Swifty's Navigator
5 Oct 2015, 7:02am
great finish - excited to see it on the road
12 Oct 2015, 7:02pm
Next stage of the car paint job was completed at the weekend after the whole body was blocked off with 2000 grit, definitely not one of my favorite jobs, a few pin holes became apparent after the blocking so i back filled with very fine filler then flattened off again.
First another two coats at 50/50 were applied then one coat at 75/25 and finally 90/10 that's 90% high gloss thinners and 10% paint although it difficult to spray at this viscosity it gives a fantastic finish.
Most of the slight orange peal effect has been taken away with the last two coats and a high gloss surface is left behind. There are a few dust particle's in the paint which will disappear with 2000 grit wet and dry with a small amount of soap added to the water for good measure, but all in all i was very surprised at how well the whole paint job has turned out, now i just have to wait at least a month before i block the whole body again for the last time.
Ordered the paint for the interior to hopefully finish all the spray painting off for this year.
Attachment “IMG_6254.jpg” from the original forum could not be reliably recovered.
Two seats arrived which i have to make a couple of mounts for to suit the build as the factory mounts would be unsuitable.
13 Oct 2015, 7:37am
Swifty - Your paint looks great. :cool:
Were the pin holes in the initial coats of red paint?
If so, do the areas with the filler added need extra coats of paint to cover them?
Your new seats look good too.
13 Oct 2015, 7:39pm
Paul The pin holes were in the high build primer which i had missed when flattening the primer but after flattening the painted surface they became visible, should of done more flattening of the primer i think. I decide to fill each pin hole with a very fine body filler then flatten off before the final coats of paint were applied, not sure if that is the correct way to deal with pin holes but its the way i decided to go down.
The seats where a little to high (it looked like noddy was sitting in his little red car) so ive had to cut the top floor away and make the usual recessed floor pans so that the seats are now angled back over and 70mm lower.
In the previous post showing the seat in place you can see that the back of the seat is higher than the rolled edge so by cutting the top floor away has dropped the seat back to below the rolled edge and also makes the hump surface fully visible.
13 Oct 2015, 8:29pm
Thank goodness for that, I wasn't going to say anything but you would have found driving it very uncomfortable with the seats so high. Good decision. :)
13 Oct 2015, 8:35pm
Seats look nice btw, very similar style to what I put in mine -
Where did yours come from?
13 Oct 2015, 8:48pm
The seats are made by OMP classic silverstone race seats.
I totally agree with you Mr T the driving position before the floor mod was done was too upright but now with the raked back look they are that little bit more comfortable although getting in and out will be a challenge especially with wet feet, will more than likely carry a piece of carpet around to place on the seats to get in and out with dirty feet etc.
15 Oct 2015, 9:16pm
Come across this site which may be of help in clarifying a few grey areas in a build http://www.motester.co.uk/mot-guide/. One point I was interested in was "does a seat belt have to have an E mark" , there is no mention in the guide of E mark required.
16 Oct 2015, 7:40am
Getting in and out is very straightforward Swifty, not as difficult as you'd think. You do need to stand on the seats unless you're as flexible as a double jointed snake though.
I bought a set of Herald/Vitesse tailored mats (similar to those below). I use the fronts as intended but the ones meant for the rear footwells I use as seat protectors to step onto when getting in and out. Worth thinking about. :)
http://www.ebay.co.uk/itm/Grey-Triumph-Herald-13-60-01-1967-to-12-1971-Tailored-Car-Mats-/331674357792?fits=Car+Make%3ATriumph%7CModel%3AHerald&hash=item4d39551020:g:coEAAOSwKIpWE8GV
16 Oct 2015, 8:12am
Any more pictures Wharfedale? Car looks finished, are you on the road yet?
16 Oct 2015, 9:05am
Fitment and markings on seat belts is covered in the Construction and Use regulations, which legally trump the MOT testers guide -
http://www.legislation.gov.uk/uksi/1986/1078/regulation/47/made
Paragraphs 4 and 7 cover e-markings.
