Maserati Replica on Ebay
9 Dec 2017, 10:45am
I can't be alone in thinking that the car that started this thread is absolutely gopping? It looks like a Maserati viewed through the bottom of a dirty pint glass.
9 Dec 2017, 11:20am
Mister Towed wrote:
Unless you already have one though it's going to be difficult to find, they only made 500 of them while Triumph churned out about 300,000 Spitfires.
307 Ti SS1 built - I suspect the vast majority survive
Mister Towed wrote:
I'd put a Puma engine on an RX8 gearbox into the standard SS1 chassis...
I’m not sure the RX8 box would fit, the tunnel is deceptively small and moving the Engine forward is restricted by the inboard dampers (the K series had a different damper mounting crossmember with cutouts to clear the crank pulley!) - I have a box here (destined for one of my GT or GTE) and a few SS1 chassis, so I might measure up?
9 Dec 2017, 12:21pm
I have an RX8 five speed box sitting on a '67 spitfire chassis in my garage at the moment ready to take the engine from the 1.7 Puma sat next to it. The Mazda box is actually quite narrow from the bellhousing back, I could take some measurements later if you're interested.
Triumph Special - it looks fine to me from some angles, but it looks too short and too high from the side making it look rather dumpy. That's possibly down to the physical height of the engine, you'd expect a V8 to sit lower than a straight six but with the induction system sitting in the V it's likely to be taller than an inline motor with its induction on the side. Shame there's no pictures of the motor in situ.
9 Dec 2017, 5:16pm
150 and 200 Maserati's are very pretty little cars ...I do tend to lean more towards the Maserati's than the Ferrari's of that era with a couple of notable exceptions ...
9 Dec 2017, 5:43pm
I can confirm that an RX8 box won’t fit in an SS1 chassis without surgery.
11 Dec 2017, 1:49pm
Just about anything can be made to go fast and handle well if you throw enough money at it. Out of the box though, it doesn’t compare (and yes, I’ve owned a few spitfires)
12 Dec 2017, 10:15am
lancelot link wrote:
I BET IT DOESN'T ....And I think fitting a bonnet scoop would be the least of your issues !! ...
Having now seen your impressive Formosa build, I can see what you mean.
However- with your bonnet stretch and wing widening, it shows what can be done.
