Convertible New Build
3 Nov 2019, 7:39pm
Jaguartvr wrote:
Typo, drop is -30mm not -130!
No worries, I figured that.
Any pics with the drop?
3 Nov 2019, 8:00pm
It is the same as my profile picture, click it and it will enlarge. These are of the earlier springs but they were also -30 and the picture was taken on the day they were fitted so hadn't yet collapsed.
The springs, tyre size and wheels all suddenly came together and it all makes it look so much better. The car isn't garaged but since changing the wheels and suspension it is impossible to take it out without someone stopping to admire it.
Currently working on a full interior. Dash (not Tributes) was awfull and only fitted where it touched (which wasn't in many places) is just about fitted, just doing a final modification to the mould. The speedo and rev counter also looked too flat so they have been adjusted and the top cowls made longer. I have also managed to incorporate the heater controls and am very pleased with how they have come out. I think the dash has taken more hours than the rest of the car. It has almost cost as much as the kit! No pictures yet as it is going to a trimmer to have it leather covered. I am also waiting for the mounting plinth for the small central instruments to come back from CNC. Should look stunning, well it bloody well should do after all the work.
Also bowed to popular pressure and removed the spare wheel so a twin stainless exhaust could be fitted. Kept the centre box and just pipe from there back, sounds great but not obnoxious. I have a phobia about not having a spare so the original space-saver lives in the boot. The car now obviously has knock-on hubs but a bit of forward thinking goes a long way. The hubs are held on by the original wheel bolts (shortened by 3mm) this way if you get a puncture, remove the wire wheel and hub and then fit the space saver using the original nuts. I have had a 3 earded spinner removing tool made up with a 2 foot
breaker bar so it is very easy to remove the spinners and nuts. I then have a locking bar that sits over 2 wheel bolts to lock the wheel so you can stop the hub from turning when undoing the bolts.
Sorry, didn't mean to hijack your excellent build thread.
3 Nov 2019, 8:13pm
That's perfect!
With all of your interior work it should be fabulous. Thanks.
3 Nov 2019, 9:11pm
Dash conversion sounds great, be sure to post some photos when its done !
4 Nov 2019, 9:27pm
Received the lower windscreen trim from Grassbank today, I've trimmed it up and should look smart on the finished car. It just visually raises the lower edge of the screen by about 3" to make it look wider, a bit more retro and less Z3.
4 Nov 2019, 9:37pm
Do you plan to modify the wiper arms as well?
4 Nov 2019, 9:38pm
So does it have a fake rubber along the top edge ?
4 Nov 2019, 11:13pm
I'll have to reduce the length of the wiper drive cranks by around 1/2" if I remember right. That will reduce the sweep of the wiper blades so they stay within the glass. The standard wiper arms can be used, just tweaked a little to get the angles correct. I also radiused each end of the panel so the trim will be curved rather than a sharp angle as in the photo.
4 Nov 2019, 11:18pm
I was going to make my own FRP part, and was referencing
Justin's photos, but the site is now down.
Should have saved them.
4 Nov 2019, 11:19pm
I intend to use genuine rubber !
4 Nov 2019, 11:20pm
They still have some stock, I only ordered this part last week.
4 Nov 2019, 11:22pm
Would look better if the panel was glassed to the "A" pillar trims.
Just hope you never have to replace the windscreen.
The PU adhesive can be removed carefully with a heat gun and a sharpened putty knife. Careful with the heat around the windscreen though. Was a challenge removing my body.
4 Nov 2019, 11:23pm
I'll try go contact Justin. Thanks
4 Nov 2019, 11:28pm
You could do that to make it look like it was always there. However, this area of the car is a compromise. If you were really keen it might be possible to extend the bonnet right back to the screen and mount the wipers on the back edge. Lots of work but it would look more authentic, perhaps.
5 Nov 2019, 12:18am
Too much work.
using the panel is a good compromise. I have sent Justin an email.
17 Nov 2019, 7:40am
Lucky - A very belated congratulations. :cool:
By the sounds of it, it appears to have been a very straight forward build.
( Obviously, your previous building experience helps. )
I look forward to seeing the car painted, especially with the bumpers.
Your garage floor needs a good clean! :icon_twisted:
:icon_wink:
17 Nov 2019, 11:06am
Hi Paul,
I liked the idea of a convertible as soon as I saw the hard top being built. That was a few years ago and I was still in the middle of my Triumph resto, then the TR turned up ! Only back in the spring of this year was I in a position to ask Dan about a convertible.
The garage is in the process of a revamp by the way ! The chequered lino was fine for a while but impossible to clean. Gone with a light grey two pack floor paint, you can't go wrong with that.
21 Nov 2019, 11:15am
Lucky@LeMans wrote:
Hi Paul,
I've not used 2 pack floor paint - indeed in my current garage I have no floor paint:sad:
In my previous garage I put down single-pack floor paint (first coat thinned with white spirit), and it stayed good for years until we moved - but it was slippery when I walked in with wet shoes. I should have mixed some sand or similar into the top coat? Did you do anything to stop the 2 pack being slippery, or doesn't it need it?
21 Nov 2019, 10:03pm
Depends how smooth your floor is I suppose. My floor is pretty textured, the concrete was just tamped down. I've not had a problem but adding sand will give you an anti slip surface for sure.
27 Nov 2019, 1:24pm
I've made the kick plates for the lower door cards.
The car has been promised to be back from the painters Wednesday next week !
27 Nov 2019, 1:25pm
Kick plates shown here......
27 Nov 2019, 3:45pm
Very well done
28 Nov 2019, 9:01am
Yes. Very nice indeed. You cannot beat simple lines. Functional and stylish
I might steal the idea one day (hope that’s ok)
28 Nov 2019, 10:03am
This photo is from an original.
28 Nov 2019, 10:18am
Find it hard to believe that for the money Ferrari charge that they just use screws to fit the door cards rather than hidden clips like every other manufacturer.
