Mister Towed on the road...
9 Aug 2016, 5:43pm
After all, who in their right mind would build a replica Lancia, paint it silver and fit German rally badges?
I was very tempted but will resist!!!! :-)
7 Sep 2016, 8:24pm
Two days spent preparing my car ready for my trip to Goodwood Revival tomorrow - oil change, plugs out gapped and cleaned, etc., which threw up a few interesting things:
The switch to NOS Stromberg 1.75's has benefited the engine enormously - I'm now getting a solid 25mpg when thrashed whereas I was struggling to get 15mpg with the worn out 1.5's fitted. I also now have a nice even grey brown deposit on all six plugs rather than front three white and back three black I used to get no matter how I adjusted the old carbs.
I've also had a play with the front suspension after struggling to keep up with Phil and Barry's cars on the back roads on our run up to the coast a few weeks back.
I did a bit of research and found that most of the Triumph small chassis gurus recommend having the lower front A arms level with the ground for best results. My front suspension was set so low that I had a dihedral angle on the lower A arms giving the front wheels quite a bit of negative camber. This had the effect of making the car very stable in a straight line at speed, but quite reluctant to change direction quickly.
Yesterday I removed the front spring units and wound the adjustable shocks in another inch, effectively raising the ride height by an inch at the front and leaving the lower front A arms parallel with the ground.
I'd also asked Barry what tyre pressures he and Phil run and I think he said they're on about 32psi all round. I'd settled on 24psi front and 22 back, mainly because when I first set the car up with really slammed suspension - lowered 90mm at the front and 75mm at the back - the tyres turned to Teflon with any more pressure than that in them.
So, I've also increased my tyre pressures to 28psi all round - I didn't want to go over 30 as I've also noticed that both Phil and Barry's cars spin up their back tyres every time they pull out of a junction while mine could keep its traction even under severe provocation and I'm not into spinning tyres myself, I just see that as wasted power.
So, after three years on the road, the combination of a slightly higher front end and more pressure in the tyres has finally sorted out the handling. It now has much lighter steering, is far more willing to change direction and is really steerable on the throttle. It now feels far more like the sports racing car it appears to be.
Photos from Goodwood to follow in a few days...
8 Sep 2016, 5:15am
have a great time ....richard earth is going tomorrow ....i have send his phone num to your phone....30 psi front 28 back
8 Sep 2016, 6:28am
Cheers Phil, I thought 32 would be too high. The wheelspin must be due to more power in your car and maybe a heavier right foot...
Thanks for Richard's number, I'll give him a call.
8 Sep 2016, 7:17am
Mr T - I'm always impressed by the way you keep changing/updating/improving your car's set up. :cool:
Enjoy the drive to Goodwood and I hope you have a great weekend.
With a bit of luck. I might see you there in 2017. :pray:
Enjoy, Paul. :)
8 Sep 2016, 12:43pm
Really looking forward to seeing your car this weekend......OH ...AND YOU ...
8 Sep 2016, 6:57pm
Ha ha, see you at the Revival Gary, it'll be nice to catch up again.
Made it to my B&B in Rowlands Castle in good time today - about three and a half hours to cover the 175 miles from Norfolk including a couple of stops to stretch my legs.
The changes I've made to my Spyder's suspension since the last time I came to Goodwood (2014) - adjustable front shocks with 1" extra front ride height, 180lb front springs, a bit more toe out on the front wheels and higher tyre pressures - have made it feel far more agile and confidence inspiring than ever before.
Don't get me wrong, it wasn't ever 'bad' but it was so stable it didn't feel as if it wanted to change direction, so it felt like I was having to force it to do what I wanted it to. Now it turns in very crisply and it's just a case of guiding it where you want it to go.
The 'new' carbs and higher tyre pressures also meant that I got 32mpg into the bargain, which is about 10mpg better than it's ever managed on a long run before, a 30% improvement! I've also finally fitted a working tachometer, a reconditioned classic Smiths 6cyl electric one, so it was nice to see that my motor's turning just over 3,000 revs at a genuine 70mph.
