gear lever cover
4. Sort out the holes left from the front mounted indicators.
5. Make a cockpit bumper for between the humps.
6. Make a finishing piece for behind the steering wheel.
7. Paint the mouth cream
8. Fit the grill
9. Fit sticky front number plate.
10. Fit headlamp chrome trims
11. Paint Navy Blue pinstripe along border of cream panel.
Done!
TTFN
Mac
25 May 2015, 5:10pm
Great job Mac..
25 May 2015, 8:49pm
Looks fabulous, be proud of that! Are those beetle indicators at the front? They look good
T
26 May 2015, 7:53am
Nice work Mac the car looks great.
Just in time for the summer, happy days.
26 May 2015, 10:58am
It looks lovely. Hope we get some nice wether now so you can enjoy the fruits of your labour.
26 May 2015, 1:25pm
Tim got the side mounted indicators from Holden.co.uk
Thanks all for the comments
Bit of a pain today as the garage called and it's going to be easier to retest than to get the current MOT cert changed to the right reg number doc obviously but a pain none the less. It's booked in for Saturday morning so hopefully I'll be taxed and legal by Saturday lunchtime 👍
TTFN
Mac
27 May 2015, 2:56pm
Nice one Mac, the car looks really first-class!
27 May 2015, 4:21pm
Mac - Thanks for the guide to making paintwork shine, as it seems to have worked well for you. :cool:
Good to see you have been following the Scottie22/Hulk Hogan "Build Bigger Arms" programme. :icon_wink:
5 Aug 2015, 7:07pm
Mac - It is a real shame that people are messing you about with the sale, as you produced a very nice car.
Hope everything else goes well for you and your wife.
Take care, Paul.
25 Mar 2017, 4:03pm
# BUMP #
I actually spoke to Mac this morning, he still has the car and it has just passed its second MOT. :cool:
Hopefully, he will pop in at some point with a proper update and some photos.
