Only managed to crab an hour outside just before darkness fell.
But it was still enough time to make a start on my bulkhead.
First job was to take a series of "before" photos.
I will post the "close ups" when the relevant section has been tackled.
But here is the overall look from the front and back.
I remembered Mister Towed (AKA "The Oracle" :icon_wink
mentioning his bulkhead cracking when it looked like this.So I wanted to brace the two sections at the back to remove any flexing when moving this around.
I couldn't do this while it was still on the chassis as the prop. shaft was in the way.
( Well, I suppose I could have built a "bridge" in the brace, but that seemed a bit OTT. )
Instead I measured the distance between the two sections while they were bolted down.
Then it was simply a case of removing paint to leave clean metal along the edge.
Then I could clamp a length of box section to one side and weld it into place.
With that side welded, I could clamp the other side and check the gap.
Then it was simply a case of finishing the welding and job done.
It is amazing how big a difference this actually made, the whole thing is now very solid.
Thankfully, I only needed to tack it in place as obviously it will be removed before re-fitting.
I knew the current reel was almost out of welding wire & I have a replacement ready to go.
So I was very happy to see I got the job done with mm to spare.
Then I started preparing the area around the original heater mounting with my angle grinder.
As it was dusk, the sparks were pretty impressive in the fading light.
Before:
After:
The micro heat that Mr T used sits inside the bulkhead, so I don't need these heater holes.
Although I still need to work out the routes for the radiator hoses, so I'll be leaving them for now.
There was just enough time to make some cardboard templates for my first repair patches.
Note: The two smaller circles are for the holes associated with the wipers & screen wash.
I'll cut them out of metal tomorrow, reload the welder and then start the repair work.
