Body Shell - Part 3:
I needed to remove the throttle cable before I could remove the pedal.
This was a simple "push and unhook the cable" job, a bit like on a bicycle.
Then there were just two bolts in the bulkhead to remove and that was it.
Note: This pedal does not have a rubber cover on it as standard.
( Which explains why I was not able to find anyone selling one!
)Then it was time to remove the petrol tank, starting with 2 clips on the filler hose.
Again, I hadn't realised the petrol cap was a simple "push on" design.
It pretty much came away in my hands as I started to look at what was holding it in.
There was two more clips on a hose connecting the fuel hard line pipes.
Then 5 bolts to undo and a bit of wiggling about and out she popped.
I assume there should be a breather hose given the molten mess held on by a clip.
Either way, I put caps on the pipe ends and sealed everything up for now.
I need a bigger jerry can to decant the remaining petrol out of the tank.
( I have no idea how long its been in there, so I'll refill with fresh petrol later on )
Not sure yet whether I can re-route and reuse the existing hard line for the Cordite.
The heater was next (and I'll be starting a separate thread on whether to keep it).
Two pipes from the engine block needed to be disconnected, held by jubilee clips.
I opted for another low tech solution to seal one end, cling film & a rubber band.
There were 4 bolts in the bulkhead to remove and that was that.
I guessing the foam "seals" are not a standard Triumph part.
Removed the main part of the steering column held in by 3 sets of brackets.
Next Steps:
- Remove the rest of the steering column
- Block the wheels & then remove the hand brake
- Undo all the bolts and see if the body will lift off!
My next post will be photos of the body shell for potential buyers.
