If you want to save "countless " hours prepping old wheels ready to paint, you can't beat having them shot blasted and powder coated . So many companies are doing it now, I bet there are several in Gloucester.
I'll be painting the rims silver and the nave plates in the main body colour, which will be a very dark green. If I can find my source picture I'll post it.
Regards, Mick
Here we go, I'll plump for a darker green, maybe BL Connaught Green, and flare the gold out around the nose .
Today, whilst pondering next steps and waiting for goodies from postie (no luck ), I decided to bite the bullet and remove the rear body. First job was to drill out the ten 4mm pop rivets securing the moulding to the frame. Attempting to lift it off resulted in zero movement - examination beneath revealed blacksmith style tank supports similar to the rear lower seat belt mounting one. To get the necessary access I jacked the back end high enough to get axle stands on their top setting in place, left the jack just touching the diff. and put a ratchet strap under the roll bar and over a roof beam for full belt and braces effect.
After a realistic effort at dislodging it, I felt comfortable with worming underneath armed with my decades old B&D angle grinder. The ends of one support, which looped under the tank, were fairly easily cut through (one side's biscuit strength weld to the frame parted under gravity), but the ends of the second, which ran across the tank's back, and was glassed and welded to it, were all but inaccessible. Persistence, and only one shattered cutting disc, eventually paid off . With assistance the moulding, c/w tank, was carried to join its GRP fellows tucked behind my front garden fence. The supports were then removed and the now completely skeletal rolling frame put to bed.
I think I'll now go the whole hog and take off the ally sides for my next small step.
The super-helpful BT Openreach guy (who saw the Phaeton bodywork and told of his building a Melos in the 80s!) has just departed having fixed the strangled connection problem. Hurrah!.
So, in the last few days, since returning from my long weekend volunteering at the Adventure Travel Film Festival, I've been busy with drill and cold chisel attacking the myriad pop rivets attaching the ally sides to the frame. She's now a true skeleton .
I have quite a shopping list of bits and pieces so will be hitting Ebay next after my enforced absence.
Yesterday, the first of my Phaeton related Ebay purchases arrived. The bushes are for the front ends of the leaf springs. The vendor listed them as Mk1 Escort but luckily included the dimensions which match Mk1/2 Cortina. I decided to go for round 7" headlamps rather than my preferred rectangular 2CV as multiple searches for the mounting bar proved fruitless.
The postman interrupted my fettling the Monaco in preparation for Saturday's Gloucester Goes Retro. The weather forecast is good so the turnout of cars should match that of previous years.
Postie has just delivered the bushes for the back end of the leaf springs so tomorrow I can get my hands dirty .
Just found you. I have been away a while. It's great to see your progress. Long covid is still slowing me down. Early specials were a bit iffy, Dexion was quite useful for structural things. and domestic wire often used.
Hi Dpaz, didn't realise you'd been laid low, best wishes for a full and speedy recovery!
Hi redratbike, when I tow the frame over to my welder for engine mountings, I'll ask him to put a blob in each side panel rivet hole as I'll be fitting new ally. I'll keep the GRP body mounting holes, drill them slightly oversize and use my lazy tongs for appropriately sized rivets.
After the Gloucester Goes Retro shenanigans, I had another camping weekend at The Overland Event near Oxford, so progress has been limited to cutting up my 1 1/2" angle for the seat belt mounting gismo and rivetting it together prior to welding - I need to do it this way as it has to fit very precisely between the frame cross members.
I got back from The Beaulieu Autojumble at about 2000 yesterday bearing my spoils, including, unusually, some car parts amongst the Biggles books and old magazines which I normally snag. I bought a pair of rear Armstrongs, new in their boxes for sixty quid, and a 3 x 2" instrument under dash mounting bracket - the twin of that I fitted to my original Phaeton (nostalgia rules!) for just three .
My internet woes were finally (hopefully) over this morning when I fitted my new fibre-friendly server, filter, and cable: it all seems lightning fast now!