Early start in the morning and I'll maybe post some pictures tomorrow evening. I have a paddock pass this time so should be able to get some good shots of the cars up close.
13 Sep 2016, 6:42pm
And here's some pictures from Goodwood at the weekend -
Wet start on Friday morning, but nothing compared to what was to come Saturday -
At least it showed that I'd polished the paint for once (the red blobs are cherries that'd fallen from a nearby tree during the night) -
Was in good company in the classic car park as usual -
Rather liked this pair of MGA 'Speedsters' -
Once inside, this was the star of the show for me, a Lancia D50 with side tanks -
Other distractions were abundant, 'oi, get outta the way, I can't see the car!'
Classic Lamborghini in Gulf racing colours, what's not to like?
D50 reeling in another scalp on the track -
Marvelous.
Friday was lovely but there was torrential rain for most of Saturday. I found out that my water resistant jacket doesn't resist water that's approaching sideways at high speed.
Once thoroughly soaked I just found an empty bit of the infield, sat on a carrier bag on the grass and enjoyed the racing, which was all the more spectacular for the cars sliding all over the place at breakneck speed.
The closest race, and also the cars that appeared least affected by the atrocious weather, was definitely the Austin A35 Academy cars. Skinny tyres and modest power combined to give them impressive grip and enough speed to look scary.
It was real head to head racing with no car having a power advantage over any other, so it's all down to the drivers. Who knew that such a pipe and slippers car - even by the standards of the fifties - could actually go so well!
It's true that the revival is now almost too popular for its own good, but the huddled masses did just that, huddled together, and didn't venture far from the bar. If you walked five or six hundred yards away from the main areas and past the chinless wonders in the posh party marquees, there was loads of space. I was also lucky enough to have a paddock pass this year so I could get close to the best cars without loads of other people getting in the way.
All in all a thoroughly enjoyable event for me and I shall go back for more another year. :peace:
15 Sep 2016, 6:14am
Mr T - Great report and photos. :cool:
15 Sep 2016, 4:56pm
Shame the mighty Lamborghini didn't make it to the track :laugh:
Great cars and great report :)
15 Sep 2016, 5:53pm
Thanks guys, appreciate the positive feedback. ;)
16 Sep 2016, 5:24pm
Yes Mr T ....great to meet up with you again and pick up some more tips on a first hand basis .....I finally got my voice back by Wednesday !!!!
Happy motoring
Slarti
16 Sep 2016, 7:58pm
Happy motoring
Slarti
It was nice to meet up with you too Slarti and I'm glad you got your voice back. Hopefully your acting fee will pay for some Strepsils for the next time England win the World Cup. If you're still around for when Alpha Centauri hosts the tournament in the year twenty five twenty five...
28 Oct 2016, 2:01pm
thought you might like this...
28 Oct 2016, 4:11pm
my type car.....nice
28 Oct 2016, 4:30pm
Very nice, what site is that on..?
Pops
28 Oct 2016, 6:02pm
Very nice Gary, I'm a big fan of the outlaw look on early Porsches. I was going to put some pics of my favourites up but it looks like Photobucket is down at the moment. :(
28 Oct 2016, 6:42pm
Mr T - Given the fact you already have a car with no roof, could you be tempted to add a roof to your next project?
So from this...
To this...
Then you would have something to drive on a rainy day. :icon_wink:
Looking forward to seeing the new build thread start at some point.
28 Oct 2016, 7:00pm
Yep, the yellow peril will be outlaw style, will have a soft top roof and might just end up with a hard top too if I can make one that looks right. And of course it'll be silver. ;)
28 Oct 2016, 9:55pm
Did we ever find out what base you are intending to use for the 356?!
29 Oct 2016, 9:12am
Okay, photobucket's up and running again so I can actually post some pictures and take the opportunity to explain one or two things.
I'm lucky enough to be able to retire in January next year after 35 years in uniforms of one colour or another. I'll have a modest heap of tax free cash and sufficient income from my combined pensions that I won't need to work 'for the man' any more, but I'm young enough to want to do more than sit in front of the telly with a rug over my knees waiting for the 'reaper to show up.
Knock knock.
Who's there?
The Grim Reaper.
