Darren's MX250
9 Mar 2017, 5:01pm
Don't know if this helps but Fiat 850 lights are very close to the 275GTB design.
9 Mar 2017, 7:08pm
Hi TynopPrime. Thanks for the pictures. I do like the GT lights, so am tempted. What are you going to do for a fog lamp - given that it is a legal requirement? Also - how did you cut the holes for the lights?
9 Mar 2017, 7:10pm
Also, I assume you have bought the lights? Can you place them in and take another picture. That would really help to see what they look like on the MX250. Thank-you.
9 Mar 2017, 7:31pm
On my 250 SWB the rear fog is inside the car in the back window. The MOT tester checked the requirements and it's perfectly legal. As it shows as clear LEDs when not lit, you can hardly see it.
20 May 2017, 9:10pm
Rear Clamshell
It's been a while since I last posted, I'm slowly working my way through all the items I need to do to before fitting the rear clamshell.
I've made a list which may or not be of interest to others.
• Clamshell
○ Rub down all mould lines and get shape correct
○ Area between doors and rear wheel arch
- Trim profile to allow enough distance to blend filler
- Consider how to get uniform both sides
• Rear Window
○ Trim flange edges for rear window glass to 5mm smaller than glass
○ Fit window
○ (paint flanges first as appropriate)
• Parcel Shelf
○ Repair, Fill and sand
○ Paint
○ Rivet and bond to rear boot area
○ Cover with fabric as appropriate
• Boot Extender
○ Ensure fits Correctly to allow rear clamshell to sit at correct height
○ MK2 - fabricate pieces to close corner gaps in corners
○ Glass fibre large gaps to avoid water leaks
○ Tiger Seal seams and smaller gaps
○ Paint
• Vents behind rear wheels
○ Cut holes and sand
○ Fabricate and Glue mesh
• Area between doors and rear wheel arch
○ Trim profile to allow enough distance to blend filler
• Wiring & Lights
○ Route rear lamp wiring
- Cut Holes in body
- Fit lights
- MK2 can use rear light jumper / sealing grommets / connector
- Join light pigtails to vehicle lighting wiring
- Consider how to connect wires when body is fitted
○ Number plate lights
- Need to re-route Mx5 wiring from rear boot lid to rear area
- Fit number plate lights
- Join light pigtails to vehicle circuit
• Aerial
○ Re-locate aerial (inside boot?)
○ Re-route wiring
○ Fit booster if needed
• Heated Screen
○ Route and glue wires around edge of window aperture
○ Ensure connection route path to body wiring
• Headliner
○ Glue headliner to body
○ Leave extra at edges to trim later
• Fuel Pipe
○ Cut hole in clamshell
○ Create recess as appropriate (from glass fibre matt) & bond
○ Fabricate longer fuel pipe and breather from 2nd MX5 fuel pipe
○ Mount fuel pipe to body
○ Fit petrol cap
• Exhaust Pipe
○ Need to lower to clear lower valence of clamshell
○ Temporarily cut and fit 90 degree bend
• Boot Lid
○ Fit hinges - ensure gap is uniform
○ Fit boot rubber
• Boot Latch
○ Fit latch to boot extender box section
○ Route remote release as appropriate
○ Fit striker to boot lid
○ Fit Lock to boot lid or use original lock as appropriate
• Drain Tubes
○ Fit spiggots in boot trough
○ Drill holes in rear boot extender
○ Fit tube between two
• Trim
○ Re-fit any trim pieces that will be hard to access afterwards
20 May 2017, 9:24pm
Boot Lid
Struggling to get the lid to sit on the rubbers straight. It is high on the lower left corner and low in the middle of the top edge.
Any hints / tips on how to get the lid to sit flush with the body?
21 May 2017, 6:41am
Its hard to say from the photo but a few things to consider.
Is it the boot lid that needs adjusting or the surrounding areas that it sits in.
Does it sit better with the rubbers removed. Bear in mind that they will compress a little one time.
Can the lip be trimmed to allow the boot corner to be lowered.
With my bonnet, I put some slices into the strengtheners underneath, curved the bonnet and glassed it back up. You could do the same, screw the boot lid to the car to get it flat and then glass it up from underneath. Screw holes are easily filled afterwards.
With the ariel, I bought a sharks fin ariel from Ebay for about £10, it has some kind of circuit board inside and a lead with an eyelet on the end. The eyelet screws to the old ariel base and the sharks fin sits under the fibreglass shell with double sided tape. It actually has better reception than the original ariel, this was on the Z3, the fitting may be different on he MX5.
21 May 2017, 9:57am
You are sitting the shell on a big bucket, this is distorting the frame.
Fit the shell to the car first. It will require some fettling to fit.
21 May 2017, 9:01pm
Thanks guys - good advice. I'll try it again fitted on the car first and then see if I need to do anything more major afterwards.
21 May 2017, 9:57pm
Yep, I did build up the shell a bit to meet the lid, I guess a couple of mm out.
23 May 2017, 10:24am
TAZ - Remember you are trying to fit this without mounting it to the car, the body does flex a lot at this stage and I would recommend only using this time to fix hinges and drill hoes for lights etc and not the final fit.
You need to trim the boot flange down as it's too high for the original seal and once you get the catch on you will find a better fit.
10 Sep 2017, 6:24pm
Wheels
Hi, Looking for ideas and suggestions on wheels.
To start discussion, I quite like these from XXR (553). However, they are quite wide and not sure they will fit in the front wheel arch?
If I calculate correctly , they will protrude 81mm from the hub (8" = 203/2 mm - 21mm offset = 81mm) and most other builds are around 70mm. So is it too much?
Should I go 15" or 16"? I think 16" will look better but am worried about a harsh ride as I have lowered the car.
At the rear I calculate I would still need a 45mm spacer.
Or what else could you suggest? Are there any good designs with staggered offsets?
10 Sep 2017, 6:33pm
I think the wheels you have picked look too modern and that the concave wheel in general is a bit of a fad right now.
Gotta be retro. There's always the usual BBS crosspokes most of us have gone for.
Be prepared that when you take your car to shows, most people will be telling you that you should be on wire wheels ;)
10 Sep 2017, 6:39pm
I'm on 15x9 et10 rear and 15x8 et10 front
10 Sep 2017, 8:34pm
I like the wheels.
Mine is on 17" 7.5j and think about 35 offset but I have made the back end narrower so needed 35mm spacers on back and 15mm on front.
11 Sep 2017, 7:02pm
Nice looking motor. How does it handle on the 17" rims? The experts seem to say that anything above 15" ruins the handling.
12 Sep 2017, 7:23pm
Have only got the car on the road last weekend and have never drove a MX5 before so can't really comment.
2 Jan 2018, 8:18pm
Finally managed to get rear section bonded and riveted over the Christmas hols!
My thoughts are now turning to the front end. Anyone have any tips on cutting out the three front vents and headlight sockets?
Also, I'm thinking of adding slots to the front wings - GTO style - but given the fibreglass bonds to the cut metal wing in that area, it seems a little tricky. Any tips? Is there a way to simulate it without cutting the whole right through?
2 Jan 2018, 10:01pm
I did the vents and headlights by roughly cutting out using a hole saw and then enlarging the holes using a dremel with one of those little sanding tube things. They get through the fibreglass pretty easily.
3 Jan 2018, 9:15am
Check out my build thread , I did vents in the wings , very easy really