After nine days of displacement activity, which included buying a Mk II Cortina fuel tank (as recommended by TD-W), I yesterday opened a can of motivation and buckled down to some rear end suspension work. I gently jacked up the nearside of the frame until I judged the tension had been taken out of the spring, and set to removing the drop links. They provided nil resistance as I'd long since given all foreseeable fixings a good dousing in dismantling liquid. I drifted out the old bushes then thoroughly wire brushed the eyes and drop links and gave them a coat of Fertan. I'd always used Kurust until I learned that Classic Land Rover owners swore by the former. Nuff said!
It can immediately be seen that the front eye then provided much stiffer resistance... The eye bolt came out easily - its nut is captive to the frame - but the bush's location is masked both ends by it. OK, I'll have to axle stand either the frame or the axle and jack the other until access to the bush is achieved. However, the shock absorber scuppered this plan so I set to removing same. The top was easy but the limited bottom clearance prevented a decent swing of the hammer onto the bolt end. OK, off with the wheel, spacer, shoes etc, then the back plate and half shaft. The bottom bolt steadfastly refused to budge despite blacksmith blows from my lump hammer so I decided to cut off the shocker at its bottom neck, then disc through the bolt. Hurrah, off at last!
I then fashioned a puller from threaded rod, nuts, washers and my biggest socket, purchased forty odd years ago for Mini top swivels, which succeeded in dragging out the metal centre of the bush. By this time the cave was like an oven so I called it a day. I'm sure the other side will prove much easier with the experience gained!
With 'only' the remains of the front bush to remove, I began the day with hopes of good progress. Wrong! I decided to remove the rubber portion by drilling some big holes then levering out the remains. However the bit tore straight in and rolled itself around against the metal sleeve, tearing the rubber away in seconds. I decided to cut a slit in the sleeve with my smallest cold chisel (yet another Machine Mart purchase). Even with the spring clamped to the frame I could barely get the cut started due to its awkward location. I resorted to what I now know I should have done in the first place - remove the spring . With it lying on the concrete slab it proved simple to chop through, bend the edges and knock it out.
Neglected domestic tasks dictated a swift tidy up and a halt to proceedings.
After a busy Friday, I returned to the cave and tackled the remaining doable L rear suspension tasks. The jumbo socket proved the perfect drift for knocking in the front bush, and likewise my home made puller for the rear ones. I ran a die down the U bolt threads before refitting the spring to the axle. It was a bit of a fiddle as they had spread a little and needed to be compressed parallel for fitting the spring's baseplate. I used my water pump pliers in one hand whilst slipping on the baseplate with the other - fiddly but effective. Back on with the half shaft etc. and that side was done, bar the shock absorber, for whose bottom eye I'll need a new bolt.
Learning from my nearside stupidity, I jacked up the offside and whipped off the spring in no time ready for today's efforts. With impeccable timing the nice man then appeared with my Ebay purchased three point harnesses, which look absolutely mint and a snip at fifty quid the pair inc. postage. Result!
The positioning of the nuts welded on as four point top fixings is suspect, unless both he (she?) and prospective passengers were of bizarre morphology. I'll chisel or disc them off for repositioning of the two now required.
I got back from The Beaulieu Autojumble at about 2000 yesterday bearing my spoils, I bought a pair of rear Armstrongs, new in their boxes for sixty quid.
When I built my first Phaeton, (bought new) in the 80s, I already had a scrap Spitfire for the front end gubbins. I bought a running 1300 Mk2 Cortina for 25 quid (those were the days!) for the back end. I'd got to the stage in my current build when fitting the above shockers was appropriate. Imagine my dismay when I discovered that the bottom bracket on the axle took a 1/2" diameter bolt whereas the shock had only a much slimmer bush. I found a super helpful bloke on Ebay who measured the Capri shock bolts he had for sale which proved correct. I bought and test fitted a pair.
The axle, rather than being the Mk 1/2 Cortina item I imagined, turns out to be from a RWD Escort. OK, I'll ask if Escort shocks will fit a Mk 2 Phaeton in a post on the Dutton Group on FB. I got a good few unhelpful replies, none of which answered the question . OK, I'll post again in words of one syllable to see if any other members can read English. No further replies were forthcoming .
So, bottom line is does any of you knowledgeable chaps know if RWD Escort rear shocks are of similar length to Mk1/2 Cortina ones?
