Garyh's Sammio build
7 Oct 2014, 8:15am
I must try and finish jobs in order, so i made a new pin for the leaf spring - now down to 4 leaves/1" block/middle hole on wishbone hangers. I was really pleased how my floorpans came out, just need to weld corners up and puddle weld in place. But i will finish suspension first.
13 Oct 2014, 11:46am
If you were buying an mx5 engine do you need the ecu etc...
24 Oct 2014, 8:38pm
Just put a bid on an MX5... will findout tomorrow night when i get home.
28 Oct 2014, 8:58am
Missed that one... i can get an engine gearbox and loom for £300 delivered?
28 Oct 2014, 5:05pm
Gary - Good luck in your quest for an engine, it will be interesting to see how the MX5 unit works out. :cool:
3 Nov 2014, 9:25pm
Cheers Gary, some nice classic car bits, will add this to my bookmarks.
4 Nov 2014, 3:53pm
That's who I got my gearbox cover from. Quality was fine and the price was good too.
Mac
29 Jan 2015, 10:42am
3d printing.
29 Jan 2015, 1:38pm
Cool name Gary, ive been considering getting a couple of name plates 3d printed or lazer cut stainless plate, are you leaving the colour as is or coating in another colour.
29 Jan 2015, 2:09pm
Hi Swifty, Triumph will be silver and italia will be an ivory white.
30 Jan 2015, 11:25am
Trevors old car up for sale.
30 Jan 2015, 11:51am
Its not Trevor's old car (No 48) thats for sale they have just use a photo of his car as the primary picture.
The actual car for sale is in the later photos, although the same colour it's a totaly differant car :eusa_whistle:
The current owner of Trevor's old car lives locally and was a bit up-set with what they have done :rant:
That said it is a very nice photo of a Sammio Spyder, would look nice on my web site :wink:
30 Jan 2015, 9:20pm
Gary - Nice use of 3D printing. :cool:
8 Feb 2015, 9:56am
Driveshafts are fitted.it was my first few hours back on the car, yesterday...
8 Feb 2015, 6:47pm
Your chassis and components look great what paint are you using? Por15?
8 Feb 2015, 8:01pm
Evening J, yes POR 15, ral3005 enamel and Lead grey engine paint.
8 Feb 2015, 8:40pm
I'm not sure if this is the right rack? Also, the solid clamps don't have a locating hole?.
9 Feb 2015, 9:06am
Looks great and a big morale boost to get to this stage. Just had a look back at your first posts to jog my memory as to how yours started and from those first pictures it has been a fair journey to get to this stage. With the better weather coming I hope you can find the time to keep plodding on. This is going to be some car once finished. Well done.
9 Feb 2015, 9:25am
Are the black diagonally slotted plates needed with the solid mountings? My recollection is they are used to tighten up the rubber bushes, by clamping them against the rubber while tightening the clamps. My reading of this is that they aren't needed with solid rack mounts.
9 Feb 2015, 6:42pm
I made a big mistake by placing the black plates under the rack instead off under the chassis where they belong.
I could shift the rack from right to left by turning the steering wheel.
Don,t know about the alley mounts...
Looks as if your rack is different to mine and other Herald racks i,ve seen so far.
Great job!
9 Feb 2015, 8:23pm
When fitting solid rack mounts you MUST either refit those plates or something else to stop the rack shifting from side to side as you turn the steering wheel.
I've pretty much kept this to myself due to the embarrassment factor, but when I fitted aluminium rack mounts about a year ago I left those plates out (not sure why).
Everything was fine - I took it for a blast along the narrow winding roads along the North Norfolk coast with my better half in the passenger seat - and we stopped for chips at Wells Next The Sea. Lovely.
When we set off for home, however, I pulled away from the roadside and turned the wheel, but the car kept going straight on. I stopped and then found that I could turn the steering about half a turn either way with no movement on the front wheels at all. :(
Taking a look underneath with wifey twirling the wheel I could immediately see what the problem was. The engine had leaked a bit of oil onto the rack mounts, lubricating them nicely, and breaking the friction that'd been the only thing holding the rack in place within the mounts. As I had no tools I had to call the RAC, and the man with a van came up with a simple solution and fitted a jubilee clip to each end of the rack outboard of the mounts, effectively filling the gap and keeping the rack where it ought to be.
The consequences of the rack working loose to the extent it did if we'd still been thrashing along those winding back roads doesn't bear thinking about. :(
That was supposed to be a temporary fix, but it's still there now and passed its last mot with them in place, so it can't be that bad, but I really ought to put those plates back in. If only that didn't need the engine lifting off its mounts...
