Geoff's 250 SWB Replica Build
30 Oct 2014, 9:58pm
Plastic Porsche wrote:
Your right, the MWS 6 x 15 wires do stick out a bit, the ET is actually -16 so they stick out alot
Very nice looking wheels but it does look like they might push out too far for the SWB arches though.
31 Oct 2014, 10:17am
Just run a few calculations through the 'will they fit?' software.
The MWS wheels at ET -16 and splined adaptors which effectively increase the wheel 'poke' by another 31.75mm (1.25"), give an equivalent of ET - 47.5mm.
Looking at the BMW Z3 as a potential donor, compared to the factory fit 7x16 ET38 alloys, the wires will 'poke' 73mm further out, widening the track by 5 & 3/4".
Even looking at some of the huge optional alloys that Z3's tend to wear - the biggest I found that I think are meant to fit on the front were 9x18 ET 40's - they'll still 'poke' out another 50mm, widening the track by 4".
There's probably two inches clearance to play with at the back, especially if a 'narrow body' donor is used, but I think it might be a struggle to get them to fit on the front without fouling the arches of the SWB shell. Shame. :(
31 Oct 2014, 6:55pm
MWS Cobra wheels
Sorry should have explained, ET of -16 includes the splined adaptors, so based on the Mx5 with a std wheel of et 45 they stick out 60mm plus half the difference between the rims (5.5 vs 6.0") so 67 mm in all. :smash:
31 Oct 2014, 7:03pm
Ah, that makes more sense and reduces the extra 'poke' to between 18 and 41mm compared to 'standard' wheels. That should be a lot more manageable. :)
19 Nov 2014, 9:56pm
Some Progress
Sanding, filling, more sanding, more filling, and a splash of paint to see how its going. Then more sanding, more filling, even more sanding.......
20 Nov 2014, 12:58am
Good to see the finishing underway. What of the door window frames ?
20 Nov 2014, 8:40am
Frames are looking good in the last picture. Is this the finalised version?
I'm looking forward to coming down to see the end project.
20 Nov 2014, 8:59am
Oh, that's starting to come together nicely now. Can't wait for the next update. :)
20 Nov 2014, 9:07am
That looks great!
20 Nov 2014, 10:05am
Wow, again.
20 Nov 2014, 7:59pm
Can someone tell me if this is just a one off for Geoff or will it eventually be a kit?.
20 Nov 2014, 8:13pm
Good evening , kits will be available , suggest you give Chris a call for more info , Geoff ,
20 Nov 2014, 9:11pm
Chris & Dan - I think this is shaping up to be your best kit yet. :cool:
Keep up the good work, Paul. :)
hurnleft - Welcome to this forum.
Sorry I meant to ask your steering wheel / air bag question over here and then completely forgot. :rolleyes:
21 Nov 2014, 9:02am
Paul L,
Hi again, as is often the case with a question such as 'can I legally remove the air bags (and some other modern stuff) to fit a wood rim steering wheel and make the cab of a Z3 look older, there are many variations of reply and the water ends up very muddied. I'll speak privately to Kevin Rooney when I'm nearer to getting started to get his answer.
A friend of mine had a customer's Bertini in yesterday so I went to look at the concept of a Z3 rebody, although I'm not interested in that actual model. I like the idea and am off to look at a 2.8 Z3 today. If that's ok, I'll be ready for when the 250 kit is ready.
21 Nov 2014, 12:19pm
I hope so
And here is how I did it
http://www.madabout-kitcars.com/forum/showthread.php?t=4917
The airbag sensor is located just in front of the gear stick and when you remove that the warning light on the dashboard goes out. On mine there was no passenger airbag fitted .
21 Nov 2014, 10:19pm
WCA Very nice interior.
I've just put a deposit on a Z3 2.8 manual so I'm getting prepared.
24 Nov 2014, 9:24pm
Working my way around the car prepping for the moulding process, I have always thought the "shoulder' of the rear wing could be improved upon. So before it was too late, out came the grinder.
25 Nov 2014, 12:13am
That looks do much better, great idea Chris
25 Nov 2014, 9:51am
Chris nice attention to detail , Geoff .
25 Nov 2014, 8:42pm
Thanks Geoff. Her's some more detail:
29 Nov 2014, 8:20pm
The devil is in the detail :smokin:
It's coming on nicely. Good job
30 Nov 2014, 8:48pm
Looking really good. I'll speak to you during the week about coming down.