[FONT="Comic Sans MS"]Quick p.s. In the interim I've managed to source a Hillman Avenger prop. shaft (it shares its gearbox with the Talbot Sunbeam 930) for 30 quid to be collected from Leics, a nice drive up the Fosseway in the offing . Also, a 4.1 diff (same ratio as that fitted to the 930) for 200, collection from Daventry, an OK distance.
Once my rear suspension woes are resolved, I'm looking forward to fettling the
Once my rear suspension woes are resolved, I'm looking forward to fettling the uber familiar small chassis Triumph front end .
Whilst mentally bemoaning the non-arrival of the shackle rubbers I'd ordered on 25 Sept., I decided to simply re-locate the rear spring pro tem with the bolts only. Seized with a fit of enthusiasm I rolled her backwards and attacked the front end. Everything came apart like a dream, and was stowed in my shed ready for winter refurbishment. I have quite a few suitable new bits and bobs which came with my Mk1 Marlin Roadster a good many years ago. They did come in useful one day!
Next job was to fit the tow bar to my Honda Jazz so I could deliver the frame to my go-to guy of 40 years at Woodchester for all the welding jobs. This was fiddly and time consuming but I knocked it off in half a day. Here's a picture of my famous 'Dutton Towing Gismo' strapped to the frame ready for action. Primitive though it is, I've used it to rescue a good half dozen Phaetons/B Types back in the 80s and 90s when I was mad keen - my longest tow being 125 miles from Brighton. Happy Days.
Anyone dismayed at the ratchet strap attachment will be reassured that this is a first, on all previous occasions I used sundry bits of blue nylon rope...
I'm off to Porthcurno for a week on Tuesday so no updates for a while.
Yesterday, after a few abortive attempts at finding a mutually acceptable pick up venue and date, I motored through the sunny Autumnal countryside to Daventry, about 90 miles, and picked up my 4.1 diff. The vendor had some interesting vehicles: a stock car; a Cologne engined S4 Phaeton; and a Moggie pick-up. After chatting cars for a good while the diff. (in a kindly supplied bin) was loaded into the front footwell whereupon I pootled home well pleased with this vital purchase .
If next week's prop. shaft collection from Leicester goes half as well I'll be delighted.
I had a diff failure on my Rickman about 4 years ago. I slowed for a speed hump on a private road, and there was no drive. Car was in gear ..... Hmm... I got out and looked underneath to see the prop turning merrily
After the AA collection I got home and jacked one side - turned the elevated road wheel and the prop turned. repeated with the other side and the same happened. When I removed the prop and diff I half expected there to be a few bits falling out, but it all looked good. With no real load on it the oil stiction must have been enough for things to turn as if normal when I tested it. I scoured the Country unsuccessfully, and then a very helpful Old Ford specialist directed me to a Rally restorer just 2 miles away from me, who I'd never known about. He promised a replacement the next day. Further inspection revealed all 6 ring gear retaining bolts were broken.during which time I'd ascertained the existing one could be fixed with some new (same as flywheel) bolts. I still bought the replacement as it would have been morally wrong to refuse the purchase. The Rally Specialist had never seen such a failure despite the huge BHP they put through their diffs!
After spending a good deal of fruitless time on various websites and FB groups I decided I should bite the bullet and buy likely looking rear shock absorbers 'Returns Accepted'. Serendipitously, after a chat with my super helpful independent parts supplier - a Mk1 Capri fan - I ordered a pair for that model and they fitted perfectly. Bingo! Excuse the wobbly low light picture, the best I could do at dusk.
In a fit of enthusiasm I also lashed out 124 quid on brushing enamel: 2.5l of Goodwood Green and 1L of Bahama Gold. I plumped for this thoroughly retro option as I also brush painted my first Phaeton - Retro Rules! 'The Look'.
These rather uninspiring bits of decades old metal lurking on my workbench in the late Autumn sunshine are, in fact, the holy grail! They're the engine mounting brackets which bolt to the sides of the Imp derived engine, and to which the rubbers are attached.
