BMW powered Sammio
22 Jan 2014, 9:07am
mikmiglia wrote:
Bless you lot, its a bit bitter on here :pop2: :eusa_clap:
The question still remains unanswered did you ever finish the V8 conversion and how did it run :becky:
22 Jan 2014, 9:25am
Good question, it must be out there somewhere and it looked great in that dragon green paint.
22 Jan 2014, 9:47am
I heard it was sold for £320,0000.........,
22 Jan 2014, 10:01am
I'm afraid not .
Mike wasn't happy with using that body because of the amount of filler in it doing the changes to design and used it as a plug only. the body was cut up and disposed of , the chassis remains in waiting for another project , wheels and tyres went on the German Miglia and the engine and gearbox are now sat in a 1927 Ford Model T Hot Rod project that was something to do with Gary J but now being finished by a friend of mine.
So the door for the first V8 example is still open.
22 Jan 2014, 6:11pm
oxford1360 wrote:
It was clocked at 200mph on the M1, at which point the upturned wheelbarrow on the bonnet flew off and caused a huge pile-up.
Was it bonded-on or bolted-on :laugh: :laugh:
22 Jan 2014, 6:13pm
So, I am now looking for a triumph donor and V8 with gearbox :rockon: :rockon:
22 Jan 2014, 6:17pm
Was it painted in red oxide with black wings and a Jag front end???:whistle:
22 Jan 2014, 10:26pm
no mate. it is an se5 chassised example with all outriggers removed post inspection , a tribute 27 T body and currently still in white or grey gelcoat.
7 Feb 2014, 4:35pm
Hav'nt done much on this project but I did add little something to enhance it's looks :eusa_angel:
Wheels
And a badge
8 Feb 2014, 7:24pm
Spent some more time on it today.
Fitted the fuel pump and filter. It has a 15mm feed pipe and a 8mm flow/pressure pipe.
I am using flexi hose but will replace it with copper at a later date.
Also fitted a frame to carry the gear stick and hand brake. The gear stick and shaft are from a BMW E36 as it is about 100mm shorter this bring the gear stick forward to a much better position. Range Rover hand brake lever is fitted and working using the standard Triumph cable.
The fuel filler will be mounted where it is on a steel plate and then pass through a hole cut in the body so when the body is removed the filler will stay in place and keeping the fuel and vapours safely inside the tank. A rubber seal will be fitted between the steel plate and the body.
All things well, we will be wiring it up over the next few days and hopefully have it running next weekend. :hail:
9 Feb 2014, 4:30pm
I'm lovin' the BMW badge. :cool:
That should help generate a few wrong guesses in the car park. :icon_twisted:
Good luck with getting the engine running again.
9 Feb 2014, 6:22pm
All I have to do now is to make it sound like a "car park" Ferrari :icon_smile:
9 Feb 2014, 10:53pm
Thats some neat fabrication Micky. Maybe I should think about a modern engine transplant?
10 Feb 2014, 9:17am
Why not there lighter, faster, more reliable and better MPG :heh:
10 Feb 2014, 11:04am
And a badge
Wonder what the sharknose grille would like grafted in.
10 Feb 2014, 11:05am
Sorry image is a bit big
10 Feb 2014, 7:14pm
Looks like you are making good progress on this mate, I am certainly intrigued..
10 Feb 2014, 7:43pm
Find me a grill like that one on the black BMW and I'll make it fit :high5:
11 Feb 2014, 12:54am
its just a beer crate with a few slats missing!!! LOL
14 Feb 2014, 5:47pm
Sorted the wiring out today and started to install the engine loom.
Ever closer to pushing the start button :icon_mrgreen:
14 Feb 2014, 8:09pm
Ahhh wiring, one of my favourite jobs.........sometimes :-)
