Cordite Demonstrator
13 Sep 2012, 9:18pm
WCA G46 development keeps getting delayed by family stuff and other commitments. Nothing this weekend or next because of weddings. Have sold the TVR and need to shift the Merc CL (bargain price if anyone wants it) to fund the Maserati. That will leave me with just the Maser as daily driver, pick up as general work horse and the G46 as project.
Hopefully combining this with the dark evenings will allow me to progress more quickly.
13 Sep 2012, 9:25pm
G46 progress
Charlie & I have started working on ours again, more bodywork alterations, I am not sure if the Sammio community is ready to see what we have done yet!
13 Sep 2012, 9:33pm
Hey, anything goes on the Sammio site. So long as your driving position doesn't leave you looking like Il Papa in the back of his Popemobile.
Would love to see some progress pic's of whatever you're doing...
14 Sep 2012, 7:13am
Mister Towed wrote:
OOPS. Sorry Gaz, I forgot you'd taken the G46 project on. I didn't mean to insult your pride'n'joy, far from it. I'd love to see one finished and painted, I guess they just take more work than the simple Spyder. Even so, I can't believe it's been so long and nobody's got one road ready - Gary J had the original G46 body almost finished in his workshop when I collected my kit way back in July '11. Perhaps he should have donated the first body out of the mould to that French chappy, what was his name now? Patoune, that's right, who got a Spyder from pile of parts to road going racer in a week...
http://www.madabout-kitcars.com/forum/showthread.php?t=2717&page=4
No problem T, no insult taken or offered, I was just pulling your leg. Car number one was Patounes car before I did a swap deal with my Spyder. Its now my car and after some modifications is looking even better than it did before. Very happy with the way it is shaping up!
Charman.Tech, Would love to see how you are progressing. Modifications on a G46 is very much welcomed, the more extreme the better. Im looking forward to seeing progress on all of the builds, so far there are 6 under construction with no two being produced being alike with Squre arches, round arches, one hump, two humps, no humps, cockpit divider, full screen, single screen and real windscreens and then there is the lovely looking V8 version too!
18 Sep 2012, 6:40am
Hi Andy,
As I try to follow your lead on my own build, can I ask another round of questions?
AndyP57 wrote:
... body fitted ... Minor cutting away at the bulkhead ...
What areas did you need to cut and by how much?
Did you use any of the donor Spitfire rubber / metal washers under the framework?
Also, in how many places (& where) is the rear frame attached?
( In addition to the two obvious mounting points at the back that is )
I wasn't sure if the metal plate for the pedals was meant to be touching the bulk head.
There appears to be a gap in your photo, are you simply bolting the master cylinders straight through?
12 Oct 2012, 9:15pm
Andy - Sorry, I know you haven't had a chance to answer my last batch of questions...
But can I be cheeky and add a few more while I try to work out what I should be doing?
I plan to start "encouraging" my frame to line up with the last two chassis mounting points soon.
Can I just check that the two frames should line up 'edge to edge' when they are joined together?
This is the passenger side & again I assume the front frame edge is on the inside.
Now you have gone through your re-body inspection, I guess bits have "fallen off" the front chassis.
Do you now know if the bonnet will clear everything in the engine bay without the need to move things?
I'd like to upgrade my radiator to the full width version that you appear to have fitted to your donor.
But the advantages of this 'straight swap' part would be lost of the mounting points need to change.
Also, if you have fitted the bonnet, I'd also like to see how the bonnet hinges work.
Was it simply a matter of using the same sort of bracket that Gary fitted to his Cordite?
And finally (you'll be glad to hear) can I just pick up on this part of your build?
AndyP57 wrote:
... I've not put any lowering blocks in mine (And may not do yet) as I want to experiment with wheel sizes to fill the arch, leaving the geometry of the swing spring as it was designed...
I am planning to use 13" wheels with 175/70 size tyres (as they came brand new with my donor).
I've also got a 1" lowering block & matching studs from Rimmer Bros based on previous advice.
Is it worth waiting to see how you get on without a lowering block, or just get on with fitting my one?
I'll have a better idea of how my body & wheels will look when I've sorted out fitting my frame.
Thanks again, Paul. :)
