New Mx250 Build
3 Jan 2014, 12:33pm
As for the rear lights,
I didn't want replica 250 GTO lights / LR rear lights as i feel they make the kit look a bit more like a kit car.
I was going to go for some LED style hamburger lights, even after reading a lot of unfavourable comments, then i thought i'd settled on Mk 1 granada rear lights, then to my horror i noticed one of the forum members had already beat me to it!
then i found these bad boys!!!
3 Jan 2014, 12:37pm
bonus points if anyone can guess their origin!
3 Jan 2014, 12:41pm
America or Cortina...
3 Jan 2014, 12:52pm
Hopefully next week i will get some workshop space back and i can finish off the prep work,
If anyone knows of a good supplier of hubcentric spacers please let me know, looking at the rear arches i think i'll need at least 40mm each side to get the stance right, i've seen bolt on spacers in 50mm for over £150, i think thats a bit steep,
3 Jan 2014, 12:56pm
Nope....
3 Jan 2014, 1:39pm
TheLaughingCow wrote:
clearer image
If they are not from a BMW 2002 then I am a Dutchman.......
3 Jan 2014, 1:57pm
clearly you are not a dutchman!
Well spotted!
Got them off FleaBay for £65 the pair, the great thing with these lights as apposed to the mk1 granada lights i was considering is the reversing lights are built in saves me having to fit a seperate reversing light, keeps the back end tidy.
3 Jan 2014, 2:01pm
They are very neat and pretty, and suit the car perfectly. They are very "un-kit"
3 Jan 2014, 8:09pm
I bought my spacers, 50mm from memory, from freaky parts for about £90 (I think). Had to wait a few weeks.
4 Jan 2014, 8:29am
Well done with those rear lights, that's the cleanest look I've seen yet!
Very neat.
4 Jan 2014, 7:05pm
That's fantastic progress in 3 weeks!
You have beaten us to it with the BMW rear lights, we have 2 pairs in the workshop waiting to be used.
4 Jan 2014, 10:20pm
Thanks Chris
They say great minds think alike!
I was considering sticking a red bulb in one of the reversing lights to use as the fog light,
But I think it has to be a set distance from the tail/ brake lights to make it 100% legit,
I did take it for a brief blast up the road today, I seem to have some slight rubbing due to the increased wheel size, will probably need to cut back the inner arch fillers, might as well wait til I have the rear spacers.
Hopefully I'll have some workshop space available later in the week so I can tackle the wipers, boot lock and bonnet latch,
Until then I'm going to eBay a few items to try and generate the money for the spacers and wipers.
5 Jan 2014, 10:23am
I didn't get much from selling the spare bits off. The hood complete was the only worthwhile bit at £90. Things like the boot lid, rear lights etc I just got a few pounds each so hardly worth the hassle of posting or waiting for people to collect.
5 Jan 2014, 12:05pm
has your mx5 been lowered at all. whats the diameter of the tyre your running. I quite like the combo. bin looking 16x8 and 16x7 and then what tyre to fit . 23inches ish maybe.
6 Jan 2014, 2:54pm
I believe the overall diameter of the wheels i. A shade under 27 inches
the suspension is completely standard, before I fitted the wheels I was planning on lowering, looking at it now, that won't be possible or necessary.
Running wheels and tyres this big will cause the speedometer to be fairly inaccurate ( about 7mph at 60mph) other than that it's just a matter of clearance
I'm fitting a double din Sat nav stereo which will help me keep an eye on my speed
6 Jan 2014, 2:57pm
The tyres are 215/55/16 - big and bouncy
wheels are 16x8 et20 offset all round, rears will be spaced 50mm each side
6 Jan 2014, 3:03pm
I've been looking at a few other builds, has anyone managed to use either the original bonnet or boot latch to latch the bonnet? I notice there's not a lot of room, so I would be cutting into the metal in front of the rad.
Most builds seem to use bonnet pins, I'd quite like to use the original bonnet release lever/cable
6 Jan 2014, 6:44pm
You might find your speedo is actually more accurate with the larger tyres. Most speedos over read by about 10% so you're typically travelling at about 54mph when it reads 60.
You can check how much difference your tyres will make to the speedo with this handy tool -
http://www.kouki.co.uk/utilities/visual-tyre-size-calculator
Just enter your original and new tyre sizes and it'll tell you the difference. So long as the error isn't much more than 10% slower than actual speed you should be fine. Check it against your sat nav speed and you might be surprised.
6 Jan 2014, 7:42pm
er kouki says 30mph on dial you actually be doing 35.9 same nock on affect with 60 actual is 71. same amount of turns 19%further distance travelled. something like that. I think i'll need a gps thing too