The Grim Reaper hurggh...
Try saying that out loud if you don't get it.
So, I need something to fill my time until I'm too frail to work, and I could also do with a small additional income stream to pay for adventurous continental road trips and new central heating boilers without eating into my nest egg.
I've looked at part time work, stacking shelves, Uber driving (failed the interview as I'm not a potential serial killer), working for a charity, etc, but the lure of being my own boss is strong.
I've long wanted to start up a small mobile catering business but always succumbed to the security of a guaranteed salary instead. So, I'm going to live the dream, turning my hobby into a business and building classic replica cars for a living.
Madness?
Well, over on the Tribute forum it's been pointed out that the 'kit car' world has changed considerably over recent years. In the booms of the fifties and eighties customers for kit cars were typically people with lots of mechanical skills but little money. It was a cheap way for a working class factory mechanic to build an interesting plaything when he wasn't at the coalface making widgets.
The prices realised for the best looking classic replicas now though, almost £50k for a Z3 based DNA 250, for example, shows that there are now lots of potential customers with deep pockets but without the technical skills or time to build their dream car themselves. They will form my customer base.
To improve on my current income level (whilst still employed) I'll only need to sell one car every eighteen months, but I'm aiming for two per year, one right hand drive and one left hand drive as the falling pound is good news for export prospects.
I won't be selling kits or taking on commission builds - I don't want any deadlines or unrealistic customer expectations - my plan is to build cars that please me and sell them to people who fall in love with them too (if I can bear to part with them...)
Ultimately I'd like to develop my own Maserati 200si replica, I fancy having a go at a (Tribute) D Type and wouldn't mind creating a more accurate Lancia D24 Spyder (V6 motor and slightly bigger), but my first project will be an outlaw 356 Speedster.
The images I'm looking at for inspiration are mainly the smooth, paired back style created by Emory Motorsports and famously driven in this episode of Jay Leno's g'rarjjj -
https://www.youtube.com/watch?v=xxSKO3Er-Yg
And some stills of this and a couple of later models in similar style -
I'll be putting my own style on the Speedster though. For starters it's going to be sitting atop a Spitfire chassis with an aluminium twin cam up front. I also want to create a bit of confusion in anybody viewing the car as to whether it's real or a replica.
Speedster replicas are so commonplace now that most people will assume even real ones are Chesil products. These tend to have the post '53 horn grilles with integrated front indicators, post '54 three dial dash and post '57 teardrop rear lights.
I'm going for an earlier look with beehive rear lights, '53 only stand-alone clear front indicators directly below the headlights and a pre 'A' dashboard with cowled instruments -
It'll still have a Speedster screen - although I like the earlier 'bent' screen on a coupe I think it's too tall for a convertible - and Porsche never actually built a Speedster with the pre 'A' dash, but that's where the confusion will come in.
Anyone interested enough in old Porsches to be looking inside will expect to see a standard Speedster dash, just like all the other Speedster replicas. Instead, they're going to find something different, the screen, seats and side curtains from a Speedster but the dash from a contemporary convertible. So, could it be a pre-production development model built by the factory in late 1953?
Well, it might just be...
More later. ;)
29 Oct 2016, 9:20am
It all sounds very interesting Towed ..good luck with it all ...I genuinely wish you luck ..the retro replica market is growing constantly , off the back of rising classic prices due to investment buyers etc...
Lancia D24 replica sounds very interesting ....There's a cheap S*mmio project on ebay at the moment that would be a good start for that !!
I get my Miglia body on Monday ....only ordered a back half up to the centre of front wheelarches ...so hopefully have a little play with it next week ..
29 Oct 2016, 9:50am
Cheers Gary, good luck with the Miglia and I think it's a wise decision not to have the fixed front end. Flip front bonnet is the way forward...
29 Oct 2016, 9:58am
Just looked up the cheap project on ebay.
By some incredible coincidence it looks just like the one you've been working on Gary. Mind you, there's a lovely finished silver example lurking in the background of one of the photographs that looks just like mine!
Leg pulling aside, wouldn't you be better off finishing it and selling it on as a turn-key car?