As for whether seat belts need to be fitted and whether they should be three point belts or lap belts, Regulations 46 (above) and 47 apply -
So, any vehicle 'first used' on or after 1st January 1965 but before 1st April 1981 needs a driver and passenger seat belt, but that can be a lap belt, while it's got to be three point belts for vehicles first used on or after 1st April 1981. Pre 1965 and no belts required.
Personally speaking I wouldn't run with no belts or a lap belt as my life was saved by a three point inertia reel belt in 1983...
16 Oct 2015, 2:35pm
sammio
yes its been running since april I postred some pics on 22 May under sammio (thread)
5 Dec 2015, 9:35pm
Wow how time flies, its been nearly eight weeks since i last did any work to the car.
Today a little progress made i cut the floor away for the seats to sit lower and angled back over, will post pictures tomorrow.
Ive also bought another project, a 25 year old piece of British history that will hopefully increase in price.
Well that's it for today see you all soon.
6 Dec 2015, 7:48pm
Pictures of the floor mods to accommodate seats.
Attachment “IMG_6267.jpg” from the original forum could not be reliably recovered.
Panels sealed in place. Will used truck bed liner for the floor, applied with a roller to hopefully give a textured finish.
The seats are to be held in place with two bars fabricated to replicate the angled floor with fastening bolts at each side of the seats.
See you all soon, hopefully.
8 Dec 2015, 8:21am
Swifty - Nice work (as usual) on lowering your floors. :cool:
The photos above also highlight what a great job you have done on the cockpit sides too.
( Especially when compared to the plywood jigsaw puzzle I'm making. :rolleyes: )
This really will be a stand out car when it is finished.
8 Dec 2015, 9:42am
Its really looking like a proper classic race car
Any pictures of the whole car have you fitted lamps etc?
8 Dec 2015, 6:44pm
Cheers Guys.
The car is still up an the axle stands so no pictures of the whole car just yet, it wont be off the stands until all the body work is flattened off as the extra height make's the rubbing down easier, less strain on the back.
Probably one of the last major buys for the build arrived today a 120mm tacho.
19 Dec 2015, 9:32pm
I thought i would take advantage of the unusual warm weather and prep the interior before hopefully spraying tomorrow that is if the temperature stays above 10 degree's.
Seats firmly attached to the floor with the gearbox tunnel and prop shaft cover fitted for the last time before painting commences in case any adjustments were required.
Masked off the areas were no paint is required. First i will apply two coats of etch primer to all the interior followed by silver cellulose on the sides, front bulk head and rear bulk head with black truck liner to the floor panels. If the black does not look right then i may give it a coat or two of the silver cellulose, that is if it does not react with the bed liner so will do a test panel first.
May apply the bed liner to the floor with a roller to give a texture finish.
20 Dec 2015, 8:47am
Interior is looking very period indeed. Nice.
20 Dec 2015, 5:17pm
Looking forward to seeing the interior painted. :cool:
20 Dec 2015, 5:45pm
Today put two layers of etch primer on then four layers of cellulose silver, it wasn't the easiest of parts to spray due to the tube section in front of the ally back panel and trying to get an even coat as was possible, consequently Ive a couple of runs on the back panel to sort out once the paint drys.
It does not look to bad, next the floor will be painted in bed liner that is once the silver paint has gone off so that masking tape can be put along the side edges.
20 Dec 2015, 5:56pm
Swifty, that looks great the attention to detail and quality of your finishing touches is going to make for an awesome finished product. Can't wait to hopefully see this at a show or two next year!?
20 Dec 2015, 6:12pm
Cheers Mr T and Jones. I am trying to create a build of deception, that is to make what is basically a cheap kit look like a period car and to hopefully have people wondering what it is and it's true age, but time will tell.
20 Dec 2015, 6:59pm
Waaaay ahead of you :)
