Mac - Thanks for the foam feedback, I might just get some plastic end caps for the frame's box section.
The new welder seems to be working well, I just need to get used to the new settings required.
The Shadow - Cheers, I learnt a lot from the detail in other builds, so wanted to do the same here.
There are certainly challenges with working outside & given the choice I'd take a warm garage every time.
But provided you accept that everything takes a lot longer, it is possible to make progress.
One thing to remember is that the new Spitfire based Ribble Navigator is a long easier to build than this.
Similarly, the Miglia is also straight forward, whereas
Micky1Mo's new kit will be a real test of skills.
There were less that 20 Cordite kits sold before production stopped and the new version was developed.
Again, given the choice, I'd prefer an easier build, but I've learnt a lot doing it the hard way!!
Managed to get quite a bit done today, so here is a summary grouped by activity...
Painting:
All the repair work is now done on this section of the bulkhead, so time for some black.
Before:
After:
The "front" side of the recess panel doesn't look too bad now after a first coat.
The "back" side of the recess panel was given a rough sanding & coat of primer.
Bulkhead Holes:
I am leaving these 5 holes as they are for the moment.
The 3 vertical ones on the right were originally for (top to bottom):
- Heater Control Value Cable
- Choke Cable
- Screen Wash Hose
The 2 horizontal ones on the left appear "surplus", as my 1500 donor shell didn't have them?
I just need two of them, one for the choke & one for the heater control.
However, I wanted to switch the choke lever to the right of the steering wheel.
( Personally I found it a pain having both the ignition key & the choke on the left. )
Plus I haven't finalised the layout of the heater yet.
Once I know what I am doing, I will weld up 3 of the holes & finish painting this area.
Bulkhead Repairs:
The next area I have to tackle is on the drivers side and is a real mess.
It doesn't look too bad from this angle, just a small oval hole to patch.
But the real horrors are here.
I want to use some box section as an external "brace" for this whole area.
In keeping with my recycling tradition I found some "spare" box section to use...
Also by cutting up the Cordite bulkhead I am committed to making this Spitfire bulkhead work.
With a few sections cut out, this is the general idea of what I have in mind.
But more on that later as I started with a simple patch repair.
Then it was time to start building my support structure.
With a bit of luck I will finish this off tomorrow as the weather closed in after dark.
( Thankfully I was able to pack everything away for the night just before it rained. )
The box section will start at this end of the bulkhead.
But I have now cut this outside section of metal off.
It was only a few inches wide and I will replace it with something similar, but running the full length of this side section.
I also started cutting the worse of the rot out.
The small square in the middle of the hole is attached to a bracket in the pillar above.
By now I was working under spot light & decided to clean this up when I could see properly.
Getting this mess repaired to a good standard will be a big test of the skills I've learnt so far.
( Which is why I started with the more simple repairs first. )
Hopefully I'll have another update tomorrow, cheers, Paul.
