YOU ARE WELCOME TO CALL BY ANYTIME - You might be best advised to give us a little notice to just make sure we are about , we usually are ...the only appt. I have soon is the Orca Inspection...probably next week...
We have managed to get a bit more done on the car ....Mike concentrated on the rear end (his speciality !! ) and I stayed up front....
I have made a bolt on subframe , needs to be bolt on to keep us the right side of SVA , that enables me to hang the bonnet...some simple 'rabbit ear' brackets and 1'' box have made this job pretty straight forward....
[SIZE="5"]SO THIS ....[/SIZE]
[SIZE="5"]NOW DOES THIS .....[/SIZE]
[SIZE="5"]
THANKS TO THIS BRACKETRY......[/SIZE]
Mike meanwhile started cutting a bootlid....we had initially thought about leaving the boot area up to the builders choice , but pretty much everyone who has enquired wants to use that dead space....we have cut a hatch that is big enough to get a spare wheel through. It works really well as a spare fits in really nice and with the front of the wheel sat where a natural bulkhead can go inside the body , the spare just pokes ot , leaving a little room behind for a small jack or wheelbrace etc.
There is still two obvious boot space sections where the original back seat was and these can be accessed in the cockpit through hatches in the rear bulkhead ....so basically , the rarely touched spare etc is tucked away in the back , adding a bit of ballast at the same time and anything you want more regular - maps , picnic , tent etc can be kept seperate up the front section of the rear....
The bootlid itself can be either hinged or fitted with locating pins , quarter turn latches , zeus fasteners , whatever !!
Obviously , if someone doesn't want the bootlid , it can be filled in and glassed over by us....
I have been toying with making some dummy Rudge style wheels recently as well ....well actually they have been going on for about 6 months !!
Rudge knock on steels were used on 1950's Mercedes cars , Gullwings etc as well as turning up on Porsche 356's over the years as well....genuine examples now change hands for thousands of pounds EACH as they are pretty desirable in those circles ....
The slotted rims are very similar to the early Porsche / VW rims , so I am starting with that and making some 'knock on ' style hubcaps ....The Beetle rims will be fitted on adaptors and then these caps will be bolted on to the wheel studs to hold in place ...dummy rivets around the edge and the centre ring eventually will help give the look as well as a bit of tube in the centre and a spinner ....they aren't replica's of a Rudge but they are '' in the same style as '' and could be an interesting option to fitting wires ....
