Denmark A352
9 Nov 2016, 6:42pm
Just prior to being delivered to me , the Spitfire underwent a fairly thorough restoration in Denmark , that involved the body being removed , chassis detailed and painted , all suspension etc refurbished including adjustable coil overs being fitted etc. and a lot of welded repairs on the bodyshell , probably as a result of its time spent in the Danish climate ..The customer paid a substantial amount for the car by UK standards as he wanted a Danish registered and fully sorted donor .
24 Nov 2016, 10:33pm
Fairly quiet couple of weeks on the A352 due to a couple of factors ...I am waiting for the aluminium Bomber seats to arrive 15 days quoted , so any day now , hopefully ...these will allow me to finish the interior . I don't want to chance belt location etc until I know the whole layout ...
I've also been waiting for my Vitesse mate to come over to start the engine between us ..I can muddle through but am no mechanic , so like to be watched over and helped ...With a check through and a prime with fresh fuel etc ...she fired after about a dozen cranks ... I'm chuffed ..more mechanically minded than I thought !!
The front carb was leaking , so Ben stripped it and cleaned it through and fitted it with a couple of new gaskets and refitted it ...shes fine now ...
tomorrow we will time her up and run her a bit longer ...
8 Dec 2016, 4:23pm
Upholstered bases I think ...They are ok ..the seats , a bit thin and a bit rushed ...I see several guys selling these ..I'd probably aim for a mid range set if it was me , rather than the cheapest ...
Having said that , they do look rather nice ...
17 Dec 2016, 8:30pm
Ally panelling mostly done , seats in , harnesses in ...
17 Dec 2016, 9:09pm
Chafe protection for the shoulder belts in the plan?
Looking good!
17 Dec 2016, 9:35pm
Looking good!
Yes ..I have some rubber u section edging trim that is going around the hole ..I think Woolies sell it , but mines come from a local Yacht Chandlers ...
The seats are very cool looking and not too uncomfortable as they are , but Thomas has plans for upholstered swabs to go on the bases ...
I'm nearly done on this one now ... Need to fit the wire wheels , firing up properly , taking for a short drive ...check everything and then it goes back to Denmark for paint and stuff ......
17 Dec 2016, 11:38pm
Looking good!
I think I would want seat squabs as well.
Best of luck!
18 Dec 2016, 7:33am
Gary - The combination of seats, belts and ally panels give the interior a real race car look, :cool:
I hope the owner will send/post some photos of it in final paint.
18 Dec 2016, 8:42am
Looking good Gary, those alloy seats really suit the car and look to be just the right size.
21 Dec 2016, 8:53pm
THEY DO LOOK THE PART ...A little thicker material and they would be excellent ...but as they are , as long as they are bolted down nice and securely ...they work out ok ..
Fibreglass trans tunnel on its way and we can pretty much sign off the interior as done ...
30 Dec 2016, 6:25pm
My customer sent me a Herald style gearbox tunnel cover he bought on ebay ..
It needed modifying to fit the A352 ...I had to cut reliefs for the fire extinguisher etc. but the main issues was it was 50mm to low at the gearstick.
I cut this section , splinted it with a 40mm gap and fibreglass the join...this allowed the stick to protrude through and the tunnel to sit down correctly ..
14 Feb 2017, 6:57pm
The car is now ready to go back to Denmark .
The bodywork and final detailing etc. will be finished off over there ...
The car will be painted BRG , which was its original colour ..the black wires should compliment it very nicely ...
15 Feb 2017, 12:22pm
Turned out nicely, that one. Kudos, Gary.
17 Jul 2017, 11:57pm
Well, I guess it's Dee time again. Here's the first pic from it's home...
18 Jul 2017, 12:17am
Well guys - it's Dee time again. To bring you up to date this is what the car looked like on arrival :-)
18 Jul 2017, 12:32am
The wheels are in
Tryin' on
18 Jul 2017, 12:39am
Perfect!
18 Jul 2017, 10:10am
Can't get enough rivets
Inner wheel arches needs trimming to fit the 15 inch dunlop alloys.
Trimmed and ready
18 Jul 2017, 10:13am
I chose to fill up every rivet with filler to make them look like the real thing. Sanding down everything
18 Jul 2017, 10:15am
Using a matte black industrial grade filler. Was thinking about keeping it in flat black for a while
18 Jul 2017, 11:44am
Glad to see it's progressing ....
18 Jul 2017, 1:29pm
I like the detailg
18 Jul 2017, 1:34pm
Awesome work on the rivets!
