Here I'am again with finally some progress to report. I have been busy getting all things sorted for the doors and the interior structure. Beside the doors I was planning, I have noticed that there is little room for shoulder and arm at the door side. I'm about 12 feet 60 and a fatty on top of that, so figure.
The tub is quite narrow. I figured that it needn't to be, because the upside of the "doors" has a substantial horizontal surface. So the tub could be widened at least 7 cm's at both sides.
I had to change my plans and went for the "superleggera" approach. Here are some pictures to explain.
This is a subframe I made for the right side
[IMG]
[/IMG]
This is the subframe in place
[IMG]
[/IMG]
This is making the framework for the doors
[IMG]
[/IMG]
Building doorframe and subframe at the inside of the body (I haven't cut the doors yet)
[IMG]
[/IMG]
This is a door frame almost finished. The foto doesn't show all the curves of the tubing following the body lines properly. It was a llot of work getting t=it done
[IMG]
[/IMG]
This is a picture of the door hinge mechanism. I used Spitfire boot hinges. The foto doesn;t show the bracket with the studs that supports this part. This part is welded to the frame. This way I can adjust the hinges by adding spacers between the stud bracket ant the hinges.
[IMG]
[/IMG]
This picture shows the complete assembly.
[IMG]
[/IMG]
After that, It's a lot of panneling. This one for the inner side of the sills (3 mm aluminium).
[IMG]
[/IMG]
These plates for the panel behind the seats.
[IMG]
[/IMG]
Which will bring it to this
[IMG]
[/IMG]
Which will lead to this (2 mm Stainless)
[IMG]
[/IMG]
And this is right where I'm today. I have to proceed with the last two panels that are in the subframes. I have to get some stainless panels welded to each other and have the aluminium panels coated first.
I have to get the body off and apply an extra layer of glassfibre because the body is very thin at the place (0,5 mm gelcoat and 0,5 mm grp). Then I have to smoothen the inside with filler before applying the paint. Ah well, never a dull moment with a Sammio I would say.
Michiel
