I spent a long time convincing myself that I must be doing something wrong, or just missing something completely.
The cable operation is set up in such a way that the back of the switch & the switch itself can only be fitting one way.
This means the "hottest" & "coolest" settings are actually a "given".
So this is the end of cable position for hot:
And then the cable is withdrawn to reach the cold setting:
So far, so good.
But the problems started when I tried to find a lever position on the valve which worked in this direction.
I even took the lever off to see if it could be adjusted, but it was also "fixed".
In the end, the only way the lever could be make to push/pull in the correct way was if it was on the "wrong" side of the mounting bracket.
In this position, the value will open/close as it is supposed to.
Now I am happy to admit that I may have been making a simple school boy error all along.
But I couldn't believe how long I'd spend messing about trying to resolve this.
So I decided that I would take my anger out on the offending bracket and hit it repeatedly with a hammer.
It wasn't a very neat job, but I did manage to reverse / turn the cable fixing point through 90 degree.
The position above is "closed".
And turning the heater switch "up" now came me this.
As you can see, that wasn't quite right, so I adjusted the cable fixing a bit until this was how fully "on" looked.
By now I realised that I have to turn the dial through the thick end of 300 degrees to go from off to on.
OFF:
Then turn the dial anti-clockwise to ON:
So much for the 45 degrees of red heater markings.
The only good news of this whole sorry saga, was that the best way to mount the value was like this.
This removes any potential fouling issues when the other heater hose is fitted.
I will need to make a new mounting bracket, but that should be straight forward enough.
( Famous last words.
)Next job will be to check and fit the dash wiring loom.
I also want to dig out my completed headlight assembly to check it following a debate on Mac's build.
But that's all from me for now, Paul.
. Just read this back to myself and am not sure it makes sense?
. Tell me what you think. UFO17.
