WCA - Build thread 3
15 Jul 2014, 8:57pm
Evening Nick the horn push is really well hidden!
It is actually a wire hanging down behind the steering wheel with an on off switch that I have to touch against the metal sterring column to activate.
This might get changed when I do the interior
22 Jul 2014, 8:20am
Stuck at home alone last night I started to wonder what I could do to answer the lower problem on the Barchetta. 200bhp is fine for pootling about but feels somewhat lacking when I press on.
Obviously I have promised the wife not to spend any more money on 'that pretty but pointless toy' so I didn't read this thread : http://www.zroadster.net/forum/viewtopic.php?f=15&t=17281
and definitely never googled this page : http://www.partsworldperformance.com/chevrolet-ls3-engines
22 Jul 2014, 10:31am
Yes those crates engines and gearboxes are good value especially as they include most of the ancillary bits you need. may turn out to be the cheapest part of a conversion though once you factor in suspension, brakes, etc. How about a chipped Z3M base car and have your body parts swapped over. That's what I'd do because the chassis would already be sorted to match the power.
22 Jul 2014, 10:54am
The weight isn't too bad so no need for major changes to suspension and my shocks could do with changing anyway.
Brakes are interesting upgrades. Again there isn't much weight difference so the mass is the same. I will be mainly on public roads so the speeds won't be above what the 2.8 is capable of, I just might be getting there a bit quicker. Might get away with just sticking better pads in the standard unit.
Chipped and supercharged donors have been considered but I do like the grunt of the V8.
I used to have an Honda Integra Type R which was incredible between 6,500rpm and 9,000rpm and I loved the engine but you had to work to keep it on the boil.
I now have the supercharged Merc and it is just 'press and go' at any speed and any situation. Watching the traction light flicker as it kicks b=down at 90mph, on a private track of course, always makes me smile just before I get pinned to the seat.
Also thinking a second hand engine rather than box fresh to keep the prices down. Really depends on what the money fairy leaves tucked down the back of the sofa.
22 Jul 2014, 11:55am
Have you measured the wheelbase and track on the Merc and checked if the body panels unbolt?
22 Jul 2014, 12:57pm
A change to M50 inlet manifold, M3 exhaust manifold, remap, and CAI is supposed to liberate an extra 40bhp for around £600 if you can do the work yourself, so not too shabby.
Lots of info about supercharging M50 and M52s here:
http://forum.e46fanatics.com/forumdisplay.php?f=41
22 Jul 2014, 1:17pm
Yes
Twice
22 Jul 2014, 7:07pm
Have decided the V8 conversion is best attempted AFTER i learn to weld. Don't hold your breath. It might be a different car I do it on by then, or a supercharger kit...
22 Jul 2014, 7:21pm
Er. I would prob look supercharger if your going for acceleration at all revs. weight differences might swing it as well. V8 lump will burble well. :-)
22 Jul 2014, 7:26pm
Checked out (a lot of) forums and the LS3 fits in quite nicely and actually moves the weight back inside the wheel base. Easy power up to 400 with hot cams etc. Cost is surprisingly close to engine swap if you ignore the work involved.
You can wring the last few tenths out of an engine of get a bigger one and leave it unstressed and running happily for longer.
At least that's the theory
22 Jul 2014, 7:33pm
Would a lexus v8 rev higher than say an American v8. Few more valves per cylinder. I don't know much bout engines but theirs lots of options. Or an audi engine. Small block, big block. Aluminum or other.
22 Jul 2014, 8:06pm
Lexus has the advantage or being cheaper but I will check out the Audi as I hadn't thought of that.
I need something short, light and capable of mating to an auto box. Hmm Mclaren...
22 Jul 2014, 10:11pm
Isn't the lexus 250bhp? Hardly worth the effort, the audi not much better unless you find an rs version.
LS all the way, plenty secong hand, you will have to import it though.
The supercharged jag/rangie engine is a possibilty too, 400bhp would work well.
