New Instruments from Grassbanks
19 Dec 2021, 9:48am
I think Chris's Z3gt dash would look good in a Kobra. One of the reasons these instruments are so expensive is the style, they need printing on the glass and separate sections inside. Kobra clocks would be so much easier to make, as Grassbank has already done the hard work on the 250 dials the cost of producing the Kobra dials would be far less. A few 3d printed cups, glass and dials along with the same loom.
Or you could use the ETB instruments which will now be much easier to fit as we have the full (and idiot-proof) wiring diagrams. This would probably be the cheaper option and would give you working oil pressure/temperature and volt gauges.
It would be nice to see full interior done on a Kobra, I don't think one has been done yet.
20 Dec 2021, 5:30pm
Cheers S,
I think maybe a spring summer project to finally have a go at Kobra dash. I’d like it to be a bit like the originals which are quite flat. That should help me for space. One day ...
21 Dec 2021, 10:51pm
DaveP wrote:
... like the originals which are quite flat ...
Good luck with that. The first thing I look for in a Cobra replica is the 3-2-1 layout on the centre dash area.
23 Dec 2021, 6:28pm
Lucky@LeMans wrote:
Most Cobra replica's don't feature an original layout for some reason. Most people want a plush interior with a deeply padded dash, the bottom of which extending down to the top of the tunnel. The original Cobra was very crude with a flat dash panel with no padding, a few instruments and a couple of switches !
https://www.classicandsportscar.com/sites/default/files/styles/slideshow_slide/public/2018-03/013_0.jpg?itok=-LiwXeoh
With my skills I should be able to get mine to look as ‘rustic’ as that !
30 Jan 2022, 5:59pm
Instrument update
Well it's been over 6 months since I ordered my instruments, I knew that they were one of the first sets so would have some teething problems but I think 6 months is enough. The repaired instruments have just been returned. Just to refresh your memory
On one instrument the "Olio" script wasn't illuminated, this has now been fixed.
The illumination on the next OLIO gauge has also been fixed and looks much better,
The Aqua gauge was returned as it was only illuminated on one side, this has unfortunately been returned untouched and looks half dead at night, I presume this is because it is fitted with the red hi temp light where there should be an illumination bulb.
I would much prefer the illumination to be correct and lose the red light.
The clock was returned because the casing was smashed. So far 3 of the small instrument casings have been received broken, this is before they have even been fitted, I hope that this is not going to be an ongoing problem. The problem now is the clocks illumination is now much dimmer than it was before.
The extra bulbs and holders that have been fitted tend to flicker if touched, I took the car around the block in the dark and noticed some flickering when going over bumps, this seems to be only on the extra bulbs that have been retro fitted.
So I'm afraid to say that my other car will be fitted with ETB instruments especially as a full easy to follow wiring diagram is now available.
The Grassbanks instruments are the better looking set and I especially like the fact that they do not have the LCD panel in the speedo. They need more work and refining, especially when considering the cost, my last set of ETB were
