Agent Thor - 60s Show Car
24 Mar 2018, 9:10pm
Getting rid of dead bodies is hard work!!!
Nobody wants them!
25 Mar 2018, 5:08pm
Had a good day today, welded in the pan, fixed the jacking point and painted the pans.
29 Mar 2018, 5:26pm
Got the brake backing plates out of the E-Tub & hit them with some etch primer.
Ready to eat somebody!!!
Turned the pan over and cleaned up the underside.
Wonder how the stone-chip paint will hold-up against hailstones ??!!??
30 Mar 2018, 5:21am
Amazing what some paint does to transform a project. :cool:
We also had hailstones lasting down last night too. :rolleyes:
1 Apr 2018, 7:59pm
Installed the rebuilt pedal assembly, what a fiddly job that was!!!
Cleaned up the front beam.
2 Apr 2018, 6:27pm
Quick mock-up for the front friction shocks.
Ignore the: crusty torsion arms & broken ball joint!
Spray can lid will be replaced by 50mm round stock welded to the beam stiffener plate.
Spring on the outside is to maintain tension on the arm.
I'll use 10mm ally plate for the arms.
Not sure if I should go inside or outside of the beam.
3 Apr 2018, 3:57pm
Cleaned-up the front drums.
3 Apr 2018, 7:31pm
Liking the friction shock idea really leans up the beam was this on the original car was Roth’s idea ?
3 Apr 2018, 7:56pm
No, the original car didn't run any shocks.
But interestingly did use one of the beetle torsion bars/beams.
I want my version to be street legal and within the DLA 8 Points Rules.
22 Apr 2018, 7:01pm
Still messing with the friction shocks.
Wasn't sure how the 10mm ally would 'bend' but came out ok.
Think I will change to 6mm as the 10mm looks too thick.
The springs just create the 'link' to the arm.
Currently using a couple bits of cardboard, just foe size, but have an old leather briefcase to cut up.
22 May 2018, 7:47pm
Made a start on shaping the body today.
Vermiculite & plaster in a 70/30 mix.
Its going to be messy!!
22 May 2018, 7:59pm
Where are you based?
As I have a number of large foam insulation panels you are welcome to have FOC.
As they might help bulk out the main shape before you fine tune the details.
This is just a small piece I used to make my bonnet bulge.
22 May 2018, 8:15pm
Love it Colin ...I can see the intended body shape now you have boarded it ... have you already got your bubble top ?
22 May 2018, 8:16pm
Cheers Paul, that's a fine offer!
Unfortunately based in Weston-Super-Mud, so not really practical to collect.
Thanks anyway.
22 May 2018, 8:18pm
Yes, actually have two bubbles , a clear on and a fluorescent yellow one!!!
Going to dig them out at the weekend.
22 May 2018, 8:25pm
Plan on cutting the clear one down like this.
That way it will be 100% road legal & not require wipers.
The other will be 'occasional' use!
23 May 2018, 8:38pm
Well that's about half a bag of plaster and around 15 litres of vermiculite so far.
[img] http://www.madabout-kitcars.com/forum/attachment.php?attachmentid=5225&stc=1&d=1527107721[/img]
10 Jul 2018, 8:56pm
Has been awhile since I posted, but here we go.
3 layers of glass, formed up some of the internal framework, constructed the hinge/lifting bracket.
10 Jul 2018, 10:01pm
Wild! Like it..
16 Jul 2018, 12:44pm
Just about to make a start on the steering, but in a bit of a quandary.
Do you think I could use the original VW Beetle steering box, re-positioned in the centre, although this will require some minor cutting of the floor pan.
Therefore giving me 2 points for keeping the steering.
Would the 'very minor' trimming of the floor pan really be noticed??
16 Jul 2018, 6:50pm
This months custom car has a lad of big daddy Roth cars in it
20 Jul 2018, 10:54am
Top is all sorted and working.
Took the body off last night to install the steering, think I'm going with the original VW steering box, moved to the central location.
20 Jul 2018, 11:05am
Starting to think about seating now.
Initially tried a single 200N linear actuator, just about raised the top, but the motor wouldn't hold it there and sort of 'back wound' and sunk miserably back down!!
So have now gone with two 1500N actuators!!!!
21 Jul 2018, 8:29am
ColinHD – I know Rods ā€˜n’ Sods is having a few technical problems at the moment.
So it is good to see photos of your build on here.
You really are turning your vision into a reality and it looks great. :cool:
