Geoff's 250 SWB Replica Build
23 Feb 2015, 9:49pm
Looking good guys.
Nice detail work and the inner panels should really make for a well finished result.
See you soon.
23 Feb 2015, 10:11pm
reneanglia wrote:
Is the rubber infill piece on the stock z3 needed to keep the water out?....or is the glass itself bonded in the frame?
René
The Z3 windscreen is bonded, the rubber trim is just a decorative cover.
23 Feb 2015, 10:14pm
Paul L wrote:
Chris - Given how good this looks now (if you ignore the flash lines), I can imagine it will look fantastic painted. :cool:
The way it all fits to / around various points on the original BMW is very clever too.
Thanks Paul. The development has been a huge amount of work, but well worth it in the end.
24 Feb 2015, 11:26am
+1
Just trying to work out finances. as I said, been a long time since a kit got me this interested. brilliant.
24 Feb 2015, 2:15pm
My first post here but been keeping an eye on all things Automotive for a long time. Chris your skills are amazing and the SWB is a stunning car and IMHO you've chosen a superb base vehicle too.
If I can sort my finances I would definitely be up for one of these for sure.
If I can add my ten pence worth re the finished styling, I'd say you have the car 99% spot on from a tribute standpoint. My only gripe is the size and positioning of the front vent, behind the front wheels.
To me it seems too big and in the wrong place. Obviously due to the BMW being shorter in the front than the Ferrari the bodywork behind the wheels is smaller, the vent therefore seems too big for the space.
Ive added some photoshopped images below(with some lovely spokies) to illustrate the point, hope you dont mind mate.
Car as is...
Original SWB
Smaller vent
I think a smaller vent would give the effect of elongating that area.
Thoughts people?
24 Feb 2015, 2:22pm
I think you're very right, Very Andy.
24 Feb 2015, 2:24pm
Cheers Gary.
Amazing how a small tweak can improve the looks IMO.
24 Feb 2015, 3:44pm
Kind of tend to agree with you VA,
here is my idea of size and position
24 Feb 2015, 3:57pm
presuming that these vents aren't functional in the master mould, they could probably be a simple bond/bolt on option available in different sizes and fitted wherever you wanted?
24 Feb 2015, 3:57pm
Yeh that looks good too Scottie.
24 Feb 2015, 4:11pm
Not sure in the vents are fixed or not. My guess is not based on these earlier pictures during the development so you could replace them with any size or shape you like - What are they like on the MX 250?.
Probably need Chris to give the definitive answer.
Plain wing
Add vent
Blend in
24 Feb 2015, 4:15pm
I hate to disagree but if you look at the first produced panels of the SWB - they are definitely molded into the body.
I am sure Chris will confirm this either way.
24 Feb 2015, 5:00pm
Hmm, I could be wrong, but from this angle it looks to me like Chris has already moved the forward vents to the middle of the panel between the wheelarch and bonnet shut-line on the production shell.
Either way, the placement of that vent wouldn't be a deal breaker for me, it's not hard to move/modify/delete such features on a fibreglass shell after all.
Now, back to the classified's to find a low mileage, FSH, silver 2 litre straight six donor with a/c, cruise control and scruffy bodywork...
24 Feb 2015, 5:33pm
Originally Posted 5th September 2014 -
Me: From talking to Chris and Dan at Donington it won't be their panels that need cutting up, but the donor Z3 needs some, ahem, adjustment with a lump hammer to squeeze it into its party frock.
Tribute: Something must have been lost in translation at the show Dave, the only modification to the Z3 base car, apart from stripping off the outer panels of course, is to cut off two small brackets from the front grille area. I will post up some pictures when I have them.
An interesting point with the taller profile tyres that are fitted to my SWB is that it corrects the over reading on the Z3 speedo, according to my GPS, almost exactly.
Tribute Automotive wrote:
Kit door skins have return edge which allows them to be bonded over the existing Z3 doors once glass and trim have been removed and an area in the centre of the door skin "pushed" in:
Apology accepted. :eusa_think:
24 Feb 2015, 6:40pm
That looks more like a boot was used, not a lump hammer.
Minor reprofiling of the contours Dr Martin stylee
24 Feb 2015, 7:40pm
colours and options
Gents
Since there are a few people on here who can use PhotoShop, could someone post a PhotoShop version of the red car in yellow with a black roof and minilight alloys
Many thanks
:fencing:
24 Feb 2015, 8:30pm
Welcome Andy.
I always welcome praise AND comments on the development of our products, but in this case the moulds are already made with the vents included in the front wing. As Mr Towed says "it's not hard to move/modify/delete such features on a fibreglass shell". This statement is true and I for one enjoy the fact that Tribute kit builders don't all build the same way meaning no two look exactly the same. Personal taste and choice of style and parts make it YOUR CAR. For example wheel/tyre choice on my own personal take on this kit/car will almost certainly not be the same as most others:
OR
Keep watching and posting.
24 Feb 2015, 8:33pm
Correct! Size 10's it was.
24 Feb 2015, 9:11pm
Plastic Porsche wrote:
Gents
Many thanks
:fencing:
Black roof Bill? Where would you break the colours on the rear pillars?
24 Feb 2015, 9:33pm
Chris.........if the door panels are fitted there bwill be an air gap between the z3 door and the panel
ofcourse,is this gonna be filled to eliminate vibration sounds?...........
René
24 Feb 2015, 9:45pm
René
Vibration sounds? The GRP door skin construction is a sandwich of 450gsm matt/3mm core matt/450gsm matt, very rigid. I will take some pictures for you. I personally am not going to fill the void, to allow any moisture to exit via the drain holes that will be drilled in the bottom of the new skins.
25 Feb 2015, 5:35am
vibration
Rene;
We will use some vertical gluelines of Sikaflex to make sure there is no vibration
Rob
25 Feb 2015, 11:37am
René
René
On thing you can do if you are worried about vibration between original metal panels and the new GRP skin panels is to squirt builders expanding foam into the gap between the panels to fill the void.
