peterux wrote:
Hi Mark,
thanks for your input.....
Faulty servo? - well I guess it's possible but it passes all the tests suggested in the MBM troubleshooting guide. Others may be exactly the same but not obvious because they have disk brakes at the back.
Pressure reducing valve to rear brakes - yup, got one of those fitted. It is the BMW one that's always been fitted. Brake testing yesterday proves the fronts break traction first so I think this is working OK
Too much vacuum? - don't know?
Manual adjustment of brake shoes - I can back them off but they have self adjusting mechanism so they will just reset themselves.
If you search for 'bake pedal return spring' in eBay you do get lots of items so it does seem like most car makers (inc. BMW) fit pedal return springs to pull the pedal back. As these servos come from the US I expect US cars have big heavy pedals and strong return springs.
Maybe the servo just needs a little help?
I am sure you should not need a return spring, and really would not recommend exploring that route. There appears to be a fundamental problem and as it is your brakes, should be 100% resolved, not masked over.
From your description it sounds as though you have eliminated the pedal, and the pedal clasp connection. Since the problem is resolved by pulling the pedal back, this suggests it is not the brake M/C - it would still stick if that was the issue. Therefore you appear to have reduced the issue to being servo related.
Stupid question - but get the easy ones out the way first - have you fitted the anti return vacuum pipe valve, and is it the corect way around? I guess it must be, but.......its an easy one to look for, and could cause the same symptoms?
Next would be to try using a dome head 6mm stud without your tube as Dennis has suggested, since that is different to everyone else. I guess if it is a snug fit it may not allow the servo to re-seat the vacuum arrangement and it is an easy one to test.
If the problem persists you have reduced it to only the servo.
I currently have John's servo, so could post it to you (I'm sure John will not mind - he's up for helping a good cause!). You could then test it in your set up.
If you would like to try it, PM me your address (I have deleted all my Servo PMs now), and I'll gladly forward it on today. And if this solves the problem, you can keep it, and I'll order an extra one as a replacement later this month in the second batch.
Mike