22 Jul 2014, 10:38pm
I know someone who has a Maserati 4200GT V8 engine with flappy paddle box attached for sale for £2k...
23 Jul 2014, 2:11am
My wife's daily drive is a Lexus sc430 4.3 v8 vvti auto (they all where) remapped to approx 350bhp if you require any measurements or pics let me know. Its silky smooth super reliable and lots of grunt, gearbox is a little old fashioned and lazy on them and the engines run very very hot , with the roof off sometimes you can feel the heat off it. If you go down the lexus route go on some drift car sites they fit all sorts of goodies to that lump and interchange torque converter's from skylines.What I would say though is with the traction control turned off its virtually impossible to set off without wheelspin even if you try to be gentle, and it has very wide tyres . you may go to a lot of expense and effort only to find you have made an un drivable car. Personally I'd stick around 200 HP and ring its neck rather than over powered and under tyred. Ed.
23 Jul 2014, 1:07pm
Just been chatting with someone who has a 350 V8 and a man that can make it fit. Just need confirmation that it will really fit and get a price. I will wait until winter to do it but I think it might actually happen...
23 Jul 2014, 6:05pm
Chevvy 350, how can you think of dropping in a cast iron pushrod V8 into an Italian style replica?
23 Jul 2014, 7:34pm
I tend to agree with Landmannn.
An awful lot of BHP will be wasted just dragging the cast iron lump around. The handling would be awful round bends, but americans don't really care about bends much, its straight line stuff with them.
A well set up 2 litre Cosworth turbo engine, putting out around 380 BHP would wipe the floor with with most american powered cars, and be much more suited to your car WCA.
In fact there is a company that sends a Rover 25 down the strip at Santa Pod with a Rover T16 engine (2 litre) which puts out 900 BHP yes 900!.
I really think the way forward is lightweight european engine, well sorted. But of course its your car, and your choice in the end,
and more importantly, your cash!
23 Jul 2014, 7:52pm
Agree about the weight, still considering options.
I have a real soft spot for V8s though and the M5 V8 doesn't fit a Z3 because its sump and stuff is the wrong way round.
Looking for a small leight V8 ain't easy.
Anyone got views on the Lotus V8. I haven't googled it yet but seem to remember they were compact
23 Jul 2014, 7:55pm
I agree with earlier comments and put the body on an M roadster. Trust me, what looks cheap to start will cost you an absolute fortune!
23 Jul 2014, 8:03pm
Still tempted by the Maser unit Mr Towed mentioned
MrTowed - I have pm'd you
23 Jul 2014, 9:28pm
If WCA isn't interested would you mind p'ming me the details.
Thanks
23 Jul 2014, 9:35pm
Surely with the complexity of fitting any v8 into a z3 altering a sump to fit a BMW v8 is of little consequence to a good aluminium fabricator.
Take a look on American sites to see what they're doing with Toyota/Lexus v8s. Appears to be lots of potential for power. You like autos so a gearbox shouldn't be a problem.
The LS range has the advantage of being very small compared with 4 cam motors. If you can afford it, it must be the engine of choice.
Whilst a Maser engine would be wonderful in your car I think it has a transaxle so won't be suitable unless you can mate it to a conventional gearbox.
No idea about the Lotus, again other than gearbox compatibility.
Stick an LS in it
Picture courtesy of hasanmotorsport.com
http://hasanmotorsports.com
23 Jul 2014, 9:58pm
The americans have put ls engines in the mx5. I checked this out, the fitting kit including exhaust, engine mounts, radiator etc came to $5k.
Having dropped an ls (lq actually) into my off roader, the costs ramp up to several thousands to finish the job off correctly. I dare not mention how much!
Don't get me wrong, a decent engine transplant is really worth doing, but don't expect it to be cheap.
In terms of bang for your buck super or turbocharging may sound expensive at face value but will probably work out the cheapest in the long run.
23 Jul 2014, 10:02pm
Have now pm'd those interested in the Maserati motor. :)
