Side repeaters fitted fine but managed to pull one of the wires loose.
That's okay, just whip off the little front wing and stick a new connector on.
The bonnet will not open! All that opening and closing over the weekend seems to have bent the lever that pops the bonnet so that it no longer pushes the catch fully open.
My bonnet is now locked closed :-(
I will spend the next maintenance period scrunched under the car with a big screw driver trying to get it open
When you finally do fix it, it may be worth installing another cord internally as a fail-safe, that you can access from only you know where? I have done that in the past with great success.
Still not open but at least all the dirt and crap that has fallen out while poking and prodding should lighten the front of the car up and counteract the effect of the re-enforcing weight
People are talking about $800 work at a garage or cutting out things and the main point of access appears to be through the kidney grills at the front which I don't have. If I work out a solution I will photo and write it up.
Your best bet would be to pop out your corner signal light and pull on the black cable - Another option not open to me!
The outside of the car is good now - except for that fact that the rear needs fixing after being remodeled by an inattentive Kia driver - so I thought I would revisit the interior.
Chris told me at Stoneleigh that the passenger airbag wasn't fitted to the UK spec cars so I had a little look
He was right, all that was there was a hole. I thought that would be about right for a glove box if I fitted a liner and a hinge. If I did that I wouldn't need the standard nasty plastic one. A few people had commented on the comedy clock so I was already thinking about revising that bit.
Anyway, one thing led to another and this happened
I will now be thinking about how to create a new interior to hide the wiring and modern switch gear but maintain the functionality such as electric hood, heated seats and air conditioning...
Started trying to understand the electrics a bit which meant kneeling on the carpet in the passenger foot well. There was a damp feeling down below, good with a woman but less si with a car so I took the carpets out. This gave a better view of the wiring
Hi mate, dash is really starting to take shape and looks loads better.
Would you be able to help me do some of those overlay sketches you did for your original concept? I have a genuine Lotus Europa body and want to overlay it over an MX5 or Mk2 MR2. Any help much appreciated mate.