My search for these elusive items began with enquiry of the Hillman Avenger Talbot Sunbeam HATS cars FB group, which drew a blank, but threw up a link to the FB Talbot Sunbeam and Avengers parts group. A little lateral thinking by a member brought the suggestion that I should try the FB Hillman Imp group, as the Sunbeam engines lend themselves to conversion back to their parent, and someone might have a pair of now redundant brackets high on a dusty garage shelf. This proved to be the case and a super helpful chap in N. Ireland not only dug them out, but posted them to me 1st Class for a very reasonable sum. Result!
With only the prop. shaft (for hybridising) left to collect next week, and a compatible speedo, which I'm tracking on Ebay, major parts sourcing difficulties should be largely over - famous last words!
I'm off to the Classic Car Show at the NEC on Friday where I can touch base with possible helpful contacts.
Yesterday I pootled up the Fosseway for my long-delayed collection of the Avenger prop-shaft I need for mating to my gearbox. I have to say that the vendor, with whom I've been in internet correspondence was, as miserable gits go, right up there, even face to face. Still I got the necessary for a reasonable 30 quid, result! It was a 150 mile round trip so, on return, I left unloading and examination for today.
The internal splines were as rusty as the rest of the prop. and needed a good hour of wire brushing (I had to saw the longitudinal corners off one of those pound shop brushes to get it slim enough) and scraping with a skinny flat bladed screwdriver for them to look half way decent. I next sat the Ford prop. alongside and had a good head scratch.
The U/J spiders and their yokes look to be of similar dimensions so it may be possible to hybridise the original with the gearbox end of the 'new' one. Before I embark on attempting this, I'll have to carefully measure where everything sits (again - I know what I'm like!) to ensure that I wouldn't end up with the gear stick either under the scuttle or my left elbow.
Whilst searching my shed for the old prop., I found the engine mounting rubbers (which were attached to the cross member when I collected all the gubbins). I'd forgotten I had them and had been searching the internet without success for a pair to bolt to my recently acquired 'Holy Grail' brackets. I now have all the necessary for more engine dangling to accurately fabricate the chassis frame mountings.
Well done Mick for sorting all the bits ! At least the internet is there to help find all the parts, it still takes a lot of work / miles and time to bring it all together ! To think that in the 70's, 80's and 90's you could go down your local scrappy and get all the bits in an hour or two for a few quid ! There were plenty of miserable old gits back then too, usually running the scrap yards !
Yesterday I decided to offer up the Talbot Sunbeam cross member again and have another head scratch: after lots more measuring, including some ground clearance guesswork, I concluded that it could be used if positioned under the Dutton's frame. I clamped it roughly in position, tapped it back and forth until it sat correctly, and checked that there was sufficient edge to the mating surfaces for secure welding. I took a rubbish picture in the gloom and called it a day. I will of course get all the relevant bits back to bare metal before taking it to my MIGmeister.
Today I re-checked everything and had a quick panic regarding clearance for the radiator, but my fears were allayed when I remembered that I'd be fitting an electric fan - phew!. I jacked up the front end to a convenient height, secured it to a beam with a ratchet strap, and drilled through the frame and cross member (after yet more measuring). I cut some threaded 6mm bar and bolted through, two nuts locked together and a penny washer beneath, and another above topped off with a split washer and nut. Job done .
I can now do some more dangling for gearbox mounting positioning.
After yesterday's temporary bolting in of the cross member, I today decided to offer up the engine. It seemed that everything was in the wrong place to achieve this . First job was to turn the 'car' around. Whilst it was down the garden, half way through the manouvre, I hoicked out the crane which it had been blocking in. I then had to work the crane around to the other side of the engine stand, which was only just possible with one crane leg up. Taking the engine's weight with the crane I freed it from the stand, which I could then stow away. With the front end of the frame now much more accessible, dangling could commence . I lowered the engine fully down onto the cross member and released it from the crane, having roughly levelled it with my trolley jack under the rear sump.
Measuring the distance from the front edge of the integral bell housing to the gearbox mounting lugs, I could accurately work out if the existing frame cross member and gearbox mounts would be compatible. The jury was out on that one so, as the sky blackened threateningly, I packed up and called it a day, well pleased with my progress.
At first glance it looks like the bulkhead structure is to the left and the engine is in back to front ! Then looking again you can see the girders rising up towards the right of the picture which hold the rear axle in place. Sometimes wonder how Mr Dutton came up with this chassis design, quite unconventional even back then !
