Rusty with poor electrics, I had 2 when they were current, wouldn't dream of trying to do anything with one. Your would have to cut it about which would mean an Iva, would be a nightmare.
Scimitar would be a much better starting point.
I know what you mean, but little cutting the body and none of the chassis if you based it on a cabriolet all the body rigidly stays because of the roll over bar.
The whole reason I scrapped the SE5 is that it was just to narrow the XJs (sorted) would make a great grande router or eventer and look a lot better than the Lynx effort.
What started me down this road is some chap from the sixties used an XK150 with a hatch back to tow his race car looked fantastic
XK-8 convertible base as used by Mrs Woss above is clearly doable.
They're probably more easily available, reliable(?) and reasonably priced (for a sound car with MOT) than the old XJ-S these days. Lose the nasty 22" wires and Silver Cross side trims, glaze the rear side panels and you could achieve a pretty good V8 auto gentleman's shooting brake look on a budget.
No chassis on an XJS so any cuts in theory would need an IVA inspection.
A half decent XJS convertible is 10K, would you really spend that sort of money to cut it about to make an estate car?
It's a bit like giving Liz Hurley to a cosmetic surgeon to make a Susan Boyle look-a-like, never mind, no accounting for taste!!
You have a point there! with the Liz Hurley reference no argument. However Toad (towed) has the right description "shooting brake" not "estate car".
It's like I live in a barn conversion but some people say bungalow
My thinking has been limited to a chassis car never though a monocoupe would be considered as the whole thing, back to the drawing board
Should be quite easy to do too : The car would retain the Corvette targa top. AeroWagen bodywork replaces the original Corvette hatch utilizing the OEM seal, hinge and latch mechanisms
I wonder what other cars could be modified in this way?
Remove the old hatch and add the new body over the remaining hole...
aweesome cars... horrendously complicated electrnics and they are at "that age"... :S
What about a Supra?
The one's that are left generally are pretty good. Main problems are hardening of valve stem oil seals, turbo's burning oil and gearbox synchro's going.
Ive had a lot of high performance cars over the years but the 3000GT (UK version of GTO but higher spec and bigger turbos) is something else, heavy car but once you wind it up
Not wanting to step on toes but has anyone tried using a rover p6 as a donor. The wings front and back come off and it has a v8 modor. Maybe a Ferrari coupe could be made or indeed a muscle car with slightly higher haunches at the back. Make it a 3 door etc
[QUOTE=zagmad;84736]Not wanting to step on toes but has anyone tried using a rover p6 as a donor. The wings front and back come off and it has a v8 modor. Maybe a Ferrari coupe could be made or indeed a muscle car with slightly higher haunches at the back. Make it a 3 door etc[/QUOTE
With a pretty expensive de-dion rear end I seem to remember
If you made it into a Volant I'm sure with a bit of jiggery pokery you could get it to sit on a standard Scimitar chassis.
A lot more practacle than an Auburn!
